  3. TSM:FPAR:No Reply
TSM:FPAR:No Reply
42 Posts 7 Posters 16.1k Views 8 Watching
  • T
    Tommas
    wrote on last edited by Tommas
    Dear All!
    Im beginner in the wireless sensor node + gateway world, and I started to build a simple MQTTClient Gateway (UNO R3 + W5100 + nrf24) with an DHT11 Sensor node (Arduino nano + DHT11 + nrf24).
    The gateway and the node are seems to be working, but the node says that
    "!TSM:FPAR:NO REPLY"
    Could someone help me what might be the problem?
    The full messages:
    NODE
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:INIT:STATID=2
    14 TSF:SID:OK,ID=2
    16 TSM:FPAR
    53 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2060 !TSM:FPAR:NO REPLY
    2062 TSM:FPAR
    2098 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4106 !TSM:FPAR:NO REPLY
    4108 TSM:FPAR
    4144 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6152 !TSM:FPAR:NO REPLY
    6154 TSM:FPAR
    6190 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8198 !TSM:FPAR:FAIL
    8199 TSM:FAIL:CNT=1
    8201 TSM:FAIL:PDT
    18204 TSM:FAIL:RE-INIT
    18206 TSM:INIT
    18213 TSM:INIT:TSP OK
    18215 TSM:INIT:STATID=2
    18217 TSF:SID:OK,ID=2
    18220 TSM:FPAR
    18256 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20264 !TSM:FPAR:NO REPLY
    20267 TSM:FPAR
    20303 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    GW
    0;255c=0,t=0,pt=0,l=0,sg=0:
    0;255;3;0;9;!TSF:MSG:LEN,0!=7
    l=0,sg=0:
    0;255;3;0;9;TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP: 100.100.13.150
    0;255;3;0;9;MCO:BGN:STP
    IP: 100.100.13.150
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;Sending message on topic: mygateway1-out/0/255/0/0/18
      How are you powering the radio modules? What capacitors did you use on the radios if any?
      • T
        Tommas
        Dear gonhan!
        First of all, thank you for your help.
        I have two power module (https://www.ebay.com/itm/262102860958 ) with an mb102 bread board and i use it for powering my nrf24. I use a 7.5v 1000mA adapter to power the modules.
        The capacitor is a 47uF one.
        I power the two microcontrollers through USB connected to my laptop at the same time, because at this way i can switch the console output between the two controllers when i would like to see the output.
        I try to follow the guides described here. All parts are from keyestudio except the two nrf24(with antenna) module.
        I use the mysensors latest library , gatewayW5100mqttclient and a dht11 example sketch (but i have tried already another official mysensors lightsensor sketch) on the node.
          Try to put the radios a couple of meters apart and see if you see any change
          T 1 Reply Last reply
            Tommas
            @gohan
            Dear gohan!
            I have tried but nothing change. I bought two nrf24 from keyestudio without pa/lna , if it arrives i will try those.
            I will write the experiences with the new ones.
            Best regards
              Are you using the PA lna? If so try a bigger cap, set pa power to min and you could also wrap the radio module with plastic and aluminum foil for shielding
                Tommas
                @gohan
                Hi gohan!
                Oh, OK! Im trying today. How can i set the power to minimum?
                Have a Good day!
                  Look at the examples of other sketches, it's a define to be added, or you can set the default value in myconfig.h inside the library folder (look for the nrf24 section in the file)
                  • ben999B
                    ben999B
                    ben999
                    Did you define the node_Id and parent_ID in the sketch ?
                    T 2 Replies Last reply
                    • ben999B ben999
                      Tommas
                      @ben999
                      Hi Ben!
                      I havent define the parent ID because i havent known that i should do. i will try these settings as soon as i can.
                      I have already defined the node id in the node sketch
                      Thank you!
                        Tommas
                        This post is deleted!
                        • ben999B ben999
                          Tommas
                          @ben999
                          Hi Ben!
                          How can i define the parent id on the gateway?
                            You don't have to define a parent ID in your case.
                            • J
                              J
                              Jan Hilbrandt
                              Hi Guys,
                              i have the same Problem
                              I've build a Serial-Gateway (Arduino Nano clone + nrf24) and a node (Arduino Nano clone + DHT22 + nrf24)
                              I do the connecition from this Site and added a 10µF capacitor to VCC and GND.
                              I try to set a fix Node-ID, but there is the same problem
                              This is the Log from the Gateway:
                              0;255;0;0;18;2.1.1
                              And the Node:
                              3 TSM:INIT
                              4 TSF:WUR:MS=0
                              11 TSM:INIT:TSP OK
                              13 TSF:SID:OK,ID=10
                              14 TSM:FPAR
                              1613 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              3621 !TSM:FPAR:NO REPLY
                              3623 TSM:FPAR
                              5223 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              7230 !TSM:FPAR:NO REPLY
                              7232 TSM:FPAR
                              8832 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              10839 !TSM:FPAR:NO REPLY
                              10841 TSM:FPAR
                              12440 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              14448 !TSM:FPAR:FAIL
                              14449 TSM:FAIL:CNT=1
                              14451 TSM:FAIL:PDT
                              24454 TSM:FAIL:RE-INIT
                              24456 TSM:INIT
                              24463 TSM:INIT:TSP OK
                              24465 TSF:SID:OK,ID=10
                              24467 TSM:FPAR
                              26066 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              28075 !TSM:FPAR:NO REPLY
                              28077 TSM:FPAR
                              I think the node is send some data but the gateway not answer.
                              I increase the distance between the gateway and the node, but still the same problem.
                              Sorry for my bad english :blush:
                                do you see any message in the GW log when node is trying to connect? Because if not it may be a problem ot the radio module of the note not sending correctly, one of the radio modules could be a fake module and very poor quality. In the beginning I bought some modules that had a blob instead of an IC on the module and they were all not working. I can suggest to try some sample sketches to check if modules are communicating and also you could give a try to mysensors library from development branch
                                • J
                                  J
                                  Jan Hilbrandt
                                  No that is the full log from the GW. Damn...all my radiomodules have this blob like this one on the left picture.
                                  I have also tested other NRF receivers (with the blob)
                                    Those are the kind that normally doesn't work. Return them if you can or you can just dump them and get the good ones (look at the threads about genuine NRF24)
                                      Tommas
                                      @gohan
                                      Oh ok. Thanks.
                                      I tried to attach 100uF capacitor but the results are same.(no reply) . The node ID is defined, the parent ID isnt.
                                      It seems that im out of ideas. I wait for the new nrf24 without pa lna.
                                      Im attaching some pictures about the project.
                                      Should i foil the nrf24 modul?
                                      https://cloud.freeforall.hu/owncloud/public.php?service=files&t=1f73fddc20c6d9a2560f88f78affd499
                                        I can't see the link but I trying to foil the radio module could be an idea, as I wrote a few posts earlier
                                          Tommas
                                          @gohan
                                          Dear gohan!
                                          Sorry, it is a private home server and it was in maintenance mode when you were trying to connect. Now it should be working.
                                          (The new nrf24 have just arrived so im going to try these as soon as i can)
                                          Best regards
