  3. Domoticz
  4. Are folks here happy with Domoticz?
63 Posts 28 Posters 55.6k Views 24 Watching
  • K kany
    Hello guys,
    I am a beginner with Domoticz. I would like to ask you a question. Can i find a way to recover the data from a sensor like temperature or smartmeter to be installed in local?
    I am working with Rasperbery +domoticz + Smartplug Fibaro.
    Firstly, i install domoticz in raspberry and i configure the plug fibaro to communicate with a usb Zwave. And it works. i can see the graph but I do not succed to retrieve the data locally into the raspberry.
    Someone has a solution to propose me?
    Thanks guys
    @kany are you referring to save data to something like influxdb?
    K 1 Reply Last reply
      K
      K
      kany
      @gohan yeah!! Possible.My goal is to use machine learning with the data i collect.
      So if you give me link where the explain how it's working influxdb it Will be good
      Thnnk@gohan for your reply
      W 1 Reply Last reply
      • K kany
        W
        W
        wergeld
        @kany Well, the data is in a SQLite database for domoticz already. You can move to InfluxDB easily. See this post on the Domoticz forum - this is how I set it up using these instructions.
        My qualms with InfluxDB is that deleting a value is nearly impossible.
        • NeverDieN NeverDie
          @gohan said in Are folks here happy with Domoticz?:
          You could use node-red to log data to an external db and do whatever you want after that: it should be easier than replace the entire controller
          In that scenario, would Node Red be getting the sensor message first and then just somehow quickly piping it to Domoticz and a copy to the external database (e.g. MySQL)?
          tbowmoT
          tbowmoT
          tbowmo
          @NeverDie
          I use node-red with domoticz, MySensor data hits node-red first (serial gateway) which then pipes the data to domoticz via a fake serial port. That way I can manipulate data that I send to domoticz, and can inject fake mysensor sensors into domoticz as well..
          Node-red also dumps all data to influxdb for data storage, and then I use grafana for graphing purposes. Besides that I have created my own dashboard for tablets.
          Currently I mostly use domoticz as scripting engine (lua), for some basic events. For example turning on TV if someone starts streaming to my chromecast, and automatically turn it off again if chromecast have been in idle state for 2 minutes (the same for my chromecast audio, that just turn on amplifier instead of TV).
          W gohanG 2 Replies Last reply
          • tbowmoT tbowmo
            @NeverDie
            W
            W
            wergeld
            wrote on last edited by wergeld
            #45
            @tbowmo Do you have a link to your node-red setup? I would like to filter the output of my sensor nodes as well (got a flaky one that sends -47.5 F temp every once in a while.
            Found your github!
            For others looking it is here.
            tbowmoT 1 Reply Last reply
            • tbowmoT tbowmo
              @NeverDie
              @tbowmo would that work also for ethernet/mqtt gateway?
              • W wergeld
                Found your github!
                tbowmoT
                tbowmoT
                tbowmo
                @wergeld
                the module is available through NPM as well.. So npm install node-red-contrib-mysensors :)
                The basic node-red mysensors is pasted below, my setup is starting to be quite extensive, with reporting to slack channels, creating a websocket for my custom dashboard etc. But isn't necessary for the basic domoticz/nodered
                For connecting node-red/domoticz together I use socat to create a virtual serial port:
                socat PTY,link=/dev/ttyS81,mode=666,group=dialout,raw PTY,link=/dev/ttyUSB21,mode=666,group=dialout,raw &
                node-red:
                        "id": "9b272654.9ad688",
                        "type": "subflow",
                        "name": "Influx processing",
                        "info": "",
                        "in": [
                                "x": 220,
                                "y": 280,
                                "wires": [
                                        "id": "5cfd0e8.fa302f"
                        "out": [
                                "x": 960,
                                "y": 240,
                                "wires": [
                                        "id": "55204322.aadfbc",
                                        "port": 0
                                "x": 960,
                                "y": 380,
                                "wires": [
                                        "id": "d6b8cf3e.6954c",
                                        "port": 0
                        "type": "function",
                        "z": "9b272654.9ad688",
                        "name": "Influx conditioner",
                        "func": "msg_env = null;\nmsg_utility = null;\nmsg_debug = null;\nst = msg.subType;\nif (msg.messageType == 1 && (st === 0 || st == 1 || st == 4 || st == 17)) {\n    var tags = {};var data = {}\n    tags.node = msg.nodeId.toString();\n    tags.sensor = msg.childSensorId.toString();\n    data.value=parseFloat(msg.payload);\n    switch (st) {\n        case 0 : type = \"temperature\";break;\n        case 1 : type = \"humidity\"; break;\n        case 4 : type = \"barometer\"; break;\n        case 17: type = \"electricity\"; break;\n    }\n    msg.payload = [data, tags];\n    msg.measurement = type;\n    msg_debug = msg;\n    if (msg.subType==17) \n        msg_utility = msg;\n    else \n        msg_env = msg;\n} \nelse \n    msg = null;\nreturn [msg_debug, msg_env, msg_utility];",
                        "outputs": "3",
                        "noerr": 0,
                        "x": 790,
                        "y": 280,
                        "wires": [
                                "c042117a.3fbdf"
                                "f6bdc7dc.77c758"
                        "id": "5cfd0e8.fa302f",
                        "type": "mysdecenc",
                        "name": "",
                        "x": 350,
                        "y": 280,
                        "wires": [
                                "55204322.aadfbc",
                                "d6b8cf3e.6954c"
                        "id": "c042117a.3fbdf",
                        "type": "influxdb out",
                        "influxdb": "9dbdc7c7.624238",
                        "name": "",
                        "measurement": "",
                        "x": 1020,
                        "y": 280,
                        "wires": []
                        "id": "f6bdc7dc.77c758",
                        "influxdb": "9de2e4ed.fdcfc8",
                        "name": "Utility",
                        "measurement": "",
                        "x": 990,
                        "y": 320,
                        "wires": []
                        "type": "function",
                        "name": "Watt/Hour calculator",
                        "func": "/* Takes input on subType 24, calculates difference\n   from last time, if around 60 seconds have passed\n   since last report.\n   It passes the value on as subType 17, and\n   childSensorId 2 */\n\nif ((msg.subType===24) && (msg.nodeId===99)) {\n    var uTime = Math.floor(Date.now()/60000);\n    var lastTime = context.get('lastTime')||0;\n    if (lastTime === 0) {\n        context.set('lastTime', uTime);\n        context.set('lastCount', msg.payload);\n    } else {\n        if (uTime != lastTime) {\n            lastCount = context.get('lastCount');\n            currentCount = msg.payload;\n            context.set('lastTime', uTime);\n            context.set('lastCount', currentCount)\n            msg.subType = 17;\n            msg.childSensorId = \"2\";\n            msg.payload = currentCount - lastCount;\n            return msg;\n        }\n    }\n}",
                        "outputs": 1,
                        "noerr": 0,
                        "x": 560,
                        "y": 340,
                        "wires": [
                                "55204322.aadfbc"
                        "id": "9dbdc7c7.624238",
                        "type": "influxdb",
                        "z": "67deb464.98214c",
                        "hostname": "127.0.0.1",
                        "port": "8086",
                        "database": "environment",
                        "name": "Environment DB"
                        "id": "9de2e4ed.fdcfc8",
                        "type": "influxdb",
                        "port": "8086",
                        "database": "utility",
                        "name": "Utility DB"
                        "id": "4c13992e.b3ec68",
                        "type": "subflow",
                        "name": "Logging filter",
                        "in": [
                                "x": 105.5,
                                "y": 240,
                                "wires": [
                                        "id": "c2063804.3df9c8"
                        "out": [
                                "x": 600,
                                "y": 260,
                                "wires": [
                                        "id": "b57b1f3.f4a84e",
                                        "port": 1
                        "id": "c2063804.3df9c8",
                        "z": "4c13992e.b3ec68",
                        "name": "",
                        "x": 230,
                        "y": 240,
                        "wires": [
                                "b57b1f3.f4a84e"
                        "type": "function",
                        "name": "Filter battery msg",
                        "func": "var battMsg = null;\nvar debugMsg = null;\nvar sketchMsg = null;\nif (msg.messageType==3) {\n    if (msg.subType===0)\n        battMsg = msg;\n    if (msg.subType==9)\n        debugMsg = msg;\n    if (msg.subType==11 || msg.subType==12)\n        sketchMsg = msg;\n}\n\nreturn [battMsg, debugMsg, sketchMsg];",
                        "outputs": "3",
                        "noerr": 0,
                        "x": 430,
                        "y": 240,
                        "wires": [
                                "dec3cc44.213c3",
                                "d8b91167.2746f"
                                "b521bd95.4ade4"
                        "id": "dec3cc44.213c3",
                        "name": "",
                        "x": 650,
                        "y": 180,
                        "wires": [
                                "1b4decbb.e4b213"
                        "id": "38f9ab87.c70654",
                        "type": "file",
                        "name": "Battery log",
                        "filename": "/var/tmp/battlog.txt",
                        "appendNewline": false,
                        "createDir": false,
                        "overwriteFile": "false",
                        "x": 1050,
                        "y": 180,
                        "wires": []
                        "id": "1b4decbb.e4b213",
                        "type": "function",
                        "name": "inject date",
                        "func": "var date = new Date();\nvar str = date.getFullYear() + \"-\" + (date.getMonth() + 1) + \"-\" + date.getDate() + \" \" +  date.getHours() + \":\" + date.getMinutes() + \":\" + date.getSeconds();\nmsg.payload = str + \" - \" + msg.payload;\nreturn msg;",
                        "outputs": 1,
                        "noerr": 0,
                        "x": 830,
                        "y": 180,
                        "wires": [
                                "38f9ab87.c70654"
                        "id": "d8b91167.2746f",
                        "type": "function",
                        "name": "Check batt level",
                        "func": "var date = new Date();\nvar str = date.getFullYear() + \"-\" + (date.getMonth() + 1) + \"-\" + date.getDate() + \" \" +  date.getHours() + \":\" + date.getMinutes() + \":\" + date.getSeconds();\nmsg.date = str;\nif (parseInt(msg.payload)<5)\nreturn msg;",
                        "outputs": 1,
                        "noerr": 0,
                        "x": 660,
                        "y": 220,
                        "wires": [
                                "c44e1c28.3bb1e"
                        "id": "c44e1c28.3bb1e",
                        "type": "template",
                        "name": "BatLow message",
                        "field": "payload",
                        "fieldType": "msg",
                        "format": "handlebars",
                        "syntax": "mustache",
                        "template": "{{date}} - Battery level is low on node {{nodeId}} : {{payload}} !",
                        "x": 850,
                        "y": 220,
                        "wires": [
                                "e9231639.16dce8"
                        "id": "e9231639.16dce8",
                        "type": "twitter out",
                        "twitter": "",
                        "name": "Tweet",
                        "x": 1030,
                        "y": 220,
                        "wires": []
                        "id": "b478903e.4b877",
                        "type": "file",
                        "name": "Presentation log",
                        "filename": "/var/tmp/presentation.txt",
                        "appendNewline": true,
                        "createDir": false,
                        "x": 840,
                        "y": 300,
                        "wires": []
                        "id": "b521bd95.4ade4",
                        "name": "",
                        "x": 650,
                        "y": 300,
                        "wires": [
                                "b478903e.4b877"
                        "id": "bed2e35d.412d2",
                        "type": "subflow",
                        "name": "Domoticz conditioner",
                        "info": "Inverts lockstate for domoticz, as domoticz has inverted the logic in their code, compared to mysensors",
                        "in": [
                                "x": 280,
                                "y": 220,
                                "wires": [
                                        "id": "8afd136d.7502f"
                        "out": [
                                "x": 1000,
                                "y": 220,
                                "wires": [
                                        "id": "91eb6b4c.6e1498",
                                        "port": 0
                        "id": "8afd136d.7502f",
                        "z": "bed2e35d.412d2",
                        "name": "",
                        "x": 410,
                        "y": 220,
                        "wires": [
                                "126152bf.ed9ead"
                        "id": "126152bf.ed9ead",
                        "type": "function",
                        "name": "Invert lockstate for domoticz",
                        "func": "if (msg.subType == 36) {\n    if (msg.payload== \"1\") msg.payload=\"0\";\n    else msg.payload=\"1\";\n}\nreturn msg;",
                        "outputs": 1,
                        "noerr": 0,
                        "x": 640,
                        "y": 220,
                        "wires": [
                                "91eb6b4c.6e1498"
                        "name": "",
                        "x": 870,
                        "y": 220,
                        "wires": [
                        "id": "2257718.fdda88e",
                        "type": "subflow",
                        "name": "Energy meter",
                        "info": "Converts input from arduino sketch, to a \nMysensors compatible protocol format, usable\nfor injecting into the message stream from\nnormal Mysensors nodes\n\nOutputs data as nodeId 99.",
                        "in": [],
                        "out": [
                                "x": 1020,
                                "y": 200,
                                "wires": [
                                        "id": "9d92273c.626dd8",
                                        "port": 0
                        "id": "12db17ce.ed24e8",
                        "type": "serial in",
                        "z": "2257718.fdda88e",
                        "name": "Meter input",
                        "serial": "acfe3226.5301d",
                        "x": 240,
                        "y": 200,
                        "wires": [
                                "e56f30b7.1a90d"
                        "id": "1dcfb48.fe2304c",
                        "type": "mysencap",
                        "name": "V_WATT node 99",
                        "nodeid": "99",
                        "childid": "1",
                        "subtype": "17",
                        "internal": "0",
                        "ack": false,
                        "msgtype": "1",
                        "presentation": false,
                        "presentationtype": "13",
                        "presentationtext": "Watt",
                        "fullpresentation": false,
                        "firmwarename": "",
                        "firmwareversion": "",
                        "x": 650,
                        "y": 160,
                        "wires": [
                                "9d92273c.626dd8"
                        "id": "f9b89df5.06476",
                        "type": "mysencap",
                        "name": "V_KWH node 99",
                        "nodeid": "99",
                        "childid": "1",
                        "subtype": "18",
                        "internal": "0",
                        "ack": false,
                        "msgtype": "1",
                        "presentation": true,
                        "presentationtext": "Kwh",
                        "fullpresentation": true,
                        "firmwarename": "MeterNode",
                        "firmwareversion": "0.1",
                        "x": 650,
                        "y": 200,
                        "wires": [
                                "9d92273c.626dd8"
                        "name": "",
                        "x": 890,
                        "y": 200,
                        "wires": [
                        "id": "e56f30b7.1a90d",
                        "type": "function",
                        "name": "Split meter data",
                        "func": "var m=msg.payload.split(';');\nvar msg1 = {payload:m[0]};\nvar msg2 = {payload:m[1]/1000};\nvar msg3 = {payload:m[1]};\nreturn [msg1, msg2, msg3];",
                        "outputs": "3",
                        "noerr": 0,
                        "x": 420,
                        "y": 200,
                        "wires": [
                                "1dcfb48.fe2304c"
                                "f9b89df5.06476"
                                "dfd92894.2026d8",
                                "11f1e54.721221b"
                        "id": "dfd92894.2026d8",
                        "type": "file",
                        "name": "meter counter output to file",
                        "filename": "/var/tmp/meascache.txt",
                        "createDir": false,
                        "overwriteFile": "true",
                        "x": 680,
                        "y": 280,
                        "wires": []
                        "id": "11f1e54.721221b",
                        "type": "mysencap",
                        "name": "V_VAR1 (Wh node 99)",
                        "nodeid": "99",
                        "childid": "10",
                        "subtype": "24",
                        "internal": 0,
                        "ack": false,
                        "msgtype": "1",
                        "presentationtype": 0,
                        "presentationtext": "",
                        "firmwarename": "",
                        "x": 660,
                        "y": 240,
                        "wires": [
                                "9d92273c.626dd8"
                        "id": "acfe3226.5301d",
                        "type": "serial-port",
                        "z": "",
                        "serialport": "/dev/ttyUTILITY",
                        "serialbaud": "115200",
                        "databits": "8",
                        "parity": "none",
                        "stopbits": "1",
                        "newline": "\\n",
                        "bin": "false",
                        "out": "char",
                        "addchar": true
                        "id": "67deb464.98214c",
                        "type": "tab",
                        "label": "Mysensors"
                        "id": "5b8bba4c.a47444",
                        "name": "Mysensors NRF",
                        "serial": "821a7286.7de59",
                        "x": 200,
                        "y": 460,
                        "wires": [
                                "a056d087.fb87f",
                                "8cb827f.b90b8d8"
                        "id": "47b5936e.b84a6c",
                        "type": "serial out",
                        "x": 1340,
                        "y": 180,
                        "wires": []
                        "id": "4755dfb8.b8aa2",
                        "name": "Domoticz",
                        "serial": "b5105521.4aefa8",
                        "x": 1320,
                        "y": 420,
                        "wires": []
                        "id": "8b4a855.f74b578",
                        "type": "debug",
                        "name": "Mysensors in",
                        "active": false,
                        "console": "false",
                        "complete": "true",
                        "x": 1110,
                        "y": 340,
                        "wires": []
                        "id": "8caee560.735118",
                        "type": "subflow:2257718.fdda88e",
                        "x": 190,
                        "y": 640,
                        "wires": [
                                "44592b43.bba6d4",
                                "d7b40093.e136f"
                        "id": "44592b43.bba6d4",
                        "type": "debug",
                        "name": "Energy meter output",
                        "active": false,
                        "console": "false",
                        "complete": "true",
                        "x": 420,
                        "y": 640,
                        "wires": []
                        "id": "9e471178.61b8f",
                        "type": "subflow:bed2e35d.412d2",
                        "name": "",
                        "x": 420,
                        "y": 220,
                        "wires": [
                                "173aba02.e8c546",
                                "9aecc18f.21f6d"
                        "id": "9bdc2a5b.6423d8",
                        "name": "Domoticz out",
                        "x": 1110,
                        "y": 420,
                        "wires": [
                                "4755dfb8.b8aa2"
                        "id": "9ebb1391.6144f",
                        "type": "debug",
                        "name": "gw debug",
                        "active": false,
                        "console": "false",
                        "complete": "true",
                        "x": 1320,
                        "y": 480,
                        "wires": []
                        "id": "49c6c17b.b6394",
                        "type": "subflow:4c13992e.b3ec68",
                        "x": 1110,
                        "y": 480,
                        "wires": [
                                "9ebb1391.6144f"
                        "id": "602db35f.9fd24c",
                        "name": "Domoticz (20)",
                        "x": 190,
                        "y": 220,
                        "wires": [
                                "9e471178.61b8f"
                        "id": "173aba02.e8c546",
                        "type": "debug",
                        "name": "Domoticz in",
                        "active": false,
                        "console": "false",
                        "complete": "payload",
                        "x": 650,
                        "y": 180,
                        "wires": []
                        "id": "3ff64036.ae116",
                        "type": "subflow:9b272654.9ad688",
                        "name": "InfluxDB",
                        "x": 1100,
                        "y": 380,
                        "wires": [
                                "aec232d3.2860b"
                                "1d454a20.ff7ae6"
                        "id": "aec232d3.2860b",
                        "type": "debug",
                        "name": "",
                        "active": false,
                        "console": "false",
                        "complete": "true",
                        "x": 1310,
                        "y": 340,
                        "wires": []
                        "id": "a056d087.fb87f",
                        "type": "change",
                        "name": "mark NRF",
                        "rules": [
                                "t": "set",
                                "p": "radio",
                                "pt": "msg",
                                "to": "nrf",
                                "tot": "str"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 390,
                        "y": 480,
                        "wires": [
                                "581b2ac8.2248c4"
                        "id": "ba16f31f.9adc5",
                        "type": "change",
                        "name": "mark RFM",
                        "rules": [
                                "t": "set",
                                "p": "radio",
                                "pt": "msg",
                                "to": "rfm",
                                "tot": "str"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 390,
                        "y": 520,
                        "wires": [
                                "581b2ac8.2248c4"
                        "id": "5990dc86.7a2ef4",
                        "type": "function",
                        "name": "net detect",
                        "func": "var net = flow.get('network') || {};\nvar msg2 = {};\nnet[msg.nodeId] = msg.radio;\nflow.set('network', net);\nmsg2.payload = net;\nreturn [msg, msg2];",
                        "outputs": "2",
                        "noerr": 0,
                        "x": 720,
                        "y": 500,
                        "wires": [
                                "1202b756.eb6449"
                                "ee23ee4a.b5f14"
                        "id": "ee23ee4a.b5f14",
                        "type": "debug",
                        "name": "",
                        "active": false,
                        "console": "false",
                        "complete": "false",
                        "x": 890,
                        "y": 520,
                        "wires": []
                        "id": "581b2ac8.2248c4",
                        "name": "",
                        "x": 570,
                        "y": 500,
                        "wires": [
                                "5990dc86.7a2ef4",
                                "b10cb69c.3e3d18",
                                "ea57b38e.eecb5"
                        "id": "1202b756.eb6449",
                        "name": "",
                        "x": 890,
                        "y": 480,
                        "wires": [
                                "8b4a855.f74b578",
                                "49c6c17b.b6394",
                                "9bdc2a5b.6423d8",
                                "3ff64036.ae116"
                        "id": "22f329c0.24f896",
                        "type": "function",
                        "name": "Net switch",
                        "func": "var net = flow.get('network');\nmsg_nrf = null;\nmsg_rfm = null;\nmsg_nodered = null;\nif (msg.nodeId in net) {\n    var network = net[msg.nodeId];\n    if (network == 'rfm') msg_rfm = msg;\n    if (network == 'nrf') msg_nrf = msg;\n    if (network == 'nodered') msg_nodered = msg;\n} else {\n    msg_nrf = msg;\n    msg_rfm = msg;\n    msg_nodered = msg;\n}\nreturn [msg_nrf,msg_rfm, msg_nodered];\n",
                        "outputs": "3",
                        "noerr": 0,
                        "x": 890,
                        "y": 220,
                        "wires": [
                                "56c9c62f.f1cbc8"
                                "4c477db.4619e84"
                        "id": "9aecc18f.21f6d",
                        "name": "",
                        "x": 650,
                        "y": 220,
                        "wires": [
                                "22f329c0.24f896",
                                "b10cb69c.3e3d18"
                        "id": "56c9c62f.f1cbc8",
                        "name": "",
                        "x": 1110,
                        "y": 180,
                        "wires": [
                                "47b5936e.b84a6c",
                                "932ebb67.4968d8"
                        "id": "4c477db.4619e84",
                        "name": "",
                        "x": 1110,
                        "y": 240,
                        "wires": [
                                "6b2fe680.509218",
                                "aac8db1a.8aa468"
                        "id": "932ebb67.4968d8",
                        "type": "debug",
                        "name": "msg_nrf",
                        "active": false,
                        "console": "false",
                        "x": 1320,
                        "y": 140,
                        "wires": []
                        "id": "6b2fe680.509218",
                        "type": "debug",
                        "name": "msg_rfm",
                        "active": false,
                        "console": "false",
                        "x": 1320,
                        "y": 280,
                        "wires": []
                        "id": "8919748d.f19738",
                        "type": "debug",
                        "name": "RFM Input",
                        "active": false,
                        "console": "false",
                        "x": 390,
                        "y": 560,
                        "wires": []
                        "id": "8155e57b.a7b2e8",
                        "name": "Mysensors RFM",
                        "serial": "48886e04.c4cc6",
                        "x": 200,
                        "y": 540,
                        "wires": [
                                "ba16f31f.9adc5",
                                "8919748d.f19738"
                        "id": "aac8db1a.8aa468",
                        "x": 1340,
                        "y": 240,
                        "wires": []
                        "id": "8cb827f.b90b8d8",
                        "type": "debug",
                        "name": "NRF input",
                        "active": false,
                        "console": "false",
                        "x": 380,
                        "y": 440,
                        "wires": []
                        "id": "b10cb69c.3e3d18",
                        "type": "link out",
                        "name": "UI link",
                        "links": [
                            "2f8a6093.73ef7",
                            "6d7cc489.0bb81c",
                            "ad2dd4f0.d2c718",
                            "d6fb4a23.fcf218"
                        "x": 755,
                        "y": 320,
                        "wires": []
                        "id": "cc31c979.e15578",
                        "type": "link in",
                        "name": "",
                        "links": [
                            "5d82dd49.5350d4"
                        "x": 755,
                        "y": 360,
                        "wires": [
                                "1202b756.eb6449",
                                "22f329c0.24f896"
                        "id": "d7b40093.e136f",
                        "type": "change",
                        "name": "mark nodered",
                        "rules": [
                                "t": "set",
                                "p": "radio",
                                "pt": "msg",
                                "to": "nodered",
                                "tot": "str"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 400,
                        "y": 600,
                        "wires": [
                                "581b2ac8.2248c4"
                        "id": "1d454a20.ff7ae6",
                        "type": "link out",
                        "name": "Trigger KWH to dashboard",
                        "links": [
                            "1e4f3d9a.978582"
                        "x": 1275,
                        "y": 380,
                        "wires": []
                        "id": "ea57b38e.eecb5",
                        "type": "debug",
                        "name": "",
                        "active": false,
                        "console": "false",
                        "complete": "true",
                        "x": 710,
                        "y": 580,
                        "wires": []
                        "id": "821a7286.7de59",
                        "z": "",
                        "serialport": "/dev/ttyNRF24",
                        "databits": "8",
                        "parity": "none",
                        "stopbits": "1",
                        "newline": "\\n",
                        "bin": "false",
                        "out": "char",
                        "addchar": true
                        "id": "b5105521.4aefa8",
                        "serialport": "/dev/ttyS80",
                        "databits": "8",
                        "parity": "none",
                        "stopbits": "1",
                        "newline": "\\n",
                        "bin": "false",
                        "out": "char",
                        "addchar": true
                        "id": "48886e04.c4cc6",
                        "serialport": "/dev/ttyRFM69",
                        "databits": "8",
                        "parity": "none",
                        "stopbits": "1",
                        "newline": "\\n",
                        "bin": "false",
                        "out": "char",
                        "addchar": true
                  tbowmoT
                  tbowmoT
                  tbowmo
                  @gohan
                  In theory it should work, as you can set node-red up to receive MQTT messages, which could then be manipulated, and send off to domoticz (if needed).
                  I think that @Anticimex made some experiments with mqtt/ethernet gateways using node-red. But can't remember details..
                  AnticimexA 1 Reply Last reply
                  • tbowmoT tbowmo
                    @gohan
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @tbowmo @gohan I made some experiments using ethernet gw (not MQTT) but gave it up because I could not get node-red to communicate with the GW on the same port for rx/tx.
                    I switched to a serial gw and that works just fine.
                    gohanG 1 Reply Last reply
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @wergeld
                      Btw. with the setup mentioned above, I have made a basic mysensors router in node-red, I can have two mysensors gateways attached to node-red (nRF24, and RFM69). I then keep track of which gateway I hear which node on, and use that to send commands through the right gateway, when domoticz want to turn on an actuator.
                      Domoticz only knows of one gateway. It just sees a bunch of nodes reporting data :)
                      • AnticimexA Anticimex
                        @Anticimex don't you think MQTT is better suited for this task? I am still quite new to node-red and haven't tikered with it much as learning javascript is low on the priority list :D
                        • tbowmoT tbowmo
                          @wergeld
                          node-red:
                                  "type": "subflow",
                                  "info": "",
                                  "in": [
                                          "x": 220,
                                          "y": 280,
                                          "wires": [
                                  "out": [
                                          "x": 960,
                                          "y": 240,
                                          "wires": [
                                                  "port": 0
                                          "x": 960,
                                          "y": 380,
                                          "wires": [
                                                  "port": 0
                                  "type": "function",
                                  "outputs": "3",
                                  "noerr": 0,
                                  "x": 790,
                                  "y": 280,
                                  "wires": [
                                          "c042117a.3fbdf"
                                          "f6bdc7dc.77c758"
                                  "name": "",
                                  "x": 350,
                                  "y": 280,
                                  "wires": [
                                          "55204322.aadfbc",
                                          "d6b8cf3e.6954c"
                                  "name": "",
                                  "measurement": "",
                                  "x": 1020,
                                  "y": 280,
                                  "wires": []
                                  "name": "Utility",
                                  "measurement": "",
                                  "x": 990,
                                  "y": 320,
                                  "wires": []
                                  "type": "function",
                                  "outputs": 1,
                                  "noerr": 0,
                                  "x": 560,
                                  "y": 340,
                                  "wires": [
                                          "55204322.aadfbc"
                                  "type": "influxdb",
                                  "port": "8086",
                                  "type": "influxdb",
                                  "port": "8086",
                                  "type": "subflow",
                                  "in": [
                                          "x": 105.5,
                                          "y": 240,
                                          "wires": [
                                  "out": [
                                          "x": 600,
                                          "y": 260,
                                          "wires": [
                                                  "port": 1
                                  "name": "",
                                  "x": 230,
                                  "y": 240,
                                  "wires": [
                                          "b57b1f3.f4a84e"
                                  "type": "function",
                                  "outputs": "3",
                                  "noerr": 0,
                                  "x": 430,
                                  "y": 240,
                                  "wires": [
                                          "dec3cc44.213c3",
                                          "d8b91167.2746f"
                                          "b521bd95.4ade4"
                                  "name": "",
                                  "x": 650,
                                  "y": 180,
                                  "wires": [
                                          "1b4decbb.e4b213"
                                  "type": "file",
                                  "createDir": false,
                                  "x": 1050,
                                  "y": 180,
                                  "wires": []
                                  "type": "function",
                                  "outputs": 1,
                                  "noerr": 0,
                                  "x": 830,
                                  "y": 180,
                                  "wires": [
                                          "38f9ab87.c70654"
                                  "type": "function",
                                  "outputs": 1,
                                  "noerr": 0,
                                  "x": 660,
                                  "y": 220,
                                  "wires": [
                                          "c44e1c28.3bb1e"
                                  "type": "template",
                                  "field": "payload",
                                  "fieldType": "msg",
                                  "x": 850,
                                  "y": 220,
                                  "wires": [
                                          "e9231639.16dce8"
                                  "twitter": "",
                                  "name": "Tweet",
                                  "x": 1030,
                                  "y": 220,
                                  "wires": []
                                  "type": "file",
                                  "createDir": false,
                                  "x": 840,
                                  "y": 300,
                                  "wires": []
                                  "name": "",
                                  "x": 650,
                                  "y": 300,
                                  "wires": [
                                          "b478903e.4b877"
                                  "type": "subflow",
                                  "in": [
                                          "x": 280,
                                          "y": 220,
                                          "wires": [
                                  "out": [
                                          "x": 1000,
                                          "y": 220,
                                          "wires": [
                                                  "port": 0
                                  "name": "",
                                  "x": 410,
                                  "y": 220,
                                  "wires": [
                                          "126152bf.ed9ead"
                                  "type": "function",
                                  "outputs": 1,
                                  "noerr": 0,
                                  "x": 640,
                                  "y": 220,
                                  "wires": [
                                          "91eb6b4c.6e1498"
                                  "name": "",
                                  "x": 870,
                                  "y": 220,
                                  "wires": [
                                  "type": "subflow",
                                  "in": [],
                                  "out": [
                                          "x": 1020,
                                          "y": 200,
                                          "wires": [
                                                  "port": 0
                                  "x": 240,
                                  "y": 200,
                                  "wires": [
                                          "e56f30b7.1a90d"
                                  "type": "mysencap",
                                  "nodeid": "99",
                                  "childid": "1",
                                  "subtype": "17",
                                  "internal": "0",
                                  "ack": false,
                                  "msgtype": "1",
                                  "firmwarename": "",
                                  "x": 650,
                                  "y": 160,
                                  "wires": [
                                          "9d92273c.626dd8"
                                  "type": "mysencap",
                                  "nodeid": "99",
                                  "childid": "1",
                                  "subtype": "18",
                                  "internal": "0",
                                  "ack": false,
                                  "msgtype": "1",
                                  "x": 650,
                                  "y": 200,
                                  "wires": [
                                          "9d92273c.626dd8"
                                  "name": "",
                                  "x": 890,
                                  "y": 200,
                                  "wires": [
                                  "type": "function",
                                  "outputs": "3",
                                  "noerr": 0,
                                  "x": 420,
                                  "y": 200,
                                  "wires": [
                                          "1dcfb48.fe2304c"
                                          "f9b89df5.06476"
                                          "dfd92894.2026d8",
                                          "11f1e54.721221b"
                                  "type": "file",
                                  "createDir": false,
                                  "x": 680,
                                  "y": 280,
                                  "wires": []
                                  "type": "mysencap",
                                  "nodeid": "99",
                                  "childid": "10",
                                  "subtype": "24",
                                  "internal": 0,
                                  "ack": false,
                                  "msgtype": "1",
                                  "firmwarename": "",
                                  "x": 660,
                                  "y": 240,
                                  "wires": [
                                          "9d92273c.626dd8"
                                  "z": "",
                                  "databits": "8",
                                  "parity": "none",
                                  "stopbits": "1",
                                  "newline": "\\n",
                                  "bin": "false",
                                  "out": "char",
                                  "addchar": true
                                  "type": "tab",
                                  "x": 200,
                                  "y": 460,
                                  "wires": [
                                          "a056d087.fb87f",
                                          "8cb827f.b90b8d8"
                                  "x": 1340,
                                  "y": 180,
                                  "wires": []
                                  "name": "Domoticz",
                                  "x": 1320,
                                  "y": 420,
                                  "wires": []
                                  "type": "debug",
                                  "active": false,
                                  "console": "false",
                                  "complete": "true",
                                  "x": 1110,
                                  "y": 340,
                                  "wires": []
                                  "x": 190,
                                  "y": 640,
                                  "wires": [
                                          "44592b43.bba6d4",
                                          "d7b40093.e136f"
                                  "type": "debug",
                                  "active": false,
                                  "console": "false",
                                  "complete": "true",
                                  "x": 420,
                                  "y": 640,
                                  "wires": []
                                  "name": "",
                                  "x": 420,
                                  "y": 220,
                                  "wires": [
                                          "173aba02.e8c546",
                                          "9aecc18f.21f6d"
                                  "x": 1110,
                                  "y": 420,
                                  "wires": [
                                          "4755dfb8.b8aa2"
                                  "type": "debug",
                                  "name": "gw debug",
                                  "active": false,
                                  "console": "false",
                                  "complete": "true",
                                  "x": 1320,
                                  "y": 480,
                                  "wires": []
                                  "x": 1110,
                                  "y": 480,
                                  "wires": [
                                          "9ebb1391.6144f"
                                  "x": 190,
                                  "y": 220,
                                  "wires": [
                                          "9e471178.61b8f"
                                  "type": "debug",
                                  "active": false,
                                  "console": "false",
                                  "x": 650,
                                  "y": 180,
                                  "wires": []
                                  "name": "InfluxDB",
                                  "x": 1100,
                                  "y": 380,
                                  "wires": [
                                          "aec232d3.2860b"
                                          "1d454a20.ff7ae6"
                                  "type": "debug",
                                  "name": "",
                                  "active": false,
                                  "console": "false",
                                  "complete": "true",
                                  "x": 1310,
                                  "y": 340,
                                  "wires": []
                                  "type": "change",
                                  "name": "mark NRF",
                                  "rules": [
                                          "t": "set",
                                          "p": "radio",
                                          "pt": "msg",
                                          "to": "nrf",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 390,
                                  "y": 480,
                                  "wires": [
                                          "581b2ac8.2248c4"
                                  "type": "change",
                                  "name": "mark RFM",
                                  "rules": [
                                          "t": "set",
                                          "p": "radio",
                                          "pt": "msg",
                                          "to": "rfm",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 390,
                                  "y": 520,
                                  "wires": [
                                          "581b2ac8.2248c4"
                                  "type": "function",
                                  "outputs": "2",
                                  "noerr": 0,
                                  "x": 720,
                                  "y": 500,
                                  "wires": [
                                          "1202b756.eb6449"
                                          "ee23ee4a.b5f14"
                                  "type": "debug",
                                  "name": "",
                                  "active": false,
                                  "console": "false",
                                  "x": 890,
                                  "y": 520,
                                  "wires": []
                                  "name": "",
                                  "x": 570,
                                  "y": 500,
                                  "wires": [
                                          "5990dc86.7a2ef4",
                                          "b10cb69c.3e3d18",
                                          "ea57b38e.eecb5"
                                  "name": "",
                                  "x": 890,
                                  "y": 480,
                                  "wires": [
                                          "8b4a855.f74b578",
                                          "49c6c17b.b6394",
                                          "9bdc2a5b.6423d8",
                                          "3ff64036.ae116"
                                  "type": "function",
                                  "outputs": "3",
                                  "noerr": 0,
                                  "x": 890,
                                  "y": 220,
                                  "wires": [
                                          "56c9c62f.f1cbc8"
                                          "4c477db.4619e84"
                                  "name": "",
                                  "x": 650,
                                  "y": 220,
                                  "wires": [
                                          "22f329c0.24f896",
                                          "b10cb69c.3e3d18"
                                  "name": "",
                                  "x": 1110,
                                  "y": 180,
                                  "wires": [
                                          "47b5936e.b84a6c",
                                          "932ebb67.4968d8"
                                  "name": "",
                                  "x": 1110,
                                  "y": 240,
                                  "wires": [
                                          "6b2fe680.509218",
                                          "aac8db1a.8aa468"
                                  "type": "debug",
                                  "name": "msg_nrf",
                                  "active": false,
                                  "console": "false",
                                  "x": 1320,
                                  "y": 140,
                                  "wires": []
                                  "type": "debug",
                                  "name": "msg_rfm",
                                  "active": false,
                                  "console": "false",
                                  "x": 1320,
                                  "y": 280,
                                  "wires": []
                                  "type": "debug",
                                  "active": false,
                                  "console": "false",
                                  "x": 390,
                                  "y": 560,
                                  "wires": []
                                  "x": 200,
                                  "y": 540,
                                  "wires": [
                                          "ba16f31f.9adc5",
                                          "8919748d.f19738"
                                  "x": 1340,
                                  "y": 240,
                                  "wires": []
                                  "type": "debug",
                                  "active": false,
                                  "console": "false",
                                  "x": 380,
                                  "y": 440,
                                  "wires": []
                                  "type": "link out",
                                  "name": "UI link",
                                  "links": [
                                      "2f8a6093.73ef7",
                                      "6d7cc489.0bb81c",
                                      "ad2dd4f0.d2c718",
                                      "d6fb4a23.fcf218"
                                  "x": 755,
                                  "y": 320,
                                  "wires": []
                                  "type": "link in",
                                  "name": "",
                                  "links": [
                                      "5d82dd49.5350d4"
                                  "x": 755,
                                  "y": 360,
                                  "wires": [
                                          "1202b756.eb6449",
                                          "22f329c0.24f896"
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "radio",
                                          "pt": "msg",
                                          "to": "nodered",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 400,
                                  "y": 600,
                                  "wires": [
                                          "581b2ac8.2248c4"
                                  "type": "link out",
                                  "links": [
                                      "1e4f3d9a.978582"
                                  "x": 1275,
                                  "y": 380,
                                  "wires": []
                                  "type": "debug",
                                  "name": "",
                                  "active": false,
                                  "console": "false",
                                  "complete": "true",
                                  "x": 710,
                                  "y": 580,
                                  "wires": []
                                  "z": "",
                                  "databits": "8",
                                  "parity": "none",
                                  "stopbits": "1",
                                  "newline": "\\n",
                                  "bin": "false",
                                  "out": "char",
                                  "addchar": true
                                  "databits": "8",
                                  "parity": "none",
                                  "stopbits": "1",
                                  "newline": "\\n",
                                  "bin": "false",
                                  "out": "char",
                                  "addchar": true
                                  "databits": "8",
                                  "parity": "none",
                                  "stopbits": "1",
                                  "newline": "\\n",
                                  "bin": "false",
                                  "out": "char",
                                  "addchar": true
                          W
                          W
                          wergeld
                          @tbowmo I feel I have a lot of reading to do...
                          Setting up my own custom dashboard has been on my todo list forever (I have the shell made and used the Domoticz API to pull in data but am not really satisfied at all with Domo's APIs). InfluxDB is neat but so, so, limited in my opinion (I do SQL Server big data analytics in the real world).
                            I want to pick a controller, but I don't want to jump in feet first only to find out later that it's somehow seriously flawed. Domoticz, Openhab, and Vera appear to be the most popular based on number of topics and posts. I think I can rule out Vera based on prior negative experience with it. So, I guess that makes it Domoticz vs. OpenHAB. Any reasons to prefer one over the other? The built-in graphing in Domoticz looks very appealing.
                            Bogus ExceptionB
                            Bogus ExceptionB
                            Bogus Exception
                            @NeverDie I tried for days. Too buggy, and not enough support. I landed with MyController, which takes advantage of MySensors, plus allows a lot of scripting, etc.
                            </$0.02>
                            "If you drop it and it breaks, it was good." ~ Mr. Lehr, my Electronics Vo-Tech teacher, on testing vacuum tubes...
                            -Arduinos (UNO, Nano, Pro-Mini, Mega, ...)
                            -ATTiny, ATMega, STM32
                            -Geek Channel: https://www.youtube.com/TheSalesEngineer
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @gohan which task? I have never used MQTT and I have not felt a need to use it so far.
                                @Anticimex I'm referring to the task of communicating between 2 or more platforms/devices: it was built for that. If I knew how to do it, I'd try to make it myself 😅
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @gohan ok, well I use node-red. It works for me, and I can easily hook in anything imaginable (including MQTT things) while also having the ability to easily inspect and manipulate the data as it flows through the grid. Perhaps MQTT offer that by itself. I don't know.
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    with node-red as middleware you can in theory filter nodes out that you won't let domoticz handle..
                                    Or run both domoticz and pidome (or another controller) in parallel, for example if you want to switch controller for some reason, then move things slowly over to the new platform. I have done this a couple of times, when I wanted to check out a new controller..
                                    MQTT could probably be used, as it can have multiple clients listen to the same data. I just want to get in between the mysensors network, and everything else, so I can manipulate data as I see fit. And that is possible with node-red. You don't need javascript knowledge for basic stuff.. As it's a graphical click and draw thing, and quite intuitive imho.
                                    • W wergeld
                                      I have used Domoticz for about 2+ years. I like it a lot but wish for something...more.
                                      Pros:
                                      Quick setup for mysensors nodes
                                      One-stop location for data storage and data presentation
                                      Android app is very good
                                      Customizable scripting options once you leave their scripting environment and use API values.
                                      Cons:
                                      Event scripting (lua? really?) needs more advanced features.
                                      Has interesting issue lately where if I lose power to the Pi I lose all data back to May 23 of this year. I have a cron job that backs up the DB nightly and send to my NAS so I can lose hours instead of days. But, man, is this annoying - I have not tracked down the reason yet.
                                      Graphs are just sort of...there. I do data viz at my job and use Highcharts (Domoticz' charting library) daily. The charts in Domoticz need a lot of work.
                                      I have started writing my own front end that calls data from the Domoticz API (as well as other APIs) for showing info in our house. Nothing crazy cool, but it will eventually work fine for me.
                                      Which brings me to the point - there is no perfect controller. You need to find the one that is right for you.
                                      ronnyandreR
                                      ronnyandreR
                                      ronnyandre
                                      @wergeld said in Are folks here happy with Domoticz?:
                                      You should check out dzVents which makes LUA-scripting much more powerful and even simpler.
                                      Newbie with RPi and Domoticz, trying to automate my home.
                                      • tbowmoT tbowmo
                                        @tbowmo I played with it few months ago and indeed it is simple click and drag, but when you want to do real things you need to know javascript
                                        • ronnyandreR ronnyandre
                                          tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @ronnyandre
                                          It seems that dzVents are part of domoticz now.. I have it in ./scripts/dzVents, and looking at the domoticz repository, it's also included there..
