  3. UPS
UPS
30 Posts 8 Posters 9.0k Views 8 Watching
  • rozpruwaczR rozpruwacz
    isn't it better to buy ready made solution ? e.g. http://www.powerwalker.com/index.php?page=select&lang=en&cat=dc
    ben999B
    ben999B
    ben999
    @rozpruwacz
    No DIY, no fun ! :wink:
    gohanG 1 Reply Last reply
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      haha :) yeah, totally agree :P
      • ben999B ben999
        @rozpruwacz
        @ben999 said in UPS:
        @rozpruwacz
        No DIY, no problems, no fun :smile:
        • dbemowskD
          dbemowskD
          I didn't read all the comments, so forgive me if this was mentioned. What if you just used an SLA or AGM battery and connected a battery tender to it. The battery tender should keep the battery topped off without over charging it, and I would think have enough power to power the PI also. Then you are converting 220 down to 12, and if the power goes down, the battery tender will just shut off and the battery would take over. No extra loss in converting 12 to 220 and back to12 again.
            I think nobody wants to convert 12 to 220v
            ben999B 1 Reply Last reply
              ben999B
              ben999B
              ben999
              @dbemowsk
              Thank you for your message
              @gohan said in UPS:
              I think @gohan got me right here. I have a spare "standard" ups at home... but i dont find that tech very sexy (on top of it it's huge)
              It's fun to scratch head !!!
              • ben999B
                ben999B
                ben999
                wrote on last edited by ben999
                #27
                Guys,
                One last question :
                Can i draw current from the charger to power box and RPi while it is charging the home-made UPS ?
                I might be ordering this in case it is possible:
                link text
                dbemowskD 1 Reply Last reply
                  if the charger is not drawing too much current I'd say yes, but you need a buck converter
                  • ben999B ben999
                    Guys,
                    One last question :
                    link text
                    dbemowskD
                    dbemowskD
                    @ben999 The highest current draw from the list of Pi models is 2.5A on the model 3B (https://www.raspberrypi.org/help/faqs/#powerReqs). If you have a power supply slightly larger than whatever model you are running, you should be good. you just need to be able to supply enough so that the PI has enough to run whatever it is doing and some for charging.
                    • dbemowskD
                      dbemowskD
                      As I mentioned in my previous post a few days ago, you will want a battery tender, and not just a charger. A battery tender will shut off if the battery is fully charged, whereas just using a battery charger could overcharge the battery.
