  3. Vera
  4. Push Data to Vera Node
verapush variable t
7 Posts 2 Posters 3.6k Views 1 Watching
  • RJ_MakeR
    RJ_MakeR
    RJ_Make
    wrote on last edited by RJ_Make
    Ok,
    Current Project:
    So I'm working on another project that involves controlling an existing ventilation system. It's very similar to the water heater control a few months ago..
    Problem Description:
    The sensor node needs to monitor the ventilation signal from the HVAC controller, and report an On or Off status to the Vera Node. (much like battery level, last update.. etc..) I have all the hardware completed however.... I don't know how to send this information from the sensor node to the Vera node?
    Question:
    How do I send this information from the sensor node to the Vera node?
    RJ_Make
      Why not just send the ventilation status as V_LIGHT or V_VAR_1.
      RJ_MakeR 1 Reply Last reply
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @hek I guess in an effort to keep things a little neater. Is it even possible to send vars to the Vera Node?
        RJ_Make
          What do you mean by "Vera Node"?
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @hek
            When a sensor is added to Vera, a 'Node' and x number of children are created. That Node is what I'm talking about. The parent (node) of the children in Vera.
            RJ_Make
              I would suggest your Arduino Node/sketch creates a child device (e.g. Light) which you report values on. The "Vera Node" device shouldn't be used for this... But if you must it has child-id 255.
                RJ_MakeR
                RJ_MakeR
                RJ_Make
                @hek
                I'll take your advice and create and use a light child.
                RJ_Make
