  3. nRF5 action!
nRF5 action!
  • NeverDieN
    NeverDieN
    #381
    Just now did a very quick range test, and the Ebyte nRF52832 module seems roughly comparable to the nRF52 DK for range. i.e. much better than the Adafruit nRF52832 Feather and also much better than the non-amplified nRF24L01+'s. So, whew! What a relief that is. At least for me, that means I won't need to wait for the nRF52840.
    So, now the next question is whether the Ebyte nRF52832 can be made to run in DCDC mode, instead of LDO mode, to make it more suited for battery operation. At the moment, I'm not even sure how big or small a power savings that would equate to. Anyone know?
    d00616D 1 Reply Last reply
    • NeverDieN NeverDie
      d00616D
      d00616D
      d00616
      So, now the next question is whether the Ebyte nRF52832 can be made to run in DCDC mode, instead of LDO mode, to make it more suited for battery operation. However, at the moment, I'm not even sure how big or small a power savings that would equate to. Anyone know?
      There is no DCDC support for ESB radio at the moment. The DCDC mode is only efficient on high current states, like enabled radio and should only enabled in an defined voltage range.
      • T Toyman
        @NeverDie wow!!! Will you write a short tutorial? Is mas erase needed for EVERY time the sketch is uploaded?
        NeverDieN
        NeverDieN
        @Toyman said in nRF5 Bluetooth action!:
        Roger Clark says not. I can't say for sure yet, as I haven't yet tried. I think the answer will probably turn out to be that if you aren't doing anything to specifically protect certain flash memory locations after programming it, then you would only need to do it once to undo and erase whatever came on the chip from the factory.
        • scalzS
          scalzS
          wrote on last edited by scalz
          #384
          @NeverDie
          like said above DCDC needs to be enabled. Then, the mcu will automatically switch between LDO mode (for light loads) and DCDC mode for higher currents loads like when mcu is wake up, or during radio comms etc.. Can be interesting in some cases.
          in datasheet, DCDC mode can divide by two mcu power consumption. Side effects could be -1dB sensitivity, so it's better to filter well by using two inductors (see ref design)
          • d00616D
            d00616D
            d00616
            I have found a simple way to mass erase the MCU. Select "None" as SoftDevice and use the "Burn Bootloader" function. There is an error generated but the device is erased.
            • NeverDieN
              NeverDieN
              #386
              @mtiutiu said in nRF5 Bluetooth action!:
              I'm going to try this one too when I have time wt51822-s4at
              I used your link to order some of those modules just now. They're so small and cheap that they might be nice for simple things.
              With the Ebyte module now working, I'm feeling emboldened again. :)
              mtiutiuM 1 Reply Last reply
              • NeverDieN
                NeverDieN
                Which nRF52832 pins do I use for the mysensors implementation of UART Tx and Rx on the nRF52832? When I looked in Nordic's nRF52832 datasheet (http://infocenter.nordicsemi.com/pdf/nRF52832_PS_v1.3.pdf), I didn't see any pins specifically assigned/reserved for that purpose.
                • scalzS
                  scalzS
                  #388
                  by default nrf52dk is RX(24) and TX(25).
                  for adafruit, i have not installed the board..but you can check in adafruit howto (or in their variant files).
                  Peripherals are not fixed, that's a big advantage vs simple 8bits mcu. You define them when doing your design (sometimes it may need some checks in datasheet, depends on mcu).
                  So, for your ebyte module your options are:
                  • create a new board for the board manager (see variant files) regarding a specific design.
                  • or you don't care of this for the moment, and you can simply use nrf52dk board and use the same mapping.
                  • or, in the same order, use adafruit board and their mapping (or sparkfun board etc.., no matter, just check their board map pictures )
                  d00616D NeverDieN 3 Replies Last reply
                  • scalzS scalz
                    d00616D
                    d00616D
                    d00616
                    @scalz said in nRF5 Bluetooth action!:
                    I working on the fourth option, I publish soon:
                    • Define the pin mapping in your sketch, then its part of your code
                    Like @scalz has written. Place the MCU in your layout and define the pin mapping later. Exceptions are analog pins, comparator pins , NFC pins, reset... The pins are documented in Infocenter: Pin assignments Please look at the "GPIO usage restrictions" chapter too.
                      mtiutiuM
                      mtiutiuM
                      mtiutiu
                      wrote on last edited by mtiutiu
                      #390
                      @NeverDie
                      For the ebyte nrf52832 based modules did you had to wire some external components? Are there some other requirements for it in order to work?
                      Thanks.
                      NeverDieN 1 Reply Last reply
                      • mtiutiuM mtiutiu
                        @NeverDie
                        Thanks.
                        NeverDieN
                        NeverDieN
                        @NeverDie
                        Thanks.
                        For proof of concept purposes, I had just 4 wires connected for programming: PWR, GND, SWDIO, and SWDCLK. After programming for range testing: just PWR and GND. I'll soon be adding UART Tx so that I can also read its serial console output.
                        • scalzS scalz
                          NeverDieN
                          NeverDieN
                          #392
                          @scalz
                          Thanks for the explanation. I had been programming it as a "Generic nRF82832," and I don't know what that mapping is. However, I can just as easily pick one of the alternatives you listed, such as the D.K, to get a predictable pin mapping.
                          @d00616
                          Your idea of having the pin mapping be selectable within the sketch sounds great! A+. I'm really looking forward to that and hope that you can do it soon. It sounds much easier for noobs like me than having to futz about with finding/changing/installing other files, and maybe also making it easier to share with and/or borrow from other makers.
                          • Nca78N
                            Nca78N
                            Not related to Bluetooth but @NeverDie did you also receive small antennas and ipx->sma adapters with your modules ?
                            I received one for each nrf52 and also one for the pa lna nrf24. I was not expecting them as those modules all have a PCB antenna and ipx is just an option.
                            • Nca78N Nca78
                              NeverDieN
                              NeverDieN
                              @Nca78 said in nRF5 Bluetooth action!:
                              Nope.
                              • scalzS scalz
                                NeverDieN
                                NeverDieN
                                #395
                                Hmm.. Where is that defined exactly? I just now tried hooking the Tx(25) of an actual nrf52DK to the Rx pin of a FTDI connector, and GND to GND, but I'm not seeing any output from the nrf52DK, even though I should be. I'm assuming that by 25 you're referring to PO.25 and not pin 25 on the chip?
                                • NeverDieN
                                  NeverDieN
                                  #396
                                  I googled up this diagram:
                                  Looks as though TX is maybe P0.06. I'll try that....
                                  • NeverDieN
                                    NeverDieN
                                    Confirmed: Pin P0.06 works as Uarte TX on the nRF52 DK. :)
                                    • scalzS
                                      scalzS
                                      #398
                                      @NeverDie yes, you're right :+1: sorry i misread it :blush:
                                      Have fun!
                                      • NeverDieN
                                        NeverDieN
                                        As final confirmation I did re-program the Ebyte module as an nRF52 DK, then connected its P0.06 to the FTDI RX, and, voilà , it worked as expected. @scalz Thanks for the idea! :)
                                        One small caveat: On the Ebyte module, P0.06 doesn't appear on the silkscreen (there's a typo where it's shown as P0.07 instead, resulting in there being two P0.07's on the silkscreen), so just pick the most obvious pin based on the numerical progression (or else consult the datasheet), and it will work.
                                        • NeverDieN
                                          NeverDieN
                                          #400
                                          In lieu of my breakout board, which hasn't yet arrived, I've been attaching wires directly to the module so that I can do more than just sit and wait for the BoB delivery. I'm now doing it this way:
                                          and although crude it's working much better than just soldering the wire to the module with no mechanical support. Doing it the way pictured, the connections stay connected and don't break loose. :) Ironically, by the time my breakout boards finally do arrive, I may have already learned everything I needed them for.
                                          I am curious: how are the rest of you handling this issue?
                                          [Edit: One other alternative: once my 1.27mm pitch generic protoboards arrive, I expect they'll offer up cleaner connection possibilities. At the moment, I'm also waiting for them to arrive from Aliexpress....]
                                          Nca78N 1 Reply Last reply
