communicate is good for first time for relays and sensors but after some days will be weak and some time stop working !
@gohan said in communicate is good for first time for relays and sensors but after some days will be weak and some time stop working !:
maybe the voltage regulator? try to swap that too. It is all a matter of trial and error.
thank you . i will change the regulator with a better regulator.and i test again . thank you
also swapping things between gateway and repeater and see if problem follows the part or not.
to test it out you would need at least 2 nodes connected to gateway and 2 to the repeater and test where the node to node communication between all nodes and see which is having problems. The best solution would be to use more than the 2 parts you currently have just to exclude both of them being faulty. I am really running out of options.
ok thank you . i will test this .
@gohan
for test first i change my regulator in controller and repeater,use LF33 instead of
ams1117. but problem dont solve.now i put some relay near controller and connect directly to controller and i will test when there is problem and relay with repeater dont work, so relay that directly connect to controller have same problem or not ! -
