  3. nRF5 action!
nRF5 action!
  • Nca78N Nca78
    @ahmedadelhosni said in nRF5 Bluetooth action!:
    @Uhrheber Great. Thanks for the help.
    So if I understand well. If I have a TIVA board like TM4C123G Launchpad and it is ARM Mx also, then I can use it to program my nRF ?
    This is the datasheet for the board : http://www.ti.com/lit/ug/spmu296/spmu296.pdf
    I searched and found those links describing how to use the Launchad but I am not sure whether this will work for nRF also or not.
    http://processors.wiki.ti.com/index.php/Stellaris_LM4F120_LaunchPad_Debug_How_To
    http://ucsolutions.blogspot.com.eg/2014/08/ti-launchpad-as-external-debugger-with.html
    Thanks.
    I think it's a question of the licence of the programmer that is on your board.
    For example the J-Link version on the NRF52 DK is only allowed to program NRF52 and NRF51 chips. It's logic because the NRF52DK is just over 30$ while a J-Link programmer is x00$.
    You have pins SWDIO and SWDCLK on pins PC0 and PC1 of your board so just try it and you will know :)
    ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    wrote on last edited by ahmedadelhosni
    #1221
    @Nca78 Yeah actually this makes sense. I forgot about the licence thing. Actually I didn't bug the boards and I want to get everything at once without missing anything. I am in a hurry :D
    it is strange that this clone can do the work as @Uhrheber mentioned.
    http://s.click.aliexpress.com/deep_link.htm?dl_target_url=https%3A%2F%2Fwww.aliexpress.com%2Fitem%2FHot-Sale-1PCS-ST-LINK-Stlink-ST-Link-V2-Mini-STM8-STM32-Simulator-Download-Programmer-Programming%2F32343514985.html%3Fspm%3D2114.search0104.3.26.LR8eH0%26ws_ab_test%3Dsearchweb0_0&aff_short_key=e2Vzr3v
    • T
      Toyman
      Guys, your best bet is to reflash STM32 Bluepill into BlackMagicProbe.
      It's awesome!
      https://medium.com/@paramaggarwal/converting-an-stm32f103-board-to-a-black-magic-probe-c013cf2cc38c
      • NeverDieN NeverDie
        Anyhow, the basic question remains and boils down to this: Can I have both
            // Enable interrupt
          NVIC_SetPriority(LPCOMP_IRQn, 15);
          NVIC_ClearPendingIRQ(LPCOMP_IRQn);
          NVIC_EnableIRQ(LPCOMP_IRQn);
        AND an equivalent incantation for the RTC both active at the same time? Or am I forced into having it be just one or the other?
        NeverDieN
        NeverDieN
            // Enable interrupt
        @d00616 Any thoughts or comments regarding this?
        d00616D 1 Reply Last reply
              // Enable interrupt
          d00616D
          d00616D
          d00616
          Sorry, I can't help here. Maybe, the interrupt priority can be used only once and you have to use another priority for RTC or LPCOMP.
          • NeverDieN
            NeverDieN
            I tried out the Fanstel BT832X (i.e. nRF52832 with PA and LNA) today:
            Good news:
            1. Even without the PA turned on, the range seems a lot better than if transmitting from an Ebyte module.
            2. Also, I've confirmed that it comes with DCDC built-in.
            3. With the PA turned on, the range is comparable to, and perhaps even better than, the RFaxis I reviewed earlier in this thread.
            With the PA turned on, it consumes about 250ma.
            • NeverDieN
              NeverDieN
              #1226
              @d00616 I hooked up the Fanstel BT832A. Although it appeared to flash and verify correctly, I couldn't get it to do anything--not even blink. Is there any chance that it's downsized flash/memory has something to do with it? "Flash/RAM memories in BT832 are 512KB/64KB. They are 192KB/24KB in BT832A." So, as an experiment, I hooked up a BT832 in its place on the same board, and it's able to transmit and blink just fine. In total, the only differences between the two are:
              1. Cortex M4F in BT832 has hardware DSP and floating point instructions. Cortex M4 in BT832A has hardware DSP instructions but it does not have floating point unit to support hardware instruction.
              2. Flash/RAM memories in BT832 are 512KB/64KB. They are 192KB/24KB in BT832A.
              3. BT832 has NFC tag interface. BT832A does not have NFC tag
                interface.
              I think we can rule out #3. So, if it isn't #2, then is perhaps #1 a factor? I wouldn't think so.
              The solder connections seemed correct. I suppose it's possible I simply got a bad module, but I'm doubtful that's it.
              Here's a photo of it installed on a BT832X board, which is pin-for-pin compatible:
                  interface.
                d00616D
                d00616D
                d00616
                I think, you have to do more things:
                1. Change compiler attributes to disable FPU support
                2. Change the memory layout in linker scripts. Look into boards definition. Linker scripts are placed under ./cores/nRF5/SDK/components/toolchain/gcc/ The SDK14 has scripts supporting the nrf52810
                3. The SDK14 has an dedicated startup code (gcc_startup_nrf52810.S), I don't know if this relevant for arduino-nrf5
                I think there is more to do than compile the code. I think the SDK code for arduino-nrf5 must be updated to SDK 14, then a nre MCU must be defined.
                I have compared the startup code. The difference is in the interrupt vector. It should work with the NRF52832 startup code, but the linker script must be changed.
                NeverDieN 1 Reply Last reply
                • d00616D d00616
                  NeverDieN
                  NeverDieN
                  @d00616 Also, at least so far, I haven't been able to get the Fanstel modules to receive anything. At first I thought it must be an LNA thing, but I tried it just now on a Fanstel module without LNA, and although it can transmit and blink just fine, the regular receive code isn't working. Any theories on that?
                    d00616D
                    d00616D
                    d00616
                    wrote on last edited by d00616
                    #1229
                    I think this could be the memory layout -> linker script. My try to port Arduino to nrf51 in 2014 is failed at the same state. Blink was ok. Using something with memory are failed. The reason was a wrong linker script. At this time Nordic hasen't released (L)GPG compatible scripts.
                    Edit: I think it's possible to add the 82810 to https://github.com/mysensors/ArduinoHwNRF5 by changing the board definition and add the missing linker script into the variant folder.
                    • d00616D d00616
                      NeverDieN
                      NeverDieN
                      @d00616 I'm puzzled then. The module that you are using (https://www.aliexpress.com/item/NRF52832-Mini-Development-Board-Gold-Core-board-Wireless-Bluetooth-Transceiver-Module/32798618219.html?spm=2114.search0204.3.1.BEAy98&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_5700015_5620015_10130_10068_10344_10345_10547_10342_10546_10343_10340_10341_10548_10545_10541_10307_5640015_10060_10155_10154_10056_10055_10539_10538_5370015_10537_10536_10059_10534_10533_100031_10103_10102_10142_10107_10324_10325_5760015_10084_10083_10178_5750015_10312_10313_10314_10073_5630015,searchweb201603_30,ppcSwitch_4_ppcChannel&btsid=011daf01-f75a-4448-9202-405ef9dcacd9&algo_expid=acb605b8-ed11-4497-8757-d77cd4b3550b-0&algo_pvid=acb605b8-ed11-4497-8757-d77cd4b3550b) allegedly comes with 512k flash and 64k ram. So, what, if any, difference is there between that and the Fanstel module with the same amount of flash and ram?
                      • NeverDieN
                        NeverDieN
                        #1231
                        OK, I need to confirm it, but I have a theory now that the Fanstel modules don't have 32K clock crystals in them. That would explain why that have pinouts for XTAL1 and XTAL2. It might also be hanging my code, which assumes there is a clock crystal and tries to turn it on. My using pin P0.02 to control the LED might be a deadly brew that causes the hang. I'll post a follow-up if that's what turns out to be the actual root of what superficially seemed like an "Rx problem."
                        • NeverDieN
                          NeverDieN
                          #1232
                          It's confirmed. Son of a gun, they don't have the 32K clock crystal on the module. On the datasheet, it says that for battery operation, "We suggest adding a 32.768 kHz crystal and 2 capacitors as shown in the upper left corner of the evaluation board schematics."
                          I'll add pads for it on the breakout board.
                            NeverDieN
                            NeverDieN
                            #1233
                            Correction: Use of P0.02 to control the LED shouldn't be a problem, as it corresponds to AIN0 and isn't involved in XTAL. Therefore, I edited the original post to strike-through this sentence.
                            • NeverDieN
                              NeverDieN
                              #1234
                              Good news! Switching over to the RC oscillator totally fixed the problem. Both the Fanstel BT832 and BT832X now receive just fine. :)
                              • NeverDieN
                                NeverDieN
                                #1235
                                In fact, both the Fanstel BT832 and the BT832X (with no LNA turned on) have much better receive range than an Ebyte module. They are head and shoulders better. In turn the BT832X (again, even with no LNA turned on) has a noticeably better receive range than the BT832.
                                So, at this point, I'm sold on the Fanstel modules for the most common uses. The Fanstel modules also have a smaller footprint than the Ebyte modules. The Ebyte modules might be better for those cases where you need a lot of easily accessible pins to do something, but that's about it I think.
                                Nca78N T 2 Replies Last reply
                                  Nca78N
                                  Nca78N
                                  Now we need to convince Fanstel to find another shipping method outside the US :D
                                  JokgiJ 1 Reply Last reply
                                    Toyman
                                    @NeverDie it looks like we found an ideal gateway.
                                    What about the code they provide to activate PA+LNA?
                                    Can it be used in mysensors?
                                    • NeverDieN
                                      NeverDieN
                                      I tried out the sub-dime sized BC832 on a quick port of the BC832X breakout board:
                                      What I'm finding is that the Rx range for the BC832 is about the same as for the Ebyte nRF52832 module: I'm hard pressed to tell which is better than the other. The BC832 is nonetheless impressive, given how small its antenna is relative to the Ebyte antenna.
                                      • T Toyman
                                        NeverDieN
                                        NeverDieN
                                        #1239
                                        @Toyman said in nRF5 Bluetooth action!:
                                        Agreed. :)
                                        I only extracted the needed info from their code to make it work. It works just fine with mysensors. For instance, here's mysensors code to activate the PA:
                                        #define PA_PIN 17
                                        #define CPS_PIN 6
                                        #define LNA_PIN 19
                                          myNrf5_pinMode(CPS_PIN,OUTPUT_H0H1);
                                          digitalWrite(CPS_PIN,HIGH);  //disable.  Active LOW
                                          //while (!(digitalRead(CPS_PIN)==HIGH)) {} //wait until confirmed
                                          myNrf5_pinMode(LNA_PIN,OUTPUT_H0H1);
                                          digitalWrite(PA_PIN,LOW);  //disable.  active HIGH
                                          //while (!(digitalRead(LNA_PIN)==LOW)) {} //wait until confirmed
                                          myNrf5_pinMode(PA_PIN,OUTPUT_H0H1);
                                          digitalWrite(PA_PIN,HIGH);  //enable.  active HIGH
                                          //while (!(digitalRead(PA_PIN)==HIGH)) {} //wait until confirmed
                                          //myNrf5_pinMode(CPS_PIN,OUTPUT_H0H1);
                                          digitalWrite(CPS_PIN,LOW);  //enable.  active LOW
                                          //while (!(digitalRead(CPS_PIN)==LOW)) {} //wait until confirmed
                                        I've tested it, and it works. From my testing it appears that the pins are write-only (which is why the while loops are now commented out).
                                        • Nca78N Nca78
                                          JokgiJ
                                          JokgiJ
                                          Jokgi
                                          wrote on last edited by Jokgi
                                          #1240
                                          @Nca78 How about sending a email to the company and ask if there is a distributor / Rep in your area?
                                          Dr. Yuan Fan
                                          Fanstel Corp.
                                          Trusted Name Since 1990
                                          7466 E. Monte Cristo Ave., Scottsdale AZ 85260 USA
                                          Tel. 1480-948-4928 x101;
                                          email: yfan@fanstel.com http://www.fanstel.com
