  3. Can't get MySensors to work - someone got an easy sketch?
3 Posts 3 Posters 1.3k Views 4 Watching
    maxdorable
    wrote on last edited by maxdorable
    Hi everybody,
    I have tested so many sketch's from other people, but I can'tget one situation to work.
    My equip:
    2 Arduino Nano with NRF24
    Raspberry 2 with Pimatic or ioBroker
    Arduino 1.8.2
    Mysensor 2.1.1
    From begin:
    I have made a serial Gateway, by using the example in Arduino.
    * The ArduinoGateway prints data received from sensors on the serial link.
    * The gateway accepts input on seral which will be sent out on radio network.
    * The GW code is designed for Arduino Nano 328p / 16MHz
    * Wire connections (OPTIONAL):
    * - Inclusion button should be connected between digital pin 3 and GND
    * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
    * LEDs (OPTIONAL):
    * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    The Debug Log say:
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    0;255;0;0;18;2.1.1
    0;255;3;0;9;MCO:BGN:STP
    ioBroker and Pimatic say the same, the Gateway is connected by USB. (in the Log above the gateway isn't connected to the raspberry, but the PC)
    Now I want to add a simply Sensor like a Door- or a Motion Sensor. I Use the example sketch from arduino.
     * Version 1.0 - Henrik Ekblad
     * Motion Sensor example using HC-SR501
     * http://www.mysensors.org/build/motion
    // Enable debug prints
    // #define MY_DEBUG
    // Initialize motion message
    	sendSketchInfo("Motion Sensor", "1.0");
    	present(CHILD_ID, S_MOTION);
    	// Read digital motion value
    	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
    	Serial.println(tripped);
    	send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
    	sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
    And this is the Debug Log:
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    12 TSM:INIT:STATID=3
    14 TSF:SID:OK,ID=3
    16 TSM:FPAR
    53 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2060 !TSM:FPAR:NO REPLY
    2062 TSM:FPAR
    2098 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4106 !TSM:FPAR:NO REPLY
    4108 TSM:FPAR
    4144 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6152 !TSM:FPAR:NO REPLY
    6154 TSM:FPAR
    6190 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8198 !TSM:FPAR:FAIL
    8199 TSM:FAIL:CNT=1
    8201 TSM:FAIL:PDT
    What is wrong? Can someone help me?
    AWIA gohanG 2 Replies Last reply
    • M maxdorable
      Hi everybody,
      My equip:
      Arduino 1.8.2
      Mysensor 2.1.1
      From begin:
      * LEDs (OPTIONAL):
      The Debug Log say:
      0;255;0;0;18;2.1.1
      // #define MY_DEBUG
      3 TSM:INIT
      4 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      14 TSF:SID:OK,ID=3
      16 TSM:FPAR
      2062 TSM:FPAR
      4108 TSM:FPAR
      6154 TSM:FPAR
      8198 !TSM:FPAR:FAIL
      8199 TSM:FAIL:CNT=1
      8201 TSM:FAIL:PDT
      AWIA
      AWIA
      AWI
      @maxdorable Welcome on the forum. The first steps are the steepest ;-) it seems like the node cannot find its parent. In many cases this is related to radio problems. Have you tried the steps in the "Troubleshooting" section?
      • M maxdorable
        Hi everybody,
        My equip:
        Arduino 1.8.2
        Mysensor 2.1.1
        From begin:
        * LEDs (OPTIONAL):
        The Debug Log say:
        0;255;0;0;18;2.1.1
        // #define MY_DEBUG
        3 TSM:INIT
        4 TSF:WUR:MS=0
        11 TSM:INIT:TSP OK
        14 TSF:SID:OK,ID=3
        16 TSM:FPAR
        2062 TSM:FPAR
        4108 TSM:FPAR
        6154 TSM:FPAR
        8198 !TSM:FPAR:FAIL
        8199 TSM:FAIL:CNT=1
        8201 TSM:FAIL:PDT
        @maxdorable do you see any message received from the gateway? Keep in mind that NRF24 use quite some peak power during transmission so not all boards can supply enough power and a capacitor is needed on the VCC and GND near the radio. Quite some people got it sorted out (me included=ì) by using one of those adapters with voltage regulator from 5v to 3.3V + capacitor (if not included already in the adapter)
