  3. Why I quit using MySensors for actuators
55 Posts 19 Posters 17.7k Views 25 Watching
  • K korvad
    @Sergio-Rius I have a similar behaviour with 2 of my relay actuators. Could you share your sketch?
    Sergio RiusS Offline
    Sergio Rius
    @korvad The sketch is a mess and I'm sure what I'm doing with 4 relays could be made with only two, but the changes I incorporated where basically:
      refreshStatus();
      // Don't do anything else during movement
      if (CurrentStatus == GOINGUP || CurrentStatus == GOINGDOWN) return;
    And in receive:
      static uint32_t next_cmd = 0;
      switch (message.type) {
      case V_STATUS:
        if (message.sensor == CHILD_ID_TOGGLE) {
    #ifdef _DEBUG
          DEBUGPLN("*** RECEIVED TOGGLE *************************");
          // Avoid controller command echoes.
          const uint32_t now = millis();
          if (PENDING(now, next_cmd)) {
    #ifdef _DEBUG
            DEBUGPLN("Too much commands in a short while! Ignoring.");
            return;
          next_cmd = now + MIN_RX_INTERVAL;
    Y K 2 Replies Last reply
    • Sergio RiusS Sergio Rius
        refreshStatus();
      And in receive:
        case V_STATUS:
      #ifdef _DEBUG
      #ifdef _DEBUG
              return;
      Y Offline
      Y Offline
      @Sergio-Rius Can you explain why you send a toggle to the door instead of up or down?
      A toggle message that is received multiple times will move the door in an arbitrary direction...
      Sergio RiusS 1 Reply Last reply
      • N Offline
        N Offline
        #43
        Were you previously debouncing the button press? Also, is the module on the same electrical circuit as the garage door motor? I wonder whether it's a power/noise isolation issue that comes into play because of the heavy motor.
        • Y Yveaux
          Sergio Rius
          @Yveaux I initially have it designed for open/close commands. But I was having too much trouble with sync when messages where lost.
          Now it simply ignores the type of command and relies more on controlling its own state.
          That's the complex part of the sketch.
          But it works as factory default.
          • N NeverDie
            Sergio Rius
            @NeverDie it doesn't have any physical button. It's always actuated through the controller.
            Also the door motor is on a completely separated circuit. Has its own PSU (ac) and it's independently activated with relays through opto-isolators.
            It cuts motor power when it's not used.
            Don't miss understand, is working very well. I only presented it as an example for an actuator that was giving trouble but that was made to work.
            N 1 Reply Last reply
              N Offline
              N Offline
              #46
              @Sergio-Rius said in Why I quit using MySensors for actuators:
              If I'm not mistaken, relay contacts can bounce too, just like a button. Well, anyway, just water under the bridge at this point it sounds like.
                  refreshStatus();
                And in receive:
                  case V_STATUS:
                #ifdef _DEBUG
                #ifdef _DEBUG
                        return;
                K Offline
                K Offline
                korvad
                @Sergio-Rius thx, will try to adapt your sketch to my needs.
                • N NeverDie
                  Sergio Rius
                  @NeverDie As the relays only activate the main motor power supply and controls start&stop and direction, bouncing is not a problem.
                  Perhaps you where thinking on an arduino actuating the door mechanism button?
                  • alowhumA Offline
                    alowhumA Offline
                    alowhum
                    @dakipro said in Why I quit using MySensors for actuators:
                    I understand the principle, number of sent packets should match number of received ones per node :)
                    I thought it was perhaps already implemented on node/gateway level. I guess one could always send Text or some custom label and handle it in controller, but having it integrated in gateway itself would be awesome :)
                    wait, what?
                    I thought MySensors already implemented this! It doesn't?
                    I want to use mysensors to turn a heater on and off. That's serious stuff. I thought MySensors went beyond 433 stuff because if made sure that messages arrived?
                    • alowhumA alowhum
                      wait, what?
                      N Offline
                      N Offline
                      @alowhum if you use ACK you know if message arrived or not. MySensors will resend message a few times if it fails (there's a #define for this I think) but not forever. If it's critical you can handle the false when it's returned in your code and resend the message after a little delay, and send yourself a warning/alert in the end if the node is unreachable).
                      alowhumA 1 Reply Last reply
                      • N Nca78
                        alowhumA Offline
                        alowhumA Offline
                        alowhum
                        @nca78 Thanks for the explananation! Do you perhaps know of an example sketch that has good example code for this? I haven't come accross it.
                        • alowhumA alowhum
                          N Offline
                          N Offline
                          @alowhum I made a test with the scipt of a remote control switch. I will look for it but it's really not some advanced programming :)
                          • N Nca78
                            alowhumA Offline
                            alowhumA Offline
                            alowhum
                            @nca78 Well, anything is helpful! Thanks!
                            • JohnRobJ Offline
                              JohnRobJ Offline
                              JohnRob
                              Hi, I know I'm a little late to this thread. I'm just starting with MySensors and am learning by reading the posts.
                              Currently I am waiting for hardware for my 1st gateway so I am not encumbered by details.
                              I notice in all the reported cases the "problem" node is AC powered, while many of the "good" sensor nodes are battery powered. Could this be significant? It would be interesting if someone with a "problem" actuator node could put a battery operated sensor node in the same area.
                              Just a thought.
                              • JohnRobJ JohnRob
                                Just a thought.
                                N Offline
                                N Offline
                                @johnrob said in Why I quit using MySensors for actuators:
                                the problem is an actuator node has to listen to the radio constantly and can't sleep, so it can't last long on batteries...
