  3. nRF5 action!
nRF5 action!
    @NeverDie nice results! What kind of overcharge protection are you using?
    NeverDieN
    NeverDieN
    @mfalkvidd said in nRF5 Bluetooth action!:
    A 2.7v LDO. Very low quiescent current of just 1ua.
    • NeverDieN NeverDie
      @NeverDie thanks. My first supercap is on the way so I'm looking forward to build something with it.
      • rmtuckerR rmtucker
        @NeverDie
        yes but it would take 4-6weeks and i was impatient so thought i would start with what i could get.
        But it seems it does not work on either looking at some of the other issues on sandeeps github.
        NeverDieN
        NeverDieN
        @rmtucker
        I notice someone on AliExpress is selling a similar concept for the nRF52832 to what you're using for the nRF51:
        https://www.aliexpress.com/item/NRF52832-Development-Board-NRF52832-Test-Board-Bluetooth-BLE4-2/32824948546.html?spm=2114.search0104.3.1.YoEIHi&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10068_10130_5430020_5410020_10307_10137_10060_10155_10154_5370011_10056_10055_10054_10059_100031_10099_5400020_10103_10102_10052_10053_10142_10107_10050_10051_5380020_5390020_10084_10083_10119_10080_10082_10081_10178_10110_10111_10112_10113_10114_10312_10313_10314_10315_10078_10079_10073_10120_5420011,searchweb201603_19,ppcSwitch_4&btsid=abd93cae-a709-47f9-989d-0c52b4cde846&algo_expid=450d3875-3c65-41c4-99a8-0a2b5eb4479e-0&algo_pvid=450d3875-3c65-41c4-99a8-0a2b5eb4479e&transAbTest=ae803_3
        • NeverDieN
          NeverDieN
          I did another sleep current measurement, this time on a Ebyte module that I had mounted to one of my breakout boards. The sleep current measured between 8ua and 9ua. However, it would jump considerably higher depending on whether I was moving or otherwise close to it. I got the lower measurements by positioning myself about 6 feet away (further than that and it gets hard to read the multimeter that's connected to the uCurrent Gold). I've never seen this kind of behavior before in anything other than the nrf52832 boards. Very curious. They're acting almost like proximity detectors. I have no idea what to make of it, but I thought I'd report it in case anyone else here is doing measurements too.
          Also, I'm going to avoid exposing the IO pins to voltages that approach Vcc in magnitude. Despite what the datasheet says, they don't seem to handle it well.
          rmtuckerR 1 Reply Last reply
          • M Mike_Lemo
            Does anybody know why the function tone() doesn't work for the nrf52?
            d00616D
            d00616D
            d00616
            @Mike_Lemo said in nRF5 Bluetooth action!:
            tone() and other things like NFC are implemented with the new Arduino Primo board. There is no MySensors support at the moment because the Primo comes with the SoftDevice which doesn't allow accessing the complete hardware without using the SoftDevice API, which is not implemented.
              rmtuckerR
              rmtuckerR
              rmtucker
              wrote on last edited by rmtucker
              #566
              @NeverDie
              What you using for pcb design?
              I would like to design something for the waveshare core board to plug into similar to what you just designed for the nrf52832 modules to adapt to 2.54mm pitch headers.
              0_1502221830970_upload-3b01b675-529e-4554-8142-f232a7d3e827
              Similar to what you did here but with two sockets on top for the waveshare board.
              https://www.openhardware.io/view/436/nRF52832-Breakout-Board
              NeverDieN T 2 Replies Last reply
                @NeverDie
                NeverDieN
                NeverDieN
                #567
                @rmtucker said in nRF5 Bluetooth action!:
                Diptrace.
                Very easy to learn. Watch this tutorial series, and in a little more than an hour you'll know enough to use it for doing real work: https://www.youtube.com/playlist?list=PLWy-YwxbAu8EkNv6iMsfLeH6Yahcwejwx
                • NeverDieN
                  NeverDieN
                  However, if you have the time to invest, you might want to learn KiCAD instead (http://kicad-pcb.org/). It's open source and free.
                  My only real concern about Diptrace is that sharing source files is very, very difficult. Eagle is much better for that, it seems. I'm guessing KiCAD is also good with that, but I can't say that I know for sure.
                  • Nca78N
                    Nca78N
                    If I was starting, it would be with Kicad.
                    NeverDieN 1 Reply Last reply
                    • Nca78N Nca78
                      NeverDieN
                      NeverDieN
                      @Nca78
                      Is it easy to share source files in KiCAD?
                      Nca78N 1 Reply Last reply
                        @Nca78
                        Nca78N
                        Nca78N
                        @NeverDie in KiCAD format, I suppose :D But even if it's not easy at least anyone can download Kicad and open them to at have a look without beeing block if you have more than two layers, or too big board.
                        I'm still using Eagle at the moment, it's the most common software but the changes made in what you can do with the free licence + limitation of PCB size are annoying. At some point I'll have to be strong and make the move to KiCAD...
                          @NeverDie
                          Toyman
                          @rmtucker
                          before you design your own board:
                          https://ru.aliexpress.com/item/Free-shipping-1pcs-NRF51822-development-board-ble4-0-Bluetooth-module-development-board-2-4G-low-power/32596438101.html?spm=a2g0v.search0204.3.73.ZtUmwF&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10068_10209_10307_10301_10137_10060_439_10155_10154_10056_10055_10054_10059_100031_10099_10103_10102_10169_10052_10053_10142_10107_10050_10051_10084_10083_10080_10082_10081_10110_10111_10112_10113_10114_10311_10312_10313_10314_10315_10078_10079_10210_10073_10125,searchweb201603_19,ppcSwitch_7_ppcChannel&btsid=df5cc403-0dac-4fab-842a-646caeb0e554&algo_expid=230ba6b9-0318-4b2a-b991-a91aafb9b85f-9&algo_pvid=230ba6b9-0318-4b2a-b991-a91aafb9b85f
                          • T Toyman
                            @rmtucker
                            rmtuckerR
                            rmtuckerR
                            rmtucker
                            @Toyman
                            Yes i am already running that board at the moment.
                            But that board consumes around 140uA when sleeping.
                            It must be the extra electronics like the regulator and uart.
                            even when feeding the core board with 3.3v directly.
                            When the core board is on its own it only measures 5uA when sleeping.
                            • NeverDieN
                              NeverDieN
                              This nRF52832 module looks to be pretty small, and it has both oscillators on it.
                              It appears that it forces you to use an external antenna though.
                              https://www.aliexpress.com/item/NRF52832-Bluetooth-4-2-Module-BLE-Low-Power-Bluetooth-External-Antenna/32825850305.html?spm=2114.search0104.3.2.Ehd1fQ&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10130_10068_5400011_10307_10137_10060_10155_10154_5370011_10056_10055_10054_10059_5380011_100031_10099_10103_10102_5410017_5430017_10052_10053_10142_10107_10050_10051_10084_10083_10119_10080_10082_10081_10178_10110_10111_10112_5390011_10113_10114_10312_10313_10314_10315_10078_10079_5420017_10073_10120,searchweb201603_2,ppcSwitch_4&btsid=2d85e0d1-50d7-434b-b096-286b0eb3b893&algo_expid=ef23bd47-74f5-4531-93b6-4883f068a6b4-0&algo_pvid=ef23bd47-74f5-4531-93b6-4883f068a6b4&transAbTest=ae803_3
                              • T
                                Toyman
                                Help needed!! I am trying to program nrf51822 with Black Magic Probe , but BMP is not recognized by Arduino IDE.
                                I can do everything in gdb, e.g. do mass erase, upload soft device etc, but BMP is simply not listed in programmers' list in Arduino IDE so I can't upload sketches.
                                • T Toyman
                                  rmtuckerR
                                  rmtuckerR
                                  rmtucker
                                  #576
                                  Could anyone tell me why the waveshare board is pulling 140uA when sleeping with everything unpugged including the usb and all the header jumpers so only 3.3v and ground fed to the header pins so not using the regulator etc.
                                  I have attached a link to the schematic hoping some circuit wiz might be able to explain.
                                  link text
                                  If i unplug the core board and just power that with 3.3v and gnd it only uses 5uA when sleeping.
                                  mtiutiuM 1 Reply Last reply
                                    link text
                                    mtiutiuM
                                    mtiutiuM
                                    mtiutiu
                                    @rmtucker
                                    Even if you're not using the regulator and the CP2102 usb-serial converter there are some leakage currents which are caused by the output stages of those IC's. For example the output stage of the voltage regulator can draw some even if it's not powered. The CP2102 can draw also through the TXD1/RXD1/SUSPEND1 LEDs and the associated GPIO pins P0.11, P0.09, etc.
                                    So to prove and test that the above it's true you need to:
                                    1. Desolder the RT9193-33 or at least its output pin(Vout pin 5)
                                    2. Desolder R6, R7, R10
                                    This is what I can conclude by looking at that schematic. Any other opinions?
                                    • mtiutiuM mtiutiu
                                      @rmtucker
                                      NeverDieN
                                      NeverDieN
                                      #578
                                      @mtiutiu said in nRF5 Bluetooth action!:
                                      Any other opinions?
                                      Yes. If it really matters that much, RMTucker should buy or make a uCurrent Gold. Otherwise, he'll find hmself chasing phantoms. I have a Fluke 87V, and I don't trust it to do these types of measurements (I've tried, and the results are just wrong when compared to a uCurrent Gold). I would trust a crappy multimeter even less. Been there and tried that already.
                                      Just my two cents.
                                      NeverDieN Nca78N 2 Replies Last reply
                                        Any other opinions?
                                        Just my two cents.
                                        NeverDieN
                                        NeverDieN
                                        #579
                                        BTW, uCurrent Gold is open source. I have an original, but you can buy clones. For instance, LowPowerLab sells a clone. You might get it faster than ordering from Australia.... unless you live in Australia. Dave Jones did a video for me once, and so I thought he deserved the profit instead of somebody else. :)
                                          Any other opinions?
                                          Just my two cents.
                                          Nca78N
                                          Nca78N
                                          Any other opinions?
                                          Just my two cents.
                                          It just depends on the burden voltage, no ? It's proportional to current in the circuit so in sleep mode when measuring around 10 uA it should be negligible.
                                          Anyway I measure when powered with 3.3V so I'm sure what I measure is higher than what I will get in reality when circuit is powered with a 3V battery.
