  3. MQTT keeps reconnecting [solved]
10 Posts 3 Posters 5.1k Views 3 Watching
  • mppM
    mppM
    mpp
    wrote on last edited by mpp
    My GatewayESP8266MQTTClient keeps connecting to the MQTT connection, these messages appear really fast (several per second):
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;Sending message on topic: mpp1-out/0/255/0/0/18
    IP: 192.168.0.164
    IP: 192.168.0.164
    IP: 192.168.0.164
    The MQTT log show the following:
    1494858022: New client connected from 192.168.0.164 as mpp-1 (c1, k15).
    1494858022: New connection from 192.168.0.177 on port 1883.
    1494858022: Client mpp-1 already connected, closing old connection.
    1494858022: New client connected from 192.168.0.177 as mpp-1 (c1, k5000).
    1494858022: New connection from 192.168.0.164 on port 1883.
    So it appears that the Gateway tries to connect but is then immediately being kicked out.
    Could it be that it is being kicked out by its own (previous) attempt to connect OR is there a problem with the controller?
    Is there a setting to configure the connection timeout?
    MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
    • mppM mpp
      IP: 192.168.0.164
      IP: 192.168.0.164
      IP: 192.168.0.164
      @mpp could it be related to the problem experienced in https://forum.mysensors.org/post/25269 ?
      • mppM
        mppM
        mpp
        @mfalkvidd, I only have one Gateway with the ID "mpp-1".
        "mpp-1" is both the client id in the gateway sketch:
        // Set MQTT client id
        #define MY_MQTT_CLIENT_ID "mpp-1"
        and the "Client id" in the gateway setting on mycontroller, but I assume this is correct?
        As soon as I change the latter the loop drops and the Gateway is connected to MQTT but then I no longer have that Gateway configured in mycontroller?
        J 1 Reply Last reply
        • mppM mpp
          J
          J
          jkandasa
          wrote on last edited by jkandasa
          @mpp What is the version of MyController are you using? Are you using inbuilt MQTT broker?
          Check the topic to-subscribe and to-publish.
          • mppM
            mppM
            mpp
            Hi @jkandasa, I'm using the latest 0.0.3.Alpha2 release. I tested both with mosquitto and the built in broker.
            As soon as I enable the Gateway in the UI I keep getting connections very fast (10 per second).
            IP: 192.168.0.164
            0;255;3;0;9;Attempting MQTT connection0;255;3;0;9;MQTT connected
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            0;255;3;0;9;Attempting MQT0;255;3;0;9;MQTT connected
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            IP: 192.168.0.164
            This happens both with mosquitto as with moquette.
            These are the topics I'm using: mpp1-in and mpp1-out
            I also noticed a java.lang.NullPointerException in the log, see https://github.com/mycontroller-org/mycontroller/issues/245
            2017-05-15 15:28:22,570 INFO [MQTT Rec: mpp-1] [org.mycontroller.standalone.gateway.mqtt.MqttCallbackListener:115] MQTT Gateway[tcp://192.168.0.177:1883] Reconnected successfully...
            2017-05-15 15:28:22,653 ERROR [nioEventLoopGroup-5-1] [io.moquette.server.netty.NettyMQTTHandler:84] Bad error in processing the message
            java.lang.NullPointerException: null
            	at io.moquette.spi.impl.ProtocolProcessor.route2Subscribers(ProtocolProcessor.java:460) ~[mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.moquette.spi.impl.ProtocolProcessor.processPublish(ProtocolProcessor.java:310) ~[mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.moquette.server.netty.NettyMQTTHandler.channelRead(NettyMQTTHandler.java:61) ~[mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:318) [mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:304) [mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.moquette.server.netty.metrics.MessageMetricsHandler.channelRead(MessageMetricsHandler.java:46) [mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.netty.handler.codec.ByteToMessageDecoder.fireChannelRead(ByteToMessageDecoder.java:276) [mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:263) [mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.netty.channel.ChannelInboundHandlerAdapter.channelRead(ChannelInboundHandlerAdapter.java:86) [mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.moquette.server.netty.metrics.BytesMetricsHandler.channelRead(BytesMetricsHandler.java:47) [mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.netty.handler.timeout.IdleStateHandler.channelRead(IdleStateHandler.java:266) [mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:846) [mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:131) [mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:511) [mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:468) [mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:382) [mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:354) [mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112) [mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:137) [mycontroller-dist-standalone-0.0.3.Alpha2-single.jar:0.0.3.Alpha2]
            	at java.lang.Thread.run(Thread.java:745) [na:1.8.0_121]
            2017-05-15 15:28:22,788 ERROR [MQTT Rec: mpp-1] [org.mycontroller.standalone.gateway.mqtt.MqttCallbackListener:55] MQTT Gateway[id:6, Name:MPP, serverURI:tcp://192.168.0.177:1883] connection lost! Error:Connection lost
            2017-05-15 15:28:22,927 INFO [MQTT Rec: mpp-1] [org.mycontroller.standalone.gateway.mqtt.MqttCallbackListener:115] MQTT Gateway[tcp://192.168.0.177:1883] Reconnected successfully...
            • mppM mpp
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              IP: 192.168.0.164
              J
              J
              jkandasa
              @mpp use different MQTT client id on your gateway sketch and MyController gateway configuration page. In the recent version, 3 random chars will be appended on MyController to avoid this kind of issue. If you want to try recent SNAPSHOT version have a look on >> http://forum.mycontroller.org/topic/58/download-snapshot-build
              • mppM
                mppM
                mpp
                I added abc to the id (mpp-1abc) and it behaves the same as if no gateway has been configured.
                What I don't understand now is how the nodes could be detected by mycontrolled (now the client id is different)?
                • mppM mpp
                  J
                  J
                  jkandasa
                  @mpp can you post your gateway sketch and MyController gateway configuration page(select gateway, click edit and post that page)
                  mppM 1 Reply Last reply
                  • J jkandasa
                    mppM
                    mppM
                    mpp
                    @jkandasa here's the sketch
                     * Version 1.0 - Henrik Ekblad
                     * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
                     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
                     * LED purposes:
                     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
                     * nRF24L01+  ESP8266
                     * VCC        VCC
                     * CE         GPIO4
                     * CSN/CS     GPIO15
                     * SCK        GPIO14
                     * MISO       GPIO12
                     * MOSI       GPIO13
                      * Inclusion mode button:
                    #define MY_BAUD_RATE 9600
                    #define MY_RADIO_RFM69
                    #define MY_IS_RFM69HW
                    #define MY_RF69_IRQ_PIN D1
                    #define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN
                    #define MY_RF69_SPI_CS D8
                    #define MY_RFM69_NETWORKID 99
                    #define MY_GATEWAY_ESP8266
                    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mpp1-out"
                    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mpp1-in"
                    // Set WIFI SSID and password
                    #define MY_ESP8266_SSID "Airport"
                    #define MY_ESP8266_PASSWORD "********"
                    // #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
                    // MQTT broker ip address.
                    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 177
                    #define MY_PORT 1883
                    // Enable inclusion mode
                    // Set blinking period
                    // Flash leds on rx/tx/err
                    #include <ESP8266WiFi.h>
                    	// Send locally attech sensors data here
                    This is the UI
                    • mppM mpp
                       * LED purposes:
                       * nRF24L01+  ESP8266
                       * VCC        VCC
                       * CE         GPIO4
                       * CSN/CS     GPIO15
                       * SCK        GPIO14
                       * MISO       GPIO12
                       * MOSI       GPIO13
                      This is the UI
                      mppM
                      mppM
                      mpp
                      upgrading to the latest build fixed my issues.
                      Thanks guys for the support!
