  3. Browser-based firmware generator
108 Posts 14 Posters 54.5k Views 18 Watching
  • rakeshpaiR
    rakeshpaiR
    rakeshpai
    Noted. Right now, the user will have to specify the ATSHA pin correctly for the SenseBender, so I guess it's not the end of the world, but I understand that it can be made easier.
    There's actually a little bit of an understanding of the board already - if you choose an ESP8266 gateway and decide to add sensors to it, you'll see pin numbers matching the ESP8266's pinout. That's pin configuration in a different sense though. Let me think about how I can incorporate this.
    Thanks for the kind words. :)
    AnticimexA 1 Reply Last reply
    • rakeshpaiR rakeshpai
      AnticimexA
      AnticimexA
      Anticimex
      @rakeshpai ah, ok. But the list of pins does not really make sense for the SenseBender gw since it is based on SAMD and not AVR.
      • rakeshpaiR
        rakeshpaiR
        rakeshpai
        Ah, didn't know that. Noted. I'll see how I can handle alternate boards.
        • U
          U
          user2684
          @rakeshpai I personally think this is just amazing! When I wrote NodeManager I tried to make the world of MySensors just a step closed to a user who is not necessarily a programmer, this is doing the other 99 steps ;-) I'm sure there will be a lot of interest around this project
          rakeshpaiR 1 Reply Last reply
          • U user2684
            rakeshpaiR
            rakeshpaiR
            rakeshpai
            Thanks, @user2684. @hek tells me that this is not the first attempt at making such a tool, but those attempts didn't end up succeeding. However, NodeManager might be changing that, making such a tool even possible. So, all compliments should be directed to you.
            I'll need to bother you soon, because I'll need your help to validate the generated code, since it directly uses NodeManager. Still working on it - I'll keep you posted.
            U 1 Reply Last reply
              U
              U
              user2684
              @rakeshpai sure, I'll be more than happy to double check any code generated for NodeManager! And I'll do a better job documenting future changes to the API since may have an impact on your project as well.
              • rakeshpaiR
                rakeshpaiR
                rakeshpai
                Update: Not much has changed functionally, but I've now added a UI notification for when an update is available, so I don't have to tell you to do the double-refresh/hard-refresh ;) and people are always on the latest version.
                I've also started writing some tests so that I can start to trust the generated code. I hope these tests are (at least somewhat) human-readable - they might be the easiest way to find out what the generated code is doing.
                For eg. this file tests the NodeManager parts of config.h, and this file tests the sensor-specific code for NodeManager. The tests aren't exhaustive yet - still work in progress.
                @user2684 Not sure if you'd prefer to read these tests. The alternative would be to change stuff on the UI, download zips, and verify the contents, which can get painful fast.
                  U
                  U
                  user2684
                  @rakeshpai I like the idea of the tests but I'm just afraid it will take more for you to write tests for all the possible combinations more than the time it took already to write the entire sketch generator :-) I'm wondering, is it something easy by chance having in console.log() the resulting code or the change performed upon any action for troubleshooting purposes? If it is too much effort, since it would be for myself only probably, let's explore a better alternative :-)
                    Disclaimer: This is a proof-of-concept. It doesn't work. Things will change, and will break. In fact, I'm sure many things are broken right now. It would be pretty stupid to use this for anything important. I'm just putting this in the public to gauge interest. You have been warned.
                    Link to the firmware generator.
                    If you are like me, you want to put approximately half a million MySensors nodes around the house. You've probably already built the first few nodes, so it feels like you are most of the way there. You love the soldering and the building. However, the coding isn't exactly fun. It requires reading through docs, then trying and failing, and rinse and repeat until you get it right.
                    This tool doesn't solve that problem yet, but it aims to. It aims to provide a simple browser-based UI for configuring your network, and then generating the firmware for the node automatically, using whatever's the best-practice for writing the firmware. This tool writes your code for you!
                    The good:
                    • You don't have to write code! This web page does it for you!
                    • Security built in by default.
                    • Uses the awesome NodeManager by @user2684 under the hood.
                    • The web-page, once loaded, works completely offline. You do not need an Internet connection to use this tool! (Try it!)
                    • No sign up, no registration. In fact, there's no server, or no central database. Your data doesn't even leave your browser.
                    • There's no server, so there's no network communication and everything's local, so it's blazing fast!
                    • That bears repeating: The firmware is generated inside your browser, without using any cloud that will rain down on you. Isn't it awesome what browsers can do these days?
                    The bad:
                    • Needs a pretty modern browser. Tested on Chrome and Firefox. Untested on IE.
                    • Doesn't work on mobile devices (yet). Might work in Chrome/Android, but it's untested. Other browsers would need a server-side component to get them to behave.
                    • I have Google Analytics on the site, just to gawk at some graphs. All GA data is anonymous.
                    The ugly:
                    • Well, it looks ugly.
                    • The code it generates hasn't been tested. This is just a proof of concept. DO NOT depend on this.
                    • The code, especially the security bits, require review. In fact, I'm pretty sure I've done it wrong.
                    • They say, 'if you aren't ashamed of it, you've released too late'. I'm definitely releasing too early.
                    With that summary out of the way, I'd love it if you could poke around and let me know what you think. You don't need to download or install anything - it's just a web page - so just click the link above. I'm trying to gauge interest in the community for this, to decide if it's worth pursuing.
                    Would you like me to spend time on making this better?
                    The icon to download firmware is on the top-right of the page, and you can see it on the pages for either the nodes you create, or on the page for the gateway. You can create nodes by selecting your network in the left hand side navigation, and clicking on the + icon at the top right of the page.
                    The firmware is downloaded as a zip, which contains a SecurityPersonalizer with your security settings, and the main sketch which runs on your node. Currently, the firmware might not even compile.
                    Hope this gives an idea of what I have in mind, even if it doesn't actually work.
                    All manner of suggestions and feedback is welcome.
                    core_cC
                    core_cC
                    core_c
                    @rakeshpai The idea of creating a generator is really cool. There are many non-programmers out there, just wanting their sensor-network up and running.
                    I bet you finish this project, and make many people happy. Keep up the good work rakeshpai.
                    The awesome MySensors generator
                    • core_cC core_c
                      rakeshpaiR
                      rakeshpaiR
                      rakeshpai
                      @core_c Thanks! That reminds me...
                      I need a name for this project, and I'm horrible at naming things. If some creative folks can chip in, that'd be awesome.
                      I've been referring to this as 'this', or app, or tool, or site, or things like that. None of them are good enough. A nice label would be great. Something catchy, maybe?
                        MySensors Sketch Generator,
                        MySensors Sketchy, ;)
                        MyGenerator,
                        NodeManager Generator,
                        • core_cC
                          core_cC
                          core_c
                          the word "Generator" scores. :)
                          i personally like "MyGenerator" most..
                          • rakeshpaiR
                            rakeshpaiR
                            rakeshpai
                            Sorry, I've been offline for the last few days. Just catching up.
                            'Sketchy' is hilarious. Certainly seems to describe the current reliability of the output code. ;) I'll wait for more suggestions though.
                            • AnticimexA
                              AnticimexA
                              Anticimex
                              MyFactory?
                              • rakeshpaiR
                                rakeshpaiR
                                rakeshpai
                                Sorry for the silence. My ISP is having trouble, and I've been mostly offline. I'm sending this message over crappy 3G on a phone.
                                Update
                                1. New 'Code' view that shows what the generated code will look like before having to download it. I'm not sure I like this - I would prefer having no mention of code on the UI at all - but it's worth experimenting with. Certainly makes things easy at dev time.
                                2. A migrations process, so that I don't have to ask you to delete your existing network, as I have been doing. Migrations will now move your local copy of the data to the latest version automatically, without any manual intervention, if there have been any changes in the data format.
                                That's all I have for now. I'll have more once my connectivity issues are fixed.
                                • rakeshpaiR
                                  rakeshpaiR
                                  rakeshpai
                                  I've hit a little bit of a wall, and need help to proceed.
                                  I created a NRF24L01 network in the UI, and tried to flash the default serial gateway code to an Arduino Pro Mini 3.3v/8Mhz. There are no sensors configured on the gateway. I tried to flash the SecurityPersonalizer on the device, and it worked perfectly, and gave a happy sounding serial output. (Yay!) However, when I flash the main gateway sketch, I get a 'not enough memory' error.
                                  Sketch uses 25,792 bytes (79%) of program storage space. Maximum is 32,256 bytes.
                                  Global variables use 2,204 bytes (107%) of dynamic memory, leaving -156 bytes for local variables. Maximum is 2,048 bytes.
                                  processing.app.debug.RunnerException: Not enough memory; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing your footprint.
                                  	at cc.arduino.Compiler.size(Compiler.java:339)
                                  	at cc.arduino.Compiler.build(Compiler.java:159)
                                  	at processing.app.SketchController.build(SketchController.java:641)
                                  	at processing.app.Editor$BuildHandler.run(Editor.java:1782)
                                  	at java.lang.Thread.run(Thread.java:745)
                                  For reference, the generated gateway sketch is as follows:
                                  // Message signing
                                  #define MY_SIGNING_SOFT
                                  #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
                                  // load user settings
                                  #include "config.h"
                                  // load MySensors library
                                  // load NodeManager library
                                  #include "NodeManager.h"
                                  // create a NodeManager instance
                                  NodeManager nm;
                                  // before
                                  void before() {
                                    // setup the serial port baud rate
                                    Serial.begin(9600);
                                    nm.before();
                                  // presentation
                                  void presentation() {
                                    // call NodeManager presentation routine
                                    nm.presentation();
                                  // setup
                                    // call NodeManager setup routine
                                    nm.setup();
                                  // loop
                                    // call NodeManager loop routine
                                    nm.loop();
                                  // receive
                                    // call NodeManager receive routine
                                    nm.receive(message);
                                  // receiveTime
                                  void receiveTime(unsigned long ts) {
                                    // call NodeManager receiveTime routine
                                    nm.receiveTime(ts);
                                  and the associated config.h is:
                                  #ifndef config_h
                                  #define config_h
                                   * Sketch configuration
                                  #define SKETCH_NAME "Gateway"
                                  #define SKETCH_VERSION "1.0"
                                  //#define MY_REPEATER_FEATURE
                                   * MySensors node configuration
                                  // General settings
                                  #define MY_BAUD_RATE 9600
                                  //#define MY_DEBUG
                                  // NRF24 radio settings
                                  #define MY_RF24_ENABLE_ENCRYPTION
                                  #define MY_RF24_CHANNEL 76
                                  //#define MY_DEBUG_VERBOSE_RF24
                                  // Serial gateway settings
                                  #define MY_GATEWAY_SERIAL
                                   * NodeManager configuration
                                  // if enabled, enable debug messages on serial port
                                  //#define DEBUG 1
                                  #define POWER_MANAGER 0
                                  #define BATTERY_MANAGER 0
                                  // if enabled, allow modifying the configuration remotely by interacting with the configuration child id
                                  #define REMOTE_CONFIGURATION 1
                                  // if enabled, persist the configuration settings on EEPROM
                                  #define PERSIST 1
                                  // if enabled, a battery sensor will be created at BATTERY_CHILD_ID and will report vcc voltage together with the battery level percentage
                                  #define BATTERY_SENSOR 1
                                  // if enabled, send a SLEEPING and AWAKE service messages just before entering and just after leaving a sleep cycle and STARTED when starting/rebooting
                                  #define SERVICE_MESSAGES 1
                                  // Enable this module to use one of the following sensors: SENSOR_ANALOG_INPUT, SENSOR_LDR, SENSOR_THERMISTOR, SENSOR_MQ, SENSOR_ML8511, SENSOR_ACS712, SENSOR_RAIN_GAUGE
                                  #define MODULE_ANALOG_INPUT 0
                                  // Enable this module to use one of the following sensors: SENSOR_DIGITAL_INPUT
                                  #define MODULE_DIGITAL_INPUT 0
                                  // Enable this module to use one of the following sensors: SENSOR_DIGITAL_OUTPUT, SENSOR_RELAY, SENSOR_LATCHING_RELAY
                                  #define MODULE_DIGITAL_OUTPUT 0
                                  // Enable this module to use one of the following sensors: SENSOR_DHT11, SENSOR_DHT22
                                  #define MODULE_DHT 0
                                  // Enable this module to use one of the following sensors: SENSOR_SHT21
                                  #define MODULE_SHT21 0
                                  // Enable this module to use one of the following sensors: SENSOR_SWITCH, SENSOR_DOOR, SENSOR_MOTION
                                  #define MODULE_SWITCH 0
                                  // Enable this module to use one of the following sensors: SENSOR_DS18B20
                                  #define MODULE_DS18B20 0
                                  // Enable this module to use one of the following sensors: SENSOR_BH1750
                                  #define MODULE_BH1750 0
                                  // Enable this module to use one of the following sensors: SENSOR_MLX90614
                                  #define MODULE_MLX90614 0
                                  // Enable this module to use one of the following sensors: SENSOR_BME280
                                  #define MODULE_BME280 0
                                  // Enable this module to use one of the following sensors: SENSOR_SONOFF
                                  #define MODULE_SONOFF 0
                                  // Enable this module to use one of the following sensors: SENSOR_BMP085
                                  #define MODULE_BMP085 0
                                  // Enable this module to use one of the following sensors: SENSOR_HCSR04
                                  #define MODULE_HCSR04 0
                                  // Enable this module to use one of the following sensors: SENSOR_MCP9808
                                  #define MODULE_MCP9808 0
                                  I tried commenting out the first three lines in the gateway sketch (the #defines to do with security personalisation, and the sketch fits, but only barely.
                                  Sketch uses 19,922 bytes (61%) of program storage space. Maximum is 32,256 bytes.
                                  Global variables use 1,710 bytes (83%) of dynamic memory, leaving 338 bytes for local variables. Maximum is 2,048 bytes.
                                  Low memory available, stability problems may occur.
                                  I'm by no means a C/C++ guy (which I why I'm writing this tool ;) ) so I'll need help to fix this. I don't even know where to start looking, since there's the combination of NodeManager and the software signing in the sketch.
                                  Any chance you could look at this, @user2684 and @Anticimex? You could download a copy of the code from the UI if you like. My configuration is an NRF network, and the gateway is the default serial gateway on the UI. I've been using the latest version of the MySensors lib from the development branch on GitHub, and am doing the compilation in the Arduino IDE.
                                  Thanks!
                                    // Message signing
                                    #include "config.h"
                                    NodeManager nm;
                                    // before
                                    void before() {
                                      Serial.begin(9600);
                                      nm.before();
                                    // presentation
                                      nm.presentation();
                                    // setup
                                      nm.setup();
                                    // loop
                                      nm.loop();
                                    // receive
                                    // receiveTime
                                      nm.receiveTime(ts);
                                    #ifndef config_h
                                    #define config_h
                                    // General settings
                                    //#define MY_DEBUG
                                    //#define DEBUG 1
                                    #define PERSIST 1
                                    Thanks!
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @rakeshpai I have never used node manager myself but it appears that it consumes quite some memory. I have to my best effort optimized the signing code to use as little memory as possible. That said, it could very well be possible to optimize it further, but I would then need other eyes on it. I have not looked into node manager, but as I understand it, it relies heavily on c++ (signing code is pretty much just c) and the atmega compiler optimized c++ code horribly bad. So I think that it is in nodemanager the biggest memory savings can be made.
                                    • AnticimexA Anticimex
                                      rakeshpaiR
                                      rakeshpaiR
                                      rakeshpai
                                      @Anticimex That's the feeling I had as well, considering that even after I disabled signing, while the sketch fits in memory, it still seemed to complain about low memory. @user2684 does this match your experience too?
                                      AnticimexA U 2 Replies Last reply
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @rakeshpai the warning is because the heap and stack is shared. So as the program claims storage for variables (typically globals statics and classes) the ram available for stack shrinks. And at some point it becomes to small. But the tools cannot determine when that happens as such analysis is quite complex. So they warn when it "feels" to be getting tight. But it ultimately comes down to how the program behaves and how the code handles function calls and parameters. So if you get the warning, it does not mean there is a problem. But you have entered what somebody decided to be the "danger zone" (probably based on typical sketch stack usage).
                                          U
                                          U
                                          user2684
                                          @rakeshpai sorry for the delay! NodeManager consumes some good memory indeed but I should have optimized this in v1.5 and the problem should have gone unless a lot of sensors are registered but this is not your case. Are you already using this version?
                                          As a side note, I've noticed when MY_RF24_ENABLE_ENCRYPTION is defined a good 20% of memory got consumed on a pro mini but I guess this is not something we can do much about :)
