  2. Enclosures / 3D Printing
  3. MySensors weather station
138 Posts 16 Posters 101.8k Views 15 Watching
    wrote on last edited by gohan
    #21
    20$ for a potentiometer???? :scream_cat:
    With that price it is cheaper to hack a spare part from another weather station :D
    • H Offline
      H Offline
      Haha.. yes.. didn't google prices. That's pricey :grimacing:
      • D dbemowsk
        So here is an update on where I am at with the direction rotor assembly. I came up with the following proposed circuit board assembly based on my circuits.io layout from my previous post. All of the reed switches are in a circular configuration and alternate the 2 different switch banks seen in the above post.
        0_1493175374379_upload-a0192f97-d885-4f50-b4cd-9f01ec151da7
        Following that diagram, here is the final prototype board. The only difference in the final board is that I used 3.3k resistors, as I was low on 2.2k's. I figured all I should have to do is make a couple adjustments to the code for the derived values when a reed switch was activated.
        0_1493175842348_upload-46ddb478-2a46-4b59-88fa-6a290eec5272
        Even though the design seemed pretty solid, I seem to be having some issues with it. I have tried a few different rotor and magnet assemblies. All of the magnets are neodymium magnets that I got from various salvage operations. The order from left to right is the order that I tested them in.
        0_1493176935322_upload-3b93081d-dd79-412c-b882-e6327d927e4b
        It appears that @gohan was correct about the first test rotor. Some of the other ones just seemed a bit erratic. There are a couple other things that I want to try, but I'm starting to look at some kind of 360 degree angle sensor to potentially use. I am wondering if anyone in the forum has done any kind of rotational angle sensing, and what sensor did you end up using?
        Y Offline
        Y Offline
        @dbemowsk You could use a compass sensor (e.g. HMC5883L) with a small magnet revolving above it.
        Requires some math to get the angle but once you nail it you'll get incredible precision from it.
          I still think the central LED with 8 phototransistor around is the cheapest solution :) (given that you are already 3D printing everything, I don't think one more part will make much difference; there is one example in another topic about hacking a weather station)
          D 2 Replies Last reply
            @gohan I am assuming that you are talking about this post:
            https://forum.mysensors.org/topic/6645/fody-weather-station-wind-sensor/2
            I would have to figure out how to wire everything, but that would be an option.
              @gohan $5 US for a 10 pack
              http://www.ebay.com/itm/10PC-LTR-301-002-Lite-On-Phototransistor-NPN-Plastic-Side-Look-10-pieces-/111612940043?hash=item19fca64f0b:g:uKIAAOSwv0tVBIf4
              Or I could go this route and have a bunch of spares for the parts bin. The per unit cost would be cheaper that way, but you have to buy a bigger bulk of them.
              http://www.ebay.com/itm/50-HONEYWELL-SDP8436-003-2-PIN-PHOTO-TRANSISTOR-DETECTOR-NPN-SIDE-LOOK-/191915022332?hash=item2caf06d7fc:m:mT-sRL8E_IkMeYJBasXQtng
                I was referring exactly to that topic. Maybe you could ask Flopp if he could measure his part for you. The tricky part will be to find the right brightness for the LED when it is crossing between 2 phototransistor, but I think it will be easier to adjust than changing a magnetic field :)
                About those parts, I can't say much, it is up to you: with 10 you still have 2 as spares just in case, 50 are quite a lot unless you plan to build more for your friends :)
                D F 2 Replies Last reply
                  @gohan Good point on the 50 pieces. I can do some experimenting prior to the final design to figure out what is going to work best.
                    keep in mind that if you don't have a regulated voltage, the LED may change brightness as battery drains out. It just came to my mind: can you manage on the sw side 2 of your reed switches on at the same time? If you can find a way you can still use the magnet and add additional "half step" in your wind direction and make it more precise
                    D 1 Reply Last reply
                      @gohan My plan I think is going to be to have a solar panel that will charge a small LiPo or SLA battery. I would size the battery big enough to handle the regulator on the pro mini and use the regulated output voltage to run the LED to give it a constant brightness.
                      My original plan with the reed switches was to have the ability to trigger 2 reed switches at once. That was the reason for having 4 reed switches for N S E W and the other 4 for NE SE SW NW. I designed it to use 2 IO lines for the 2 different banks of 4 reed switches. That way if the N and NE reed switches were triggered that you would get that extra half step. The biggest problem that I am running into is that for some reason the reed switches don't seem to be triggering consistently with any of the magnet configurations I have tried. That is why I wanted to look at another approach.
                      I ordered the 10 photo transistors this morning. I will still look at a way to run them as 2 banks of 4 sensors like I did with the reed switches so I can get that extra half step.
                        F Offline
                        F Offline
                        flopp
                        wrote on last edited by flopp
                        #31
                        @gohan said in MySensors weather station:
                        The tricky part will be to find the right brightness for the LED when it is crossing between 2 photo-transistor, but I think it will be easier to adjust than changing a magnetic field :)
                        What I did for wind direction is that I "look" for the first photo-transistor that get light from the LED and use that direction. So I don't care if the light is crossing between 2 photo-transistor. I scan from first digital in until i scanned all of them.
                        void readWindDirection()
                          //check in what direction the wind is. First sensor that have light will be the direction
                          int i = 4;
                          for (i; i < 9 ; i++){
                            if (!digitalRead(i)){
                              WD = WDarray[i-4];
                              return;
                          i = 14;
                          for (i; i < 17 ; i++){
                              WD = WDarray[i-9];
                              return;
                        • F flopp
                            int i = 4;
                                WD = WDarray[i-4];
                                return;
                            i = 14;
                                WD = WDarray[i-9];
                                return;
                          @flopp I am curious how you wired your electronics. I saw that as one of your original questions in your fody weather station post. so based on what you are saying, you really only use the 8 different directions, N, NE, E, SE, S, SW, W, NW, correct?
                          I have the basic design of the one you had pictured in your post mostly done. I still have to plan for circuit board mounting and wire connections, but I don't think that should be too difficult.
                          Here is my starting design done in OpenSCAD. I have the center hole threaded part way with a US 1/4 x 20 thread as that is what I used for the bolts to go through the wind vane.
                          0_1493275410728_upload-206e872f-5ef5-4ef8-9c8b-5e4536d8fb31
                          0_1493275543341_upload-febb1225-6256-4cc2-bee9-2c4d220d3238
                          I shoud be getting the phototransistors by Monday, so I want to draw up a preliminary design for the circuit board before that.
                          • D dbemowsk
                            F Offline
                            F Offline
                            flopp
                            @dbemowsk said in MySensors weather station:
                            Yes, correct. I have 8 receivers for the light.
                            I want to know more about this product https://www.youtube.com/watch?v=-oQiJ50LcAc
                            • D dbemowsk
                              F Offline
                              F Offline
                              flopp
                              Your drawings look good.
                              • D Offline
                                Here is possibly how it would be fitted into the wind vane body cap. It'll be a tight fit for the PCB, but I'm sure I can make it.
                                0_1493290462764_upload-41341d20-831d-4331-9aba-56d34034fbb9
                                • wallyllamaW Offline
                                  wallyllamaW Offline
                                  wallyllama
                                  Some things about the direction sensor, your magnet/reed switch is exactly what is in the old dallas 1-wire weather station and it worked well giving 16 positions,
                                  the led/photodiode method mentioed by gohan is interesting, if you used analog inputs you could use the value across 3 of them at a time to interpolate a pretty high resolution answer, multiplexing could make it so you dont need 8 analog inputs.
                                  Another thing is a rotary encoder, ive seen them used to measure the angles of telescope mounts, i believe they can be had with good enough resolution for your needs.
                                  I didnt read the whole thread, apologies if i am repeating ideas, or if you have decided on a solution.
                                  • wallyllamaW wallyllama
                                    @wallyllama No problem, I appreciate the input.
                                    • D Offline
                                      So for the phototransistor method, I figured I could use a similar approach to what I was planning with the reed switches. Here is a proposed schematic:
                                      0_1493356241919_upload-499fb8bd-e4c7-435b-a86a-114395356c60
                                      The idea is to use two identical banks of 4 phototransistors and alternating these in the slots. This should allow me to get the increased resolution that I was figuring on getting with the reed switch design.
                                      Does anyone see any issues with this design?
                                      F 1 Reply Last reply
                                      • D dbemowsk
                                        F Offline
                                        F Offline
                                        flopp
                                        @dbemowsk
                                        On my(fody) wind direction they use GND instead of VCC. When light is hitting the receiver, GND is passing through and you get a shortcut. I think, in that way you don't need all the 3,3K resistors.
                                        About resolution, personally I wouldn't focus on that because the wind is never in the same direction more than a few second then it moves a little bit. Maybe it stays in same direction when you have strong winds?
                                        • F flopp
                                          @dbemowsk
                                          @flopp Are you only using 1 analog data line? The idea behind the resistors is to give varying degrees of 0 to 5 volts on the analog pin. Depending on which phototransistor is triggered, the value seen by the IO line is different for every one allowing you to differentiate which sensor is tripped.
                                          If you are saying not to worry as much about the resolution, then I should be able to drop to using only 1 analog line instead of two with a configuration like this:
                                          0_1493364799125_upload-a8f9c536-c440-4196-a5f6-060f6c6ce3f4
                                          12.2k
