  3. nRF5 action!
nRF5 action!
  • mr_redM mr_red
    @Calvin-Khung Hi Calvin, I read your comments here and on Stackoverflow/exchange. I honestly think that you dont have the right skills to do this. The exploited vulnerability in the blog is quite sofisticated. I think you have to start getting your debugger configured correctly. Your say you have an st-link v2 which lets me to belive you have a cheap chinese clone.
    This clone has not all debugging features included, as you might saw in my posts earlier. You are much better of with a Black magic probe or a J-Link.
    Have you got a halted NRF51 yet?
    Calvin KhungC
    Calvin KhungC
    Calvin Khung
    @mr_red If it's a clone then that would probably explain why it wasn't successful. I've read a thing or two about the BMP. Do you think its a good idea to convert the cheap ST-Link V2 to a BMP? Found a blog about it.
    http://blog.linuxbits.io/2016/02/15/cheap-chinese-st-link-v-2-programmer-converted-to-black-magic-probe-debugger/
    J-Link is way too expensive so I won't even bother considering it. And I don't quite get what you mean but yeah, I did halt it during the process.
    monteM JokgiJ 2 Replies Last reply
    • Calvin KhungC Calvin Khung
      monteM
      monteM
      monte
      @Calvin-Khung you can convert st-link clone into BMP. The only problem would be if there is not enough flash on the chip. If I remember correctly, BMP firmware needs more than 64kb. But you will know for sure, if you'll try.
      • Calvin KhungC
        Calvin KhungC
        Calvin Khung
        @monte For sure, I'll give it a try. Thanks for helping out guys!
        • JokgiJ
          JokgiJ
          Jokgi
          Calvin, You cam buy a Nordic Development kit for about $50 dollars or less. It has the J-Link OB device on it for swd programming and debugging.
          Nca78N 1 Reply Last reply
          • JokgiJ Jokgi
            Nca78N
            Nca78N
            @Jokgi said in nRF5 action!:
            Best solution imho, never had a problem with it programming the nrf5 modules, just drag & drop from Windows file explorer.
              JokgiJ
              JokgiJ
              Jokgi
              wrote on last edited by Jokgi
              #1826
              @Calvin-Khung
              Jokgi
              Jokgi about 2 hours ago
              Calvin, You can buy a Nordic Development kit for about $50 dollars or less. It has the J-Link OB device on it for SWD programming and debugging.
              • NeverDieN
                NeverDieN
                I agree with Jokgi, but nonetheless for anyone interested in the Black Magic Probe alternative, here's an article on how to make a BMP from a $2 Blue Pill board:
                https://medium.com/@paramaggarwal/converting-an-stm32f103-board-to-a-black-magic-probe-c013cf2cc38c
                • orhanyorO
                  orhanyorO
                  orhanyor
                  i use $10 replica Jlink from aliexpress works ok with the latest firmware without an issue. i use it just to flash bootloaders to cortex m0-m4 and nrf52's but it should work for any task that a genuine jlink can do.
                  Calvin KhungC 1 Reply Last reply
                  • J
                    J
                    Jon Raymond
                    There also is an "Education" version of the Jlink for $20 if you want an official one with access to nRF Command Line Tools.
                    JokgiJ 1 Reply Last reply
                    • J Jon Raymond
                      JokgiJ
                      JokgiJ
                      Jokgi
                      @Jon-Raymond Correct. It is a nice product for the price and the intended user. As Jon mentioned, you can use the command line tools as well as nRFconnect and also has direct hooks into the Segger Embedded Studio which is a fully functional IDE / compiler/ Debugger and is free when used with Nordic Semi devices.
                      Plus there is no license conflict as there is when using one of these cheap overseas j-link knock offs. (Which could "break / brick" anytime doing a "official" Segger update on these clones.)
                      • orhanyorO orhanyor
                        Calvin KhungC
                        Calvin KhungC
                        Calvin Khung
                        @orhanyor good to hear! i ordered that as well since just to try it out in hope that it would work. now that you've said that, maybe i shouldn't worry too much then.
                        orhanyorO 1 Reply Last reply
                          orhanyorO
                          orhanyorO
                          orhanyor
                          @Calvin-Khung Well im actually surprised that it still works because people are reporting they might stop working after a firmware update so you might wanna hold back on that other than that it works surprisingly well. i bought another as my back up plan which im expecting it in these days. its abit different than the one i have. this one is much cheaper and looks like jlink edu mini rather than a normal j link with a black box.. i ll see if it works when i receive it, here it is.
                          https://www.aliexpress.com/item/32669702891.html?spm=a2g0s.9042311.0.0.27424c4d4Fx7g9
                          • orhanyorO
                            orhanyorO
                            orhanyor
                            i just received this little thing, tested it with atmel studio just to flash some M4 boards and it worked nicely. i wanted to update its firmware via jlink(playing with fire) but it didnt let me saying its up to date so its all ok i guess. it only has 4 pins 3v, gnd, swdio, swclk. for $2.50 in total with shipping its a steal :)
                              J
                              J
                              Jon Raymond
                              @orhanyor Is it just me or does that micro usb connector look like it should be mounted upside down so it actually nests into the cutout in the board below it? Of course the pinout would be mirrored but it seems like a layout issue that they just ran with.
                              • orhanyorO
                                orhanyorO
                                orhanyor
                                usb connector is actually nested as far as i can see but it dips 1-2 mm only. weird but it works so its all good :)
                                • Calvin KhungC
                                  Calvin KhungC
                                  Calvin Khung
                                  wrote on last edited by Calvin Khung
                                  #1836
                                  This post is deleted!
                                  • nagelcN
                                    nagelcN
                                    nagelc
                                    Does anyone have any experience with the minew modules?
                                    https://www.aliexpress.com/item/4000111771020.html?spm=a2g0o.productlist.0.0.355350384gOEfO&algo_pvid=0304e5fd-2ee1-4b3c-8324-d7457ed54a60&algo_expid=0304e5fd-2ee1-4b3c-8324-d7457ed54a60-3&btsid=0ab50f4415945033578573060e726c&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
                                    I've been using the Fanstel BT832 series with success, but I have been looking at this one to get a few more hand-solderable GPIOs.
                                    nagelcN 1 Reply Last reply
                                    • nagelcN nagelc
                                      nagelcN
                                      nagelcN
                                      nagelc
                                      I received a few of the Minew MS50SFB modules. They appear to need unlocking similar to the E73 modules. I have tried using instructions as for E73, but no luck so far with either
                                      gdb
                                      https://forum.mysensors.org/topic/9266/guide-nrf5-nrf51-nrf52-for-beginners/54?_=1598203470928
                                      acts like it is working, but doesn't really unlock the module.
                                      or J-link
                                      https://forum.mysensors.org/topic/9266/guide-nrf5-nrf51-nrf52-for-beginners/33?_=1598203470928
                                      returns error from nrfjprob. In J-Link application can not connect
                                      NeverDieN Nca78N 3 Replies Last reply
                                      • nagelcN nagelc
                                        gdb
                                        or J-link
                                        NeverDieN
                                        NeverDieN
                                        @nagelc If you do manage to get it working, I'd be curious as to what kind of range you get out of it a compared to other modules. The antenna pattern looks a bit different.
                                        • nagelcN nagelc
                                          gdb
                                          or J-link
                                          NeverDieN
                                          NeverDieN
                                          #1840
                                          @nagelc It's a shot in the dark, but maybe you want to check the schematic for any differences with other modules that you've previously programmed successfully. Either it's a dud, or it must be that.
