  3. VEML6070 and VEML6075 UV sensors
52 Posts 6 Posters 19.9k Views 5 Watching
  • A Avamander
    @alexsh1 I have the same board, there seems to be a regulator and a few other components on the board, if you remove those, how's the power consumption then?
    alexsh1A Offline
    alexsh1A Offline
    alexsh1
    @avamander I have removed every component bit by bit. Originally the consumption was 56uA and now it is 50uA with the only sensor left on the board
    A 1 Reply Last reply
    • alexsh1A alexsh1
      A Offline
      A Offline
      Avamander
      wrote on last edited by Avamander
      #42
      @alexsh1 There's an I^2C address selection jumper on the board, maybe that draws current?
      alexsh1A 1 Reply Last reply
      • A Avamander
        alexsh1A Offline
        alexsh1A Offline
        alexsh1
        @avamander desoldered
        • alexsh1A alexsh1
          A Offline
          A Offline
          Avamander
          #44
          @alexsh1 Just desolder the sensor itself from the board if you're that far already? I wouldn't be surprised if aliexpress sellers sell counterfeit chips that are s****ier, I'm already seeing that with nRF24L01+'s
          • A Avamander
            alexsh1A Offline
            alexsh1A Offline
            alexsh1
            @avamander I tried to resolder it to the board - no luck.
            It is very small. Very hard to solder any wires to it
            • alexsh1A Offline
              alexsh1A Offline
              alexsh1
              Ok, I did manage to solder the bare sonsor.
              Consumption is still 50uA.
              Can anyone please let me know your VELM6075 break board consumption?????
              • alexsh1A alexsh1
                A Offline
                A Offline
                Avamander
                @alexsh1 I'd do it but I'm waiting for my replacement multimeter to arrive, sorry.
                • A Avamander
                  alexsh1A Offline
                  alexsh1A Offline
                  alexsh1
                  @avamander That's ok. Just post values here - other may benefit on this as well.
                  I still have no idea why the sensor is taking so much current
                  • T Offline
                    T Offline
                    tonbor
                    An old thread, tried the github ino for the VEML6075, is not working ok. UVA and UVB sometimes wrong negative figures. I am going to try the sparkfun library, is from 2018. Let you now if I get beter results.
                    T 1 Reply Last reply
                    • T tonbor
                      T Offline
                      T Offline
                      tonbor
                      This post is deleted!
                      • T Offline
                        T Offline
                        tonbor
                        Original by scalz@mysensors: https://forum.mysensors.org/topic/6952/veml6070-and-veml6075-uv-sensors/25#
                        Needs a modified VEML6075-lib: https://github.com/rejoe2/VEML6075
                        rewritten by Tonbor using sparkfun libary
                        //#define MY_NODE_ID 10
                        #include <SparkFun_VEML6075_Arduino_Library.h>
                        VEML6075 uv;
                        //VEML6075 veml6075 = VEML6075();
                        bool sensorFound = false;
                        #define CHILD_ID_UVI 1
                        #define CHILD_ID_UVA 2
                        #define CHILD_ID_UVB 3
                        uint32_t SLEEP_TIME = 30
                        1000; // Sleep time between reads (in milliseconds)
                        MyMessage uviMsg(CHILD_ID_UVI, V_UV);
                        MyMessage uvaMsg(CHILD_ID_UVA, V_UV);
                        MyMessage uvbMsg(CHILD_ID_UVB, V_UV);
                        sendSketchInfo("UV Sensor", "1.4T");
                        present(CHILD_ID_UVI, S_UV);
                        present(CHILD_ID_UVA, S_UV);
                        present(CHILD_ID_UVB, S_UV);
                        if (!uv.begin()) {
                        Serial.println(F("VEML6075 not found!"));
                        } else
                        sensorFound = true;
                        //#ifdef MY_DEBUG
                        // uint16_t devid = veml6075.getDevID();
                        // Serial.print(F("Device ID = "));
                        // Serial.println(devid, HEX);
                        // Serial.println(F("----------------"));
                        //#endif
                        if (sensorFound) {
                        unsigned long lastSend =0;
                        float uvi;
                        float uva;
                        float uvb;
                        static float uviOld = -1;
                        static float uvaOld = -1;
                        static float uvbOld = -1;
                        //veml6075.sleep(false); // power up veml6075 == begin()
                        //sleep(500);
                        // Poll sensor
                        //veml6075.poll();
                        uv.powerOn();
                        delay(250);
                        uva = uv.a();
                        uvb = uv.b();
                        uvi = uv.index();
                        #ifdef MY_DEBUG
                        Serial.print(F("UVA = "));
                        Serial.println(uva, 2);
                        Serial.print(F("UVB = "));
                        Serial.println(uvb, 2);
                        Serial.print(F("UV Index = "));
                        Serial.println(uvi, 1);
                        if (uvi != uviOld) {
                        send(uviMsg.set(uvi,2));
                        uviOld = uvi;
                        if (uva != uvaOld) {
                        send(uvaMsg.set(uva,2));
                        uvaOld = uva;
                        if (uvb != uvbOld) {
                        send(uvbMsg.set(uvb,2));
                        uvbOld = uvb;
                        uv.shutdown(); ; // power down veml6075
                        sleep(SLEEP_TIME);
                        • T Offline
                          T Offline
                          tonbor
                          wrote on last edited by tonbor
                          #52
                          This ino is working for me, it has the sleep function to save batteries. The Adafruit en the github/mysensors-> https://github.com/schizobovine/VEML6075 lib gives far to high index with my sensor. Only uv a and uv b declaration is not correct. Uv expect a index 0 till 11, domoticz controller passes a lower figure when it receives a number above 11.
                          12.2k
