  3. Interval/sleep sensor settings
6 Posts 4 Posters 2.8k Views 1 Watching
  • M Offline
    M Offline
    marceltrapman
    Let's assume I have a temperature sensor and let's assume I want to set it to sleep for 30 minutes before reporting any change (if any) makes me thing the following:
    1. Is it possible to change this interval through the controller/gateway currently or can I and do I need to add this myself?
    2. When I do this the sensor is asleep and can not receive any request from the controller (if I am correct). Will the request be queued or do I have to create a queue on the controller?
    3. When I have to create a queue on the controller how is it reported that the request did not arrive?
    4. And, lastly, is it possible to wake the sensor up with a special request (I assume not)?
    Fulltime Servoy Developer
    • M Offline
      M Offline
      mitekg
      wrote on last edited by hek
      here is my solution for dht-22 battery driven sensor:
        #include <Sleep_n0m1.h>
        #include <EEPROM.h>
        #include <RF24.h>
        #include <Sensor.h>
        #include <DHT.h>
        // Set RADIO_ID to something unique in your sensor network (1-254)
        // or set to AUTO if you want gw to assign a RADIO_ID for you.
        #define RADIO_ID AUTO
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        // Send the Battery Percentage to the Gateway
        #define VBatMax 4.0            // The voltage of New Batteries
        #define VBatDropout  2.0    // The battery dropout voltage
        unsigned long SLEEP_TIME = 30; // Sleep time between reads (in seconds)
        float SENSOR_TOLERANCE = 0.1; // Tempereture or humidity sensetive change +- 0.1 will not go to data transmit
        unsigned long SEND_FREQ = 1; // If the temperature doesn't change for this period, force data transition of battery level to reset TTL on vera gate. 1 = means send each time the sensor wake-up
        unsigned long SETTINGS_REQ_FREQ = 1; // How often node reqsts a new settings 1 = means req. each time the sensor wake-up. NOTE: Settings reqsts each time the sensor resets.
        struct port_param_t{String name; String value;};
        #define MAX_PARAMS 20 // ������� ���������� ����������� �� ����� �������
        port_param_t params[MAX_PARAMS]; // � ���� ������ ����� ��������� ���� ��������� ���������
        byte parsedParams=0; // ������� ���������� ��� ������� ���������
        Sensor gw(9, 10);
        DHT dht;
        Sleep sleep;
        float lastTemp;
        float lastHum;
        float lastSend = 0;
        float lastReq = 0;
        float lastBattLevel;
        boolean metric = true;
          delay(2000);
          analogReference(INTERNAL);
          Serial.begin(BAUD_RATE);  // Used to type in characters
          gw.begin(RADIO_ID);
          gw.sendSketchInfo("Humidity", "1.2");
          gw.sendSensorPresentation(CHILD_ID_HUM, S_HUM);
          gw.sendSensorPresentation(CHILD_ID_TEMP, S_TEMP);
          metric = gw.isMetricSystem();
          veraCfgread();
        void veraCfgread()
        	char* defCfg="1,1,30,1";
        	char* Cfg = gw.getStatus(RADIO_ID, V_VAR1); // getting cfg
        	Serial.println("parsed:");
        	parseParams(Cfg);
        	if (parsedParams==0)
        		gw.sendVariable(RADIO_ID, V_VAR1, defCfg);
        	else
        		SENSOR_TOLERANCE = float(strtoint(params[0].value))/10;
        		SEND_FREQ = strtoint(params[1].value);
        		SLEEP_TIME = strtoint(params[2].value);
        		SETTINGS_REQ_FREQ = strtoint(params[3].value);
        	Serial.print(SENSOR_TOLERANCE);
        	Serial.print(",");
        	Serial.print(SEND_FREQ);
        	Serial.print(",");
        	Serial.print(SLEEP_TIME);
        	Serial.print(",");
        	Serial.print(SETTINGS_REQ_FREQ);
        	Serial.print(".");
        // Read the Battery
        long readVcc() {
            long result;
            ADCSRA |= _BV(ADSC); // Convert
            while (bit_is_set(ADCSRA,ADSC));
            result = ADCL;
            result |= ADCH<<8;
            result = 1125300L / result; // Back-calculate AVcc in mV
            return result;
        int strtoint(String str) // ��������� ��������������� ������ � �����
          int tempInt;
          char rez[str.length()+1];
          str.toCharArray(rez, sizeof(rez));
          tempInt = atoi(rez);
          return tempInt;
        void parseParams(char* inputString)
        	parsedParams=0; // ���� ������ �� ���������
        	String message = inputString;
        	int commaPosition;  // the position of the next comma in the string
        	do
              commaPosition = message.indexOf(',');
              if(commaPosition != -1)
                  params[parsedParams].value = message.substring(0,commaPosition);
        		  parsedParams++;
                  message = message.substring(commaPosition+1, message.length());
              else
              {  // here after the last comma is found
                 if(message.length() > 0)
                   params[parsedParams].value = message;  // if there is text after the last comma
           while(commaPosition >=0);
          lastSend--;
          lastReq--;
          // -1------------------------------------------
          if (isnan(temperature))
          else if (temperature != lastTemp || lastSend == 0)
        			Serial.print("TR: ");
        			Serial.println(temperature);
        			float delta = lastTemp - temperature;
        			delta = abs (delta);
        			if (delta > SENSOR_TOLERANCE || lastSend == 0)
        				lastTemp = temperature;
        				if (!metric)
        				gw.sendVariable(CHILD_ID_TEMP, V_TEMP, temperature, 1);
        				Serial.print("T: ");
          // -2------------------------------------------
          if (isnan(humidity))
          else if (humidity != lastHum || lastSend == 0)
        		   Serial.print("HR: ");
        		   Serial.println(humidity);
        		   float delta = lastHum - humidity;
        			   lastHum = humidity;
          Serial.println(lastSend);
          if (lastSend <= 0)
        	  lastSend = SEND_FREQ;
          Serial.print("LastSndAfter: ");
          if (lastReq <= 0)
        	  veraCfgread();
        	  lastReq = SETTINGS_REQ_FREQ;
          // -3------------------------------------------
          long curVcc;// = readVcc();
          float pct;  // = (curVcc-(VBatDropout*1000)) /(((VBatMax-VBatDropout) *1000))*100;
          float batteryV  = sensorValue * 0.003363075;
          curVcc = batteryV*1000;
          pct = batteryPcnt;
          if (pct != lastBattLevel)
        	  lastBattLevel = pct;
        	  gw.sendBatteryLevel(pct);
        	  /*Serial.print("Batt%: ");
              Serial.println(pct);
        	  Serial.print("Vcc: ");
              Serial.println(batteryV);*/
        	  gw.sendVariable(RADIO_ID, V_VAR2, curVcc);
          // Power down the radio.  Note that the radio will get powered back up
          // on the next write() call.
          delay(1000); //delay to allow serial to fully print before sleep
          gw.powerDown();
          sleep.pwrDownMode(); //set sleep mode
          sleep.sleepDelay(SLEEP_TIME * 1000); //sleep for: sleepTime
        			   gw.sendVariable(CHILD_ID_HUM, V_HUM, humidity, 1);
        			   Serial.print("H: ");
          Serial.print("LastSndBefore: ");
      • M Offline
        M Offline
        marceltrapman
        Wow thank you but... Can you please correct the formatting :)
        • H Offline
          H Offline
          Thanks for the example @mitekg
          Took the liberty to fix the formatting in your post.
          Start a line with 4 spaces or tab to format as code.
          M 1 Reply Last reply
          • H hek
            M Offline
            M Offline
            mitekg
            @hek, thx4fix!)
            @marceltrapman, if u have any questions, u r welcome)
            R 1 Reply Last reply
            • M mitekg
              @hek, thx4fix!)
              R Offline
              R Offline
              RJ_Make
              @mitekg
              Have you converted you sketch to v 1.4?
              RJ_Make
              12.1k
