  3. nRF5 action!
nRF5 action!
    I'm going to try this one too when I have time wt51822-s4at
    I used your link to order some of those modules just now. They're so small and cheap that they might be nice for simple things.
    With the Ebyte module now working, I'm feeling emboldened again. :)
    mtiutiuM
    mtiutiuM
    mtiutiu
    #390
    For the ebyte nrf52832 based modules did you had to wire some external components? Are there some other requirements for it in order to work?
    • mtiutiuM mtiutiu
      For proof of concept purposes, I had just 4 wires connected for programming: PWR, GND, SWDIO, and SWDCLK. After programming for range testing: just PWR and GND. I'll soon be adding UART Tx so that I can also read its serial console output.
      • scalzS scalz
        by default nrf52dk is RX(24) and TX(25).
        for adafruit, i have not installed the board..but you can check in adafruit howto (or in their variant files).
        Peripherals are not fixed, that's a big advantage vs simple 8bits mcu. You define them when doing your design (sometimes it may need some checks in datasheet, depends on mcu).
        So, for your ebyte module your options are:
        • create a new board for the board manager (see variant files) regarding a specific design.
        • or you don't care of this for the moment, and you can simply use nrf52dk board and use the same mapping.
        • or, in the same order, use adafruit board and their mapping (or sparkfun board etc.., no matter, just check their board map pictures )
        #392
        @scalz
        Thanks for the explanation. I had been programming it as a "Generic nRF82832," and I don't know what that mapping is. However, I can just as easily pick one of the alternatives you listed, such as the D.K, to get a predictable pin mapping.
        @d00616
        Your idea of having the pin mapping be selectable within the sketch sounds great! A+. I'm really looking forward to that and hope that you can do it soon. It sounds much easier for noobs like me than having to futz about with finding/changing/installing other files, and maybe also making it easier to share with and/or borrow from other makers.
        d00616D 1 Reply Last reply
        • Nca78N
          Not related to Bluetooth but @NeverDie did you also receive small antennas and ipx->sma adapters with your modules ?
          I received one for each nrf52 and also one for the pa lna nrf24. I was not expecting them as those modules all have a PCB antenna and ipx is just an option.
          • Nca78N Nca78
            Nope.
            • scalzS scalz
              #395
              Hmm.. Where is that defined exactly? I just now tried hooking the Tx(25) of an actual nrf52DK to the Rx pin of a FTDI connector, and GND to GND, but I'm not seeing any output from the nrf52DK, even though I should be. I'm assuming that by 25 you're referring to PO.25 and not pin 25 on the chip?
                #396
                I googled up this diagram:
                Looks as though TX is maybe P0.06. I'll try that....
                  Confirmed: Pin P0.06 works as Uarte TX on the nRF52 DK. :)
                    #398
                    @NeverDie yes, you're right :+1: sorry i misread it :blush:
                    Have fun!
                      As final confirmation I did re-program the Ebyte module as an nRF52 DK, then connected its P0.06 to the FTDI RX, and, voilà , it worked as expected. @scalz Thanks for the idea! :)
                      One small caveat: On the Ebyte module, P0.06 doesn't appear on the silkscreen (there's a typo where it's shown as P0.07 instead, resulting in there being two P0.07's on the silkscreen), so just pick the most obvious pin based on the numerical progression (or else consult the datasheet), and it will work.
                        #400
                        In lieu of my breakout board, which hasn't yet arrived, I've been attaching wires directly to the module so that I can do more than just sit and wait for the BoB delivery. I'm now doing it this way:
                        and although crude it's working much better than just soldering the wire to the module with no mechanical support. Doing it the way pictured, the connections stay connected and don't break loose. :) Ironically, by the time my breakout boards finally do arrive, I may have already learned everything I needed them for.
                        I am curious: how are the rest of you handling this issue?
                        [Edit: One other alternative: once my 1.27mm pitch generic protoboards arrive, I expect they'll offer up cleaner connection possibilities. At the moment, I'm also waiting for them to arrive from Aliexpress....]
                        Nca78N 1 Reply Last reply
                          @scalz
                          @d00616
                          d00616D
                          d00616D
                          d00616
                          With merging this pull request the feature should be available: https://github.com/mysensors/ArduinoBoards/pull/13
                          Documentation can be found at https://github.com/mysensors/ArduinoHwNRF5
                          • d00616D d00616
                            d00616D
                            d00616D
                            d00616
                            Merged. Have fun with board definition in your sketch.
                              Not many solutions, I soldered wires directly to the modules too, I used thin&cheap wires from aliexpress. They are very convenient for this, easy to solder and very soft so not having any constraint on the solder joints when you manipulate them. Then I put module on the side of board with double sided tape and soldered other ends of the wires to a connector.
                              Then I flip everything and only look at the beautiful side of things :D
                              • d00616D d00616
                                #404
                                Thanks! By being "merged," does that mean it is now in the regular MySensors development release, and so I should reload a fresh copy of the MySensors development library?
                                Also, is this the way I should enable P0.21 as nReset (to enable hardware resets on P0.21), or should I instead be writing 0xFFFF directly to both the PSELRESET[0] and PSELRESET[1] registers to enable that?
                                mfalkviddM d00616D 2 Replies Last reply
                                    d00616D
                                    d00616D
                                    d00616
                                    The Board definition is independed from MySensors core living at https://github.com/mysensors/ArduinoBoards You have to follow the instructions, then you can install the MySensors nRF5 Boards via Arduino Board Manager.
                                    Look into the Tools menu. For nRF52 MCU is a "Reset" menu. Switch it to "Enable"
                                    • d00616D d00616
                                      #407
                                      @d00616
                                      I got the pin mapping to work, but setting reset enable through the tool menu seems to have no effect. I subsequently drive P0.21 low (all the way to GND even), but no reset happens. Am I doing it wrong? Anyone gotten it to work?
                                        @d00616
                                        #408
                                        I also tried adding a 10K pullup resistor, and no change.
                                        At the moment I'm unfamiliar with the nRF52 API. What would the code be to set both those reset registers to 0xFFFF? That by itself should enable the reset on P0.21. I could try inserting it into the demo script and see if reset then works.
                                          #409
                                          I guess it wouldn't be that simple, because I just now read that it requires a system reset after writing to those registers: https://devzone.nordicsemi.com/question/157603/can-i-enable-and-disable-nrf52832-reset-pin-when-code-is-running/ for it to take effect.
