  3. Domoticz(Raspberry) with Mysensor USB gateway without Radio
6 Posts 2 Posters 3.9k Views 3 Watching
  • D
    D
    Dumoulin
    I try to create USB gateway without radio, but my domoticz under raspberry don't see this gateway.
    Could you check my code?
    //#define MY_RADIO_NRF24
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define IN_Sejour_Presence1  2  // Arduino Digital I/O pin number for Presence
    #define IN_Sejour_Presence2  3  // Arduino Digital I/O pin number for Presence
    #define IN_Sejour_Presence3  4  // Arduino Digital I/O pin number for Presence
    #define IN_ChParents_Presence  5  // Arduino Digital I/O pin number for Presence
    #define NUMBER_OF_INPUT 4 // Total number of attached input port
    #define RELAY_Sejour_Volet1_Bas  22  // Arduino Digital I/O pin number for relay
    #define RELAY_Sejour_Volet1_Stop  23  // Arduino Digital I/O pin number for relay
    #define RELAY_Sejour_Volet1_Haut  24  // Arduino Digital I/O pin number for relay
    #define RELAY_Sejour_Volet2_Bas  25  // Arduino Digital I/O pin number for relay
    #define RELAY_Sejour_Volet2_Stop  26  // Arduino Digital I/O pin number for relay
    #define RELAY_Sejour_Volet2_Haut  27  // Arduino Digital I/O pin number for relay
    #define RELAY_Sejour_Volet3_Bas  28  // Arduino Digital I/O pin number for relay
    #define RELAY_Sejour_Volet3_Stop  29  // Arduino Digital I/O pin number for relay
    #define RELAY_Sejour_Volet3_Haut  30  // Arduino Digital I/O pin number for relay
    #define RELAY_Sejour_Lumiere1  31  // Arduino Digital I/O pin number for relay
    #define RELAY_Sejour_Lumiere2  32  // Arduino Digital I/O pin number for relay
    #define RELAY_Sejour_Lumiere3  33  // Arduino Digital I/O pin number for relay
    #define RELAY_Sejour_Chauffage1  34  // Arduino Digital I/O pin number for relay
    #define RELAY_Sejour_Chauffage2  35  // Arduino Digital I/O pin number for relay
    #define RELAY_SdJ_Volet1_Bas  37  // Arduino Digital I/O pin number for relay
    #define RELAY_SdJ_Volet1_Stop  38  // Arduino Digital I/O pin number for relay
    #define RELAY_SdJ_Volet1_Haut  39  // Arduino Digital I/O pin number for relay
    #define RELAY_ChParents_Volet_Bas  41  // Arduino Digital I/O pin number for relay
    #define RELAY_ChParents_Volet_Stop  42  // Arduino Digital I/O pin number for relay
    #define RELAY_ChParents_Volet_Haut  43  // Arduino Digital I/O pin number for relay
    #define RELAY_ChParents_Lumiere  44  // Arduino Digital I/O pin number for relay
    #define RELAY_ChParents_Chauffage  45  // Arduino Digital I/O pin number for relay
    #define NUMBER_OF_RELAYS 32 // Total number of attached relays port 22 to 53
    unsigned long Duree_Sejour_Lum1 = 60000;
    unsigned long Duree_Sejour_Lum2 = 60000;
    unsigned long Duree_Sejour_Lum3 = 60000;
    unsigned long Duree_ChParents_Lum = 60000;
    bool IN_Sejour_Presence1_Etat = LOW;
    bool IN_Sejour_Presence1_Etat_Avant = LOW;
    bool IN_Sejour_Presence2_Etat = LOW;
    bool IN_Sejour_Presence2_Etat_Avant = LOW;
    bool IN_Sejour_Presence3_Etat = LOW;
    bool IN_Sejour_Presence3_Etat_Avant = LOW;
    bool IN_ChParents_Presence_Etat = LOW;
    bool IN_ChParents_Presence_Etat_Avant = LOW;
    // Initialize motion message
    void before()
       // sendSketchInfo("MySensorBas", "1.0");
        for (int sensor=RELAY_Sejour_Volet1_Bas, pin=RELAY_Sejour_Volet1_Bas; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
            pinMode(pin, OUTPUT);
         pinMode(IN_Sejour_Presence1, INPUT);
         pinMode(IN_Sejour_Presence2, INPUT);
         pinMode(IN_Sejour_Presence3, INPUT);
         pinMode(IN_ChParents_Presence, INPUT);
        sendSketchInfo("Salon_Parents_SdJ", "1.0");
            present(sensor, S_BINARY);
         for (int sensor=IN_Sejour_Presence1, pin=IN_Sejour_Presence1; sensor<=NUMBER_OF_INPUT; sensor++, pin++) {
            present(sensor, S_MOTION);
        // Read digital motion value
        IN_Sejour_Presence1_Etat = digitalRead(IN_Sejour_Presence1);
        if (IN_Sejour_Presence1_Etat != IN_Sejour_Presence1_Etat_Avant){
          if (IN_Sejour_Presence1_Etat == HIGH){
      //          Serial.println(IN_Sejour_Presence1_Etat);
                send(msg.set(IN_Sejour_Presence1_Etat?"1":"0"));  // Send tripped value to gw
          IN_Sejour_Presence1_Etat_Avant = IN_Sejour_Presence1_Etat;
        IN_Sejour_Presence2_Etat = digitalRead(IN_Sejour_Presence2);
        if (IN_Sejour_Presence2_Etat != IN_Sejour_Presence2_Etat_Avant){
          if (IN_Sejour_Presence2_Etat == HIGH){
      //          Serial.println(IN_Sejour_Presence2_Etat);
                send(msg.set(IN_Sejour_Presence2_Etat?"1":"0"));  // Send tripped value to gw
          IN_Sejour_Presence2_Etat_Avant = IN_Sejour_Presence2_Etat;
        IN_Sejour_Presence3_Etat = digitalRead(IN_Sejour_Presence3);
        if (IN_Sejour_Presence3_Etat != IN_Sejour_Presence3_Etat_Avant){
          if (IN_Sejour_Presence3_Etat == HIGH){
      //          Serial.println(IN_Sejour_Presence3_Etat);
                send(msg.set(IN_Sejour_Presence3_Etat?"1":"0"));  // Send tripped value to gw
          IN_Sejour_Presence3_Etat_Avant = IN_Sejour_Presence3_Etat;
        IN_ChParents_Presence_Etat = digitalRead(IN_ChParents_Presence);
        if (IN_ChParents_Presence_Etat != IN_ChParents_Presence_Etat_Avant){
          if (IN_ChParents_Presence_Etat == HIGH){
      //          Serial.println(IN_ChParents_Presence_Etat);
                send(msg.set(IN_ChParents_Presence_Etat?"1":"0"));  // Send tripped value to gw
          IN_ChParents_Presence_Etat_Avant = IN_ChParents_Presence_Etat;
        if (message.type==V_STATUS) {
            // Change relay state
            digitalWrite(message.sensor-1+RELAY_Sejour_Volet1_Bas, message.getBool()?RELAY_ON:RELAY_OFF);
            // Store state in eeprom
            // Write some debug info
       //     Serial.print("Incoming change for sensor:");
       //     Serial.print(message.sensor);
       //     Serial.print(", New status: ");
       //     Serial.println(message.getBool());
      Have you tried commenting mydebug?
      • D
        D
        Dumoulin
        Yes, I Have:
        0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
        0;255;3;0;9;MCO:BGN:BFR
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSF:WUR:MS=0
        0;255;3;0;9;!TSM:INIT:TSP FAIL
        0;255;3;0;9;TSM:FAIL:CNT=1
        0;255;3;0;9;TSM:FAIL:PDT.
        But I don't know why I have on first error :Transport device initialization failed
        • D
          D
          Dumoulin
          When I put serial gateway code availiable on MySensor Site, I have the same error.
          I try to do MySensor USB gateway without radio for physical IO on Arduino(to have relay)
            It's actually weird, but if only need relays, you can control gpio directly from domoticz.
            • D
              D
              Dumoulin
              Ok, I find.
              Sketchinfo was in Presntation, and should be in setup.
