  3. nRF5 action!
nRF5 action!
  • NeverDieN
    NeverDieN
    I'm leaning more toward the nRF52 platform over the nRF51, in part for its superior range but also because I'm guessing it will be a little easier for the person who is implementing the OTA sketch uploads to implement it first on an nRF52 (more resources, less constrained).
    • NeverDieN
      NeverDieN
      So, is the speed of the Cortex on an nRF5 already good enough that one can simply emulate an atsha signing component, and thus that part now completely disappears from the BOM?
      • NeverDieN NeverDie
        AnticimexA
        AnticimexA
        Anticimex
        @NeverDie you can run soft signing on any device. It emulates the atsha204a equally well. The performance of the MCU only affects the speed of the calculations, not the quality of the result.
          AnticimexA
          AnticimexA
          Anticimex
          @NeverDie but remember that if you use soft signing it is your own responsibility to protect the hmac key from readout by an attacker with physical access to the device.
          NeverDieN 1 Reply Last reply
          • AnticimexA Anticimex
            NeverDieN
            NeverDieN
            #185
            @Anticimex said in Minimalist SAMD21 TQFP32 Pro Mini:
            Thanks! Good to know. Speaking only for myself, I don't think I'll be losing any sleep over the prospect of an attacker gaining physical access to one of my home devices with the intent of extracting the hmac key. I'm more likely to win a lottery than have that happen--and I don't even play lotteries.
            AnticimexA 1 Reply Last reply
              AnticimexA
              AnticimexA
              Anticimex
              @NeverDie that is probably correct, I just feel a responsibility to inform everyone of any known weaknesses in the security infrastructure ;)
                NeverDieN
                NeverDieN
                @Anticimex
                I don't mean to trivialize it. For commercial applications, the atsha204a would of course make sense.
                But, at least for now, it sounds likely that $2.73 will buy you the hardware for a nice little home wireless node, minus sensors and power supply. That's today's price for a NRF51822-04 MINI that NCA78 linked to above. And, of course, that price will continue to drop. Pretty cool!
                • NeverDieN
                  NeverDieN
                  Which library is most recommended for exploiting the RTC that's on an nRF52832? Likewise, what's the best library for sleeping the nRF52832? Since I have the DK, I'd like to take some current measurements while running some demo code for that. That will establish a baseline for comparing future measurements.
                  d00616D 1 Reply Last reply
                  • NeverDieN
                    NeverDieN
                    #189
                    I just now ordered this:
                    https://www.sparkfun.com/products/13746?_ga=2.39569123.1141912816.1499956888-1087552930.1495048698
                    It's like a regular FTDI, but it can also power your project at 3.3v at up to 600ma! :) Previously I had to make my own hacked FTDI interface to do that. Ordinary 3.3v FTDI's will burn out under the load of, say, an ESP8266, or a 20db Tx power amplified nRF24L01.
                      d00616D
                      d00616D
                      d00616
                      @NeverDie said in Minimalist SAMD21 TQFP32 Pro Mini:
                      Sleeping is implemented by hwSleep(). This function uses one RTC. If you need advanced RTC access, you have to cooperate with this RTC, because the interrupt routine must reset the state registers. On nRF51 the other RTC is used for millis(). The nRF52 has one RTC free.
                      • NeverDieN
                        NeverDieN
                        #191
                        In case anyone else either has, or is thinking of getting, the nRF52832 DK, it looks as though there is indeed a way to use its programmer to program an offboard nRF52832 without desoldering the nRF52832 that's on the DK. Here's the existence proof photo where an 832 DK is being used to program Sparkfun's nRF52832 breakout board over the two SW lines:
                        The caption reads "For faster programming, an nRF52832 Development Kit can be used to program the nRF52832 Breakout Board."
                        I haven't yet found the instructions on how to do it though.
                          @d00616
                          9mmx9mm would be great. However, are you certain? Product description says 15.4mmx15.4mm.
                          Pitty the lack of 32khz crystal, but for a lot of sensor nodes perhaps it won't matter much.
                          I did find this after making my prior post:
                          https://www.aliexpress.com/item/nRF51-M0-Ultra-small-Bluetooth-BLE-Module-4-0-Module-LIS3DH-Support-10-GPIOs/32697055436.html?spm=a2g0s.13010208.99999999.295.t9NHvJ
                          which is allegedly 8.5mmx10.5mm and allegedly does have a 32Khz crystal, but the trade-off is that it's an nRF51832, not an nRF52832.
                          NeverDieN
                          NeverDieN
                          @d00616
                          I'm convinced! I pulled this picture off the FCC website, and, indeed, it is 9x9mm:
                          (https://fccid.io/2AA72-PTR5628)
                          So, thanks for mentioning its size, or else I never would have known!
                            @d00616
                            NeverDieN
                            NeverDieN
                            So, what's the smallest nRF52 module that also includes a 32Khz crystal? I think I might want to standardize as much as possible on a single module rather than juggle a bunch of different ones.
                            d00616D 2 Replies Last reply
                              d00616D
                              d00616D
                              d00616
                              What do you think about creating an table with known modules including integrated hardware, available ports and size?
                              I think, most small modules comes without 32kHz crystal. This is mostly an option. Maybe for the 9x9mm module. But I think the antenna is no good choice for indoor usage.
                              I have a lot of RedBear BLE Nano 2 (18x21mm) modules. It's complete including 32Khz crystal and a 3-13V voltage converter. With 2.54mm pins it's easy to solder.
                              I have asked the manufacturer(cdebyte) of the nice nRF24 and nRF52 modules if it's possible to build an module including the nRF52, an RGB LED, an button and 5V protected inputs with the layout like the popular nRF24 modules plus two optional pins (6/8 IO Ports!). I think such type of nRF52 module makes it easy to migrate to 32 Bit using existing boards or build new boards.
                              • NeverDieN
                                NeverDieN
                                #195
                                I just now noticed that Ebyte also has a storefront on aliexpress.
                                https://cdebyte.aliexpress.com/store/2077046?spm=2114.12010108.0.0.7Yid4a
                                For me, it's much better than ebay, because it includes free e-packet delivery to the US. So, unlike ebay, I will hopefully get their modules much sooner than September! The estimated delivery time from Ebyte if ordered through Aliexpress is 12-20 days. :)
                                https://www.aliexpress.com/store/product/CDEBYTE-E73-2G4M04S-BLE-4-2-5-0-long-distance-100m-2-4GHz-SMD-ARM-Core/2077046_32820692238.html?spm=2114.12010615.0.0.TZClHR
                                [Edit: Also, on Aliexpress, Ebyte gives a coupon for $5 off if you order >$45]
                                Nca78N 1 Reply Last reply
                                  Nca78N
                                  Nca78N
                                  @NeverDie yes noticed their shop only 2 days ago and feeling frustrated now :D
                                  For shipment delay I wouldn't be surprised if they shipped the same way with free option and it would just be a different way to state the delay on the 2 websites...
                                  • Nca78N Nca78
                                    NeverDieN
                                    NeverDieN
                                    @Nca78
                                    We'll soon know. I ordered Ebyte products from both Ebay and Aliexpress, and I'll take note of when each order arrives.
                                      d00616D
                                      d00616D
                                      d00616
                                      wrote on last edited by d00616
                                      #198
                                      I have found the Raytec Modules. http://www.raytac.com/products.php?id=1
                                      The smallest one is the MDBT42V 8,4x6,4x1,5mm with PCB antenna and 80m range in open space.
                                      This module https://www.mtmtech.com.tw/M905.html is 6.5 ✕ 6.5 x 1.1 mm
                                      • d00616D d00616
                                        Nca78N
                                        Nca78N
                                        @d00616 said in Minimalist SAMD21 TQFP32 Pro Mini:
                                        M905 is impressive, but with connectors at the bottom it's impossible to hand solder...
                                        Raytac module is what scalz used for the prototype of his "Aeos" board, pretty small but he didn't look so happy with the range.
                                        • TerrenceT
                                          TerrenceT
                                          Terrence
                                          Guys, when you start using these 832 chips are you going to be programming via Bluetooth or just using the radios in some other way?
