  2. Enclosures / 3D Printing
  3. MySensors weather station
138 Posts 16 Posters 112.8k Views 15 Watching
  • sundberg84S sundberg84
    @dbemowsk - are your goal to sleep this sensor or whats your thoughts running it with battery? It might be a hard nut to crack 5v 16mhz and batteries?
    Love your thread btw! Keep up the good work :)
    dbemowskD
    dbemowskD
    @sundberg84 I don't plan to sleep the sensor at all. Putting the sensor to sleep would cause problems with the anemometer and the interrupt I need to use for that. The main reason for needing it to run on battery is that I plan to mount this up in the air on the top edge of my house. This is why I want to also put a solar panel on it. During the day the solar panel can run the sensor and charge the battery, and at night the battery can take over.
      Are you sure you don't want to sleep sensor? If it is a matter of interrupts for anemometer, you could use a dinamic sleep time, like if you don't have any wind motion within 2 seconds put the node to sleep and wake it up on pin change
      dbemowskD 1 Reply Last reply
        dbemowskD
        dbemowskD
        @gohan I have never worked with a dynamic sleep timer. Do you have am example of how this is used?
          Not really, maybe just put the sleep in an IF statement and check if the time from last impulse from the anemometer is over than 2 sec then sleep, otherwise it just continues loop
            dbemowskD
            dbemowskD
            @gohan So am I correct in assuming that an interrupt will wake a sleep timer? As long as I can catch the pulses from the anemometer, I don't see a reason I couldn't use a sleep timer. Just thinking about it, I may also want to use an interrupt for the rain gauge sensor for similar reasons. Not sure about the wind direction sensor.
            gohanG 1 Reply Last reply
            • dbemowskD
              dbemowskD
              Here are a few more pictures of the new layout with the new anemometer cups.
              0_1499087266284_upload-2b958d54-e3bb-4ae1-9ba4-815bc9ac5f88
              0_1499087278053_upload-dec6c2b6-ee03-4891-9f89-161246ed722f
              0_1499087288381_upload-164b9af0-fe6c-4ebf-ab25-e675e10c41d7
              • dbemowskD dbemowsk
                @dbemowsk basically you would need to attach sleep to both interrupts on pin 2 and 3 and use them for anemometer and rain meter. For wind direction check it when it wakes up
                • dbemowskD
                  dbemowskD
                  So I am trying to figure out code for the wind speed sensor and I see there is a V_GUST value. I am wondering what people use for that value.
                  • dbemowskD
                    dbemowskD
                    So now that I have the wind direction sensor working, I need to try to migrate the code into my weather_station sketch. One option that I am working on implementing is a calibration button for North. So after I get things set up and mounted, I will use a compass to point the wind vane towards North. I will then press the calibration button which will save the current direction position to EEPROM if it is different than the one stored. The following code will then be used to get the true direction that the wind vane is pointing.
                    value = 360 * myAS5047.sensor_read() / 16383; //Read the value from the direction sensor as a value from 0 to 360
                    north_offset = EEPROM.read(address);  //Read the offset value from EEPROM
                    dir = ((value - north_offset) < 0) ? 360 - abs (value - north_offset)  : value - north_offset; //Get the true direction
                    insert code to read the button and if pressed, check the current value stored in EEPROM against the value read from the sensor
                    and write the new value if it is different.  If the sensor value matches the current stored value, then ignore the write to
                    save on EEPROM writes.
                    So with this idea, I will need to know a few things. First, I am assuming that MySensors does EEPROM writes and reads. Is there a particular addreess pointer variable that I should use when writing my value to EEPROM? I will also need to know how I can get the address pointer to that data the same each time the arduino is reset, especially if MySensors does writes and reads.
                    As always, any input is appreciated.
                    Nca78N 1 Reply Last reply
                      Nca78N
                      Nca78N
                      Hello, @dbemowsk
                      You should use the built in method from the MySensors library to do that :
                      https://www.mysensors.org/download/sensor_api_20#saving-state
                      dbemowskD 2 Replies Last reply
                      • Nca78N Nca78
                        Hello, @dbemowsk
                        dbemowskD
                        dbemowskD
                        @Nca78 Thanks, exactly what I wanted to know.
                        • Nca78N Nca78
                          Hello, @dbemowsk
                          dbemowskD
                          dbemowskD
                          @Nca78 So my values are from 0 to 360, looking at the link you posted, the value that you save to an address is uint8_t which is equivalent to a byte (0 to 255). Is there a way to store a word value (uint16_t), or do I need to break the value into two bytes and store those into two positions?
                            Nca78N
                            Nca78N
                            @dbemowsk said in MySensors weather station:
                            Yes it can only store bytes, but it's not a big deal to make a method to read/write values on 2 bytes.
                            Else you can just keep a precision of 2° and divide by 2 to get a 0=>180 value ;)
                            • dbemowskD
                              dbemowskD
                              Actually thinking about this, I should be using 0 to 359. 0 to 360 is actually 361 positions, not 360.
                                wrote on last edited by gohan
                                #95
                                Precision of 2° I believe it's enough as many weather stations provide just the 8 general directions
                                  dbemowskD
                                  dbemowskD
                                  @gohan It would only be for saving the offset for north, so I think I will do that.
                                  • dbemowskD
                                    dbemowskD
                                    So I am trying to figure out the SPI for the wind direction sensor. Where is the SPI code for MySensors. Do I need to call SPI.begin()? Does MySensors code use transactions? If so, where can I find that to look at.
                                      Doesn't it have a library?
                                        dbemowskD
                                        dbemowskD
                                        @gohan It does, but it is an untested library. This is the test code that I ran using that library:
                                        #include "AS5047.h"
                                        #include <EEPROM.h>
                                        #define SWITCH_PIN 7 //The north calibration switch
                                        AS5047 myAS5047(5); // SS pin
                                        int address = 0;      //EEPROM address counter
                                        int north_offset = 0;
                                        long value;
                                        int dir;
                                        bool button;
                                          SPI.begin;
                                          Serial.begin(9600);
                                          pinMode(SWITCH_PIN, INPUT_PULLUP);
                                          value=(360*myAS5047.sensor_read())/16383;
                                          dir = ((value - north_offset) < 0) ? 360 - abs(value - north_offset) : value - north_offset;
                                          Serial.print("measured direction: ");
                                          Serial.println(dir);
                                          Serial.print("north_offset: ");
                                          Serial.println(north_offset);
                                          button = digitalRead(SWITCH_PIN);
                                          if (!button && north_offset != value) {
                                            EEPROM.write(address, value);
                                            north_offset = value;
                                            Serial.println("Button pressed");
                                          delay(1000);
                                        This test worked fine, now I am trying to merge this with my weather station sketch. I am not very familiar with working with SPI. In the setup() method, they call SPI.begin(). I am just trying to figure out what I need to do for merging the code.
                                        • dbemowskD
                                          dbemowskD
                                          Should all of the SPI stuff be included in the library?
