  3. Sleep issue
Sleep issue
8 Posts 2 Posters 2.1k Views 2 Watching
  • Richard van der PlasR
    wrote on last edited by Richard van der Plas
    Having code with a door sensor and a light.
    Because i want to save battery time, ive incoporated a sleep mode.
    the sleep mode is called after the door is closed, and will wake up again after a change or time ( to measure temperature).
    Sleep mode must not be called when the door is open because of the light which should go out after a radio message from the Gateway.
    snippet of code:, the 2,5 seconds delay is to make sure the door doesnt open again.
    if (gotoSleep == 1) {
         Serial.print("--==## Door closed, Going to Sleep ");
         Serial.println(SLEEP_TIME);
         delay(2500);
         sleep(digitalPinToInterrupt(DOOR_SWITCH), FALLING, SLEEP_TIME);
         gotoSleep =0;
    log file shows this:
    --==##Door Trigger1
    14061 TSF:MSG:SEND,5-5-0-0,s=0,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
    --## Running  Loop
    --==##Door Trigger0
    16822 TSF:MSG:SEND,5-5-0-0,s=0,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
    19329 MCO:SLP:MS=300000,SMS=0,I1=0,M1=2,I2=255,M2=255
    19333 MCO:SLP:TPD
    19385 MCO:SLP:WUP=0
    That is so weird, why does it wake again on interrupt (as told by log parser)
    CHANGE or FALLING doesn t matter
    Richard van der PlasR YveauxY 2 Replies Last reply
    • Richard van der PlasR Richard van der Plas
           delay(2500);
           gotoSleep =0;
      --==##Door Trigger1
      --## Running  Loop
      --==##Door Trigger0
      19333 MCO:SLP:TPD
      19385 MCO:SLP:WUP=0
      This post is deleted!
             delay(2500);
             gotoSleep =0;
        --==##Door Trigger1
        --## Running  Loop
        --==##Door Trigger0
        19333 MCO:SLP:TPD
        19385 MCO:SLP:WUP=0
        YveauxY
        YveauxY
        @Richard-van-der-Plas update to latest MySensors library (2.2.0 beta) and try again please.
        Richard van der PlasR 1 Reply Last reply
        • YveauxY Yveaux
          @Yveaux i dont think i can do that in the online arduino create environment.....
          YveauxY 1 Reply Last reply
            YveauxY
            YveauxY
            @Richard-van-der-Plas probably not, but what you're describing is a known issue in 2.1.x
            • YveauxY Yveaux
              @Yveaux damn is there any other way to fix it besides the 2.2?
                YveauxY
                YveauxY
                @Richard-van-der-Plas not that I'm aware of. It's a bug in the library which you cannot fix without touching the library code.
                • YveauxY Yveaux
                  @Yveaux Ok went to 2.0 and that indeed works
