  3. NRF24L01 SMD to DIP converter
19 Posts 6 Posters 6.9k Views 4 Watching
  • B
    B
    bilbolodz
    I'm looking for PCB which allow mount NRF24K01 SMD modules (version with PA and without) into existing Mysensors device prepered for DIP version of NRF. Any ideas?
    mfalkviddM kalinaK 2 Replies Last reply
    • B bilbolodz
      @bilbolodz like this? https://www.openhardware.io/view/297/SMDnRF24_adapter
      B 1 Reply Last reply
        B
        B
        bilbolodz
        @mfalkvidd Yes but it's ONLY for "normal version of SMD". Versions with PA have a little different pinout.
        E 1 Reply Last reply
        • Nca78N
          Nca78N
          And what is your final goal with that ?
          If you want cdebyte makes some pa lna nrf 24 modules with PCB antenna which is better than chip antenna, with both SMD and through hole connectors.
          • B bilbolodz
            kalinaK
            kalinaK
            kalina
            @bilbolodz said in NRF24L01 SMD to DIP converter:
            Any ideas?
            Yes, I have one - https://www.openhardware.io/view/449/DIP-to-SMD-NRF24L01-adapter
            • kalinaK kalina
              Any ideas?
              B
              B
              bilbolodz
              @kalina Cheater ;-)
              kalinaK 1 Reply Last reply
              • B bilbolodz
                @kalina Cheater ;-)
                kalinaK
                kalinaK
                kalina
                @kalina Cheater ;-)
                Is this thanks for the adapter? :-)
                B 2 Replies Last reply
                • kalinaK kalina
                  @kalina Cheater ;-)
                  B
                  B
                  bilbolodz
                  @kalina YEP :-)
                  • kalinaK kalina
                    @kalina Cheater ;-)
                    B
                    B
                    bilbolodz
                    wrote on last edited by bilbolodz
                    @kalina Now "for real": I will be more than happy if you provide gerber files for PCB factory and thank you very much for you work.
                    • B bilbolodz
                      kalinaK
                      kalinaK
                      kalina
                      Already added to project files.
                      • kalinaK kalina
                        B
                        B
                        bilbolodz
                        @kalina Thanks.
                        At the begging quick question: are you sure that all is fine with drills? Some gerber renders in PCB factories show strange results (pcbs.io and oshpark.com).
                        I've maid a quick research with comparison of cost (I've always took "the cheapest product and shipment option):
                        • www.seeedstudio.com 10 pcs 4.90 USD + shipment 11.30 USD - (PCB max size 100 mm x 100m)
                        • pcbs.io 4 pcs 1.50 USD + shipment free (probably problems with drills need to be checked more throughly)
                        • oshpark.com 3 pcs 1.85USD + shipment free (probably problems with drills need to be checked more throughly)
                        • dirtypcbs.com "protopack" (at least 10 pcs maybe more) 11.95 USD + 2 USD shipment (PCB max size 50mm x 50m, factory complaining after ZIP upload: "No board outline (.GML/.GKO/.GBR) file found")
                        Of course it depends of "someone needs" but I think it could be a good idea to prepare "panelized version" with a few pcs of PCB which fits into PCB factory needs (dirtypcbs.com: 5cmx5cm, www.seeedstudio.com 10cmx10cm) for a "batch order" it should be more costs efficient.
                        • B bilbolodz
                          @kalina Thanks.
                          kalinaK
                          kalinaK
                          kalina
                          wrote on last edited by kalina
                          Yes.
                          For example, 20 pcs with delivery (to Poland) cost 11$ on PCBWay.
                          • kalinaK kalina
                            Yes.
                            B
                            B
                            bilbolodz
                            @kalina said in NRF24L01 SMD to DIP converter:
                            I've never used PCBWay but I will add it to "my list".
                            • B
                              B
                              bilbolodz
                              What's the size of these PCB?
                              • Nca78N
                                Nca78N
                                10*10 cm on PCBWay
                                You can also add elecrow, 5 boards with a max of 10*10cm for 5$, and I think I have seen a 5$ China Post shipping.
                                • B
                                  B
                                  bilbolodz
                                  I mean: what is the size of @kalina designed PCB.
                                  • B bilbolodz
                                    kalinaK
                                    kalinaK
                                    kalina
                                    If you need get size for ordering - you can specify 15.2x15.5mm.
                                    • B bilbolodz
                                      E
                                      E
                                      emc2
                                      @bilbolodz Actually a PA+LNA version is on github (untested)
                                      https://github.com/emc2cube/SMDnRF24_adapter/tree/master/PA_LNA
                                      But yes, I did not update the openhardware part yet.
                                      • A
                                        A
                                        antonio_clinton
                                        Banned
                                        If you want to order PCB, maybe try -Removed by moderator-. They provide rapid prototyping.
                                        Their minimum order is at least one board, the board is of good quality.
                                        To Poland about four or five days.
                                        They now have activities. Can be paid on delivery.
