  2. Enclosures / 3D Printing
  3. MySensors weather station
138 Posts 16 Posters 112.8k Views 15 Watching
  • dbemowskD dbemowsk
    @flopp Are you only using 1 analog data line? The idea behind the resistors is to give varying degrees of 0 to 5 volts on the analog pin. Depending on which phototransistor is triggered, the value seen by the IO line is different for every one allowing you to differentiate which sensor is tripped.
    If you are saying not to worry as much about the resolution, then I should be able to drop to using only 1 analog line instead of two with a configuration like this:
    0_1493364799125_upload-a8f9c536-c440-4196-a5f6-060f6c6ce3f4
    F
    F
    flopp
    @dbemowsk
    I am using 8 digital inputs, with pinmode(x,INPUT_PULLUP) on all of them, A0, A1 and A2 i use as digital input because I am using UNO so all the digitals was occupied with NRf and Rain, Wind speed.
    dbemowskD 1 Reply Last reply
    • F flopp
      @dbemowsk
      dbemowskD
      dbemowskD
      @flopp I just didn't want to use up all the IO lines if I didn't have to. The designs that I was showing with the resistors allows you to detect multiple switch triggers with 1 or 2 I/O lines depending how you want that detection done. I want to add a few other sensors to the setup, so I want to keep as many IO lines free as I can.
      • dbemowskD
        dbemowskD
        Just got my phototransistors. The ebay auction said that it was for 10 sensors. I got 15..... BONUS. :^)
        wallyllamaW 1 Reply Last reply
        • dbemowskD
          dbemowskD
          OK, so I am doing some testing on the new wind direction sensor board I am building. My problem is that the infrared LED that I have, which was scavanged from an old remote, has good IR pointing forward. but when I try to direct it sideways to the IR sensors, I appear to not be getting enough IR light to trigger the sensors. If I shine a flashlight at each of the sensors, they register, but not when O Does anyone know of either a different IR diode, or a way that I can get the existing diode to shine more in a sideways direction? Here is what the board is looking like. I currently only have one set of 4 sensors connected for testing. You can kind of see that the IR LED is lit.
          0_1495063129068_upload-5fcf55ca-db4f-48c5-9d3a-721e5c0b9bb1
          This is the design of the IR rotor that directs the light which gets screwed to the end of the bolt that is the shaft of the wind direction vane. The majority of the IR light gets directed at the end of the bolt.
          0_1495063638749_upload-c72eb7e3-4af9-4742-bffe-20d565d4835b .
          I am up for any suggestions.
          wallyllamaW 2 Replies Last reply
            Something reflective that diffuses light?
              wallyllamaW
              wallyllamaW
              wallyllama
              @dbemowsk 15 is metric for 10.*
              • If you received 16, then I could have said you ordered in hex, and this would actually have been funny.
                wallyllamaW
                wallyllamaW
                wallyllama
                wrote on last edited by wallyllama
                #47
                @dbemowsk i have an led flashlight in the shape of a lantern, it has a shape like cone that has been dehydrated, so there is a concave curve from the base to the tip. Sort of like a golf tee but different proportions.0_1495070004870_1495069978157-964853724.jpg
                I guess it it like a regular flashlight reflector inside out
                • wallyllamaW wallyllama
                  dbemowskD
                  dbemowskD
                  @wallyllama That would have been funny. There are 10 types of people in this world, Those that understand binary, and those that don't.
                    dbemowskD
                    dbemowskD
                    @wallyllama My only problem with this is that the hole that the LED fits in is slightly larger than 5mm, so that cone would need to be tiny.
                      wallyllamaW
                      wallyllamaW
                      wallyllama
                      #50
                      @dbemowsk actually, you only have to illuminate the sensors that your slot faces, a 45° mirror or a reflector opposite the slot should help.
                        dbemowskD
                        dbemowskD
                        @gohan I tried putting a piece of tin foil in the hole, but it must not have been at the right angle.
                          Maybe a steel sphere? A white piece of plastic? Remember that you can use the smartphone camera to see the ir light coming from the led, in case you would like to see the result before assembling it
                            dbemowskD
                            dbemowskD
                            @gohan Yes, I have been using my smart phone camera. I use it all the time at work to test remotes. I have some other things to try later today. I will post my results.
                            • Luc3asL
                              Luc3asL
                              Luc3as
                              Hello all,
                              I'd like to add to this discussion my bit,
                              here is code from my older project of arduino based, battery operated, solar panel charged weather station
                              https://github.com/Luc3as/MySensors-WeatherStation
                              I must finish all documentation, I have PCBs ready and manufactured and tested, and models ready for 3d prints too.
                              I am not measuring wind so I am also interested in nice work above.
                              for now it is still work in progress, here is little teaser of overall look
                              • Luc3asL Luc3as
                                Hello all,
                                dbemowskD
                                dbemowskD
                                @Luc3as Thanks for the contribution. I have been quite busy the past few weeks and haven't had a lot of time to work more on the wind direction sensor. There are still a few issues I am working through with that before I can start jumping into the code for it. I am hoping to get more done this weekend.
                                As for your 3D files, do you have them on thingiverse or somewhere accessible for us to check them out? I am interested in the work you have done.
                                  Those are quite a lot of solar panels. Is it that power hungry?
                                    dbemowskD
                                    dbemowskD
                                    @gohan I can't see those small panels delivering that much. Plus, at certain parts of the day a number of the panels will most likely be shaded lowering their output.
                                    Luc3asL 1 Reply Last reply
                                      Luc3asL
                                      Luc3asL
                                      Luc3as
                                      @dbemowsk yup, actually there are 8 of them, each providing nominal 0,5 volts, so to power up the lipo charger for battery I need at least 4 volts, in direct sunlight I think this will not be problem, but as @dbemowsk says, it will not have ideal position to sun every day and for whole time. but there is big enough reserve at battery , providing power for few days to weeks even without solar panel.
                                      and I am also checking voltage on solar panel so if there would be some problem with charging I can set notifications or something from home automation system.
                                      gohanG 1 Reply Last reply
                                      • G
                                        G
                                        GaryStofer
                                        I did some wind speed and direction sensor boards that I use in my own weather station design. All solid state and high resolution with analog signal readout, voltage for direction, 8 pulse per rev for speed. For inspiration see http://wws.us.to. Gary
                                        • Luc3asL Luc3as
                                          @Luc3as if you put solar panels in series you will get resistance from the shaded ones (at least that is what I saw in some experiments) . It would be better to have a single one pointing south that gathers the most sunlight and that's it
