  3. Node to Node communication
15 Posts 6 Posters 11.1k Views 5 Watching
  • T Offline
    T Offline
    TEStevens
    Hello
    Is it possible for two nodes to directly talk to each other?
    If so can someone point me to an example of how to do this if it exists?
    I am have just a few sensors that I have manually assigned sensor ids to and I would like to have them talk to each other without necessarily needing a controller.
    • hekH Offline
      hekH Offline
      Yes, messages follow this routing:
      Just use setDestination on the MyMessage before sending.
      On the receiving node you have to add a callback method for incoming messages and call gw.process() in loop().
      B F 2 Replies Last reply
        B Offline
        B Offline
        boozz
        @hek
        But you'd always need a gateway, correct?
        boozz
        • hekH Offline
          hekH Offline
          wrote on last edited by hek
          Gateway or Repeater node (in a two sensor setup).
          In the picture above two leaf sensors (in the same "leaf") can talk to each other just via the repeater node.
          B 1 Reply Last reply
            B Offline
            B Offline
            boozz
            @hek
            Ok, thanks!. For some reason I thought that always an gateway had to be involved. Good to know.
              F Offline
              F Offline
              funky81
              @hek does it mean that the radio in repeater side has to be always in awake position?
              • hekH Offline
                hekH Offline
                @funky81
                Yes, that is probably best. :)
                F 1 Reply Last reply
                  @funky81
                  F Offline
                  F Offline
                  funky81
                  @hek noted... Thanks
                  • G Offline
                    G Offline
                    gigi
                    wrote on last edited by gigi
                    I made a sketch that sends a V_VAR1 from node 7 to node 8
                    send sketch
                    int cval_use, cval_gen;#define CHILD_ID_WATT 0
                    MyMessage msgVar1(CHILD_ID_WATT,V_VAR1);
                    MyMessage msgVar2(CHILD_ID_WATT,V_VAR2);
                    gw.send(msgVar1.setDestination(8).set(cval_use) );
                    gw.send(msgVar2.setDestination(8).set(cval_gen) );
                    receive sketch
                    if (message.isAck())
                    //read: 7-0-8 s=1,c=1,t=25,pt=2,l=2:486
                    if (message.type==V_VAR1)
                    int Var1;
                    Var1= atoi(message.data);
                    Serial.println("#########V_VAR1#########");
                    Serial.println("Var1");
                    Serial.println(Var1);
                    Serial.println("##########V_VAR1########");
                    if (message.type==V_VAR2)
                    int Var2;
                    Var2 = atoi(message.data);
                    Serial.println("########V_VAR2##########");
                    Serial.println("Var2");
                    Serial.println(Var2);
                    My problem:
                    Var1 and var2 ia alway 0.
                    send sketch serial
                    send: 7-7-0-8 s=1,c=1,t=24,pt=2,l=2,st=ok:580
                    send: 7-7-0-8 s=1,c=1,t=25,pt=2,l=2,st=ok:0
                    receiver sketch
                    read: 7-0-8 s=1,c=1,t=24,pt=2,l=2:580
                    Var1: 0
                    read: 7-0-8 s=1,c=1,t=25,pt=2,l=2:0
                    Var2: 0
                    Vera lite - mysensors Ethernet gateway - AirWik sensor - Relay Module
                    • hekH Offline
                      hekH Offline
                      You'll probably have to use message.getInt() in the receiving node (because this data is transmitted in binary format).
                      • K Offline
                        K Offline
                        krayola
                        Earlier today, I was fiddling with using setDestination() and always got st=fail showing up on the gateway, and the message never got to the node I wanted it to... And all the nodes were in my office at the time. I was running trunk for all libs.
                        Any ideas what to look at? The gateway's error led never flashed, either.
                        hekH 1 Reply Last reply
                        • K krayola
                          hekH Offline
                          hekH Offline
                          @krayola
                          How did your network topology look like?
                          Possible to show the debug log on gateway/repeater node (that should relay message)?
                          • K Offline
                            K Offline
                            krayola
                            It seems #define DEBUG is on by default in master :)
                            https://github.com/mysensors/Arduino/blob/9192da3a7d99171c2f42436a0a4ab8c72463119d/libraries/MySensors/MyConfig.h
                            My topology seems to be flat right now. I only have 3 nodes + gateway at present.
                            I did try having combination repeater+sensor nodes, but they were using sleep() which may have been part of the problem.
                            When I use gw.request() I'm able to get messages from the gateway to the node in question (with appropriate controller logic).
                            Here's the code on the test sensor:
                            gw.send(msg.setSensor(i).set(temperature, 2).setDestination(1));
                            Here's the sensor connecting and trying to send a message to node 1 (which is
                            <- 0;0;3;0;9;send: 0-0-2-2 s=255,c=3,t=6,pt=0,l=1,st=fail:M
                            <- 0;0;3;0;9;read: 2-2-0 s=255,c=3,t=11,pt=0,l=18:Temperature Sensor
                            <- 2;255;3;0;11;Temperature Sensor
                            <- 0;0;3;0;9;read: 2-2-0 s=255,c=3,t=12,pt=0,l=3:1.0
                            <- 2;255;3;0;12;1.0
                            <- 0;0;3;0;9;read: 2-2-0 s=0,c=0,t=6,pt=0,l=5:1.4.1
                            <- 2;0;0;0;6;1.4.1
                            <- 0;0;3;0;9;read: 2-2-1 s=0,c=1,t=0,pt=7,l=5:24.00
                            <- 0;0;3;0;9;send: 2-0-1-1 s=0,c=1,t=0,pt=7,l=5,st=fail:24.00
                            Node 1 was initialized:
                            gw.begin(incomingMessage, AUTO, false);
                            and uses
                            gw.sleep(SLEEP_TIME);
                            I thought I'd mention that having a request in the code makes it so i can reliably receives up to 2 messages from the gw (via the controller). Any more than that get lost.
                            gw.request(outdoorTempSensorId, V_TEMP, outdoorTempNodeId);
                            I clearly need to go read all the code :-) There's not that much of it.
                            • hekH Offline
                              hekH Offline
                              If your node expects messages you cannot sleep it. It must call gw.process() as often as possible.
                              • K Offline
                                K Offline
                                krayola
                                I figured that out from the other thread :)
                                I added this little helper to my copy of MySensors.cpp:
                                    void MySensor::wait(unsigned long ms) {
                                            bool slept_enough = false;
                                            unsigned long start = millis();
                                            unsigned long now;
                                            // Let serial prints finish (debug, log etc)
                                            Serial.flush();
                                            while (!slept_enough) {
                                                    MySensor::process();
                                                    now = millis();
                                                    if (now - start > ms) {
                                                            slept_enough = true;
                                In theory it'll handle the millis() rollover, but I haven't verified yet.
                                I'm now able to send messages between nodes with and without being in repeater mode. I have yet to test repeater mode, as i haven't convinced a sensor it can't see the gw yet :)
