  3. How do I get multiple different mock barometers?
53 Posts 6 Posters 9.9k Views 5 Watching
    @NeverDie for a node I think the bottleneck is the speed of the air transfer. Sending a message takes about 1ms at the default setting of 250kbps. But a busy gateway might benefit from the higher processing speeds on nRF52832.
    NeverDieN Offline
    NeverDieN Offline
    #41
    @mfalkvidd said in How do I get multiple different mock barometers?:
    Does it default to 250kbps to compensate for the range problems that the nRF24L01 has? I'm planning to bump mine up to 2mbps if at all possible. That might save appreciably on battery life.
    • NeverDieN Offline
      NeverDieN Offline
      I suppose the
      wait(long_wait)
      isn't so bad a power drain if it's actually sleeping rather than busy-waiting for 500ms.
      • rmtuckerR rmtucker
        @NeverDie
        Here is a little sketch that compiles on the NRF5.
        //#define MY_DEBUG
        #define MY_RADIO_NRF5_ESB
           @def MY_NRF5_ESB_PA_LEVEL
           @brief Default nRF5 PA level. Override in sketch if needed.
           - NRF5_PA_MIN = -40dBm
           - NRF5_PA_LOW = -16dBm
           - NRF5_PA_HIGH = 0dBm
           - NRF5_PA_MAX = 4dBm
        #define MY_NRF5_ESB_PA_LEVEL (NRF5_PA_MAX)
        #define MY_NRF5_ESB_CHANNEL (76)
        #define MY_NRF5_ESB_MODE (NRF5_250KBPS)
        #define MY_NODE_ID 10
        #define VOLTAGE     0
        float vcc = (hwCPUVoltage() / 1000.0);
        MyMessage VoltageMsg(VOLTAGE, V_VOLTAGE);
          sendSketchInfo("General sensor", "1.0");
          present(VOLTAGE, S_MULTIMETER);
        //  Serial.begin(115200);
        //  while (!Serial) ; // wait for Arduino Serial Monitor
          send(VoltageMsg.set(vcc, 3));
        //  Serial.print(F("Voltage = "));
        //  Serial.print(vcc, 3);
        //  Serial.println(F("v"));
          sleep(60000);
        NeverDieN Offline
        NeverDieN Offline
        #43
        @rmtucker said in How do I get multiple different mock barometers?:
        Just now noticing that your definitions:
        can also be set in myconfig.h.
        Strangely, myconfig.h defaults to max Tx power on the nrf52, but not max Tx power on the nrf24. Not sure why, especially since, if anything, the nRF24 needs it more.
        So, I just now changed myconfig.h to put everything at max Tx power and 2mbps ota datarate. A lot of the nrf24 fake chips don't even run at 250kbps.
        rmtuckerR 1 Reply Last reply
          Do mean the fake chips need to run at higher datarate?
          NeverDieN 1 Reply Last reply
          • NeverDieN NeverDie
            rmtuckerR Offline
            rmtuckerR Offline
            rmtucker
            @NeverDie
            Ye i just like all the settings at the beginning of my sketches etc,it reminds me if i have changed channel number etc.
              NeverDieN Offline
              NeverDieN Offline
              @gohan said in How do I get multiple different mock barometers?:
              All the fakes I've encountered can handle 1mbps and 2mbps.
              • NeverDieN Offline
                NeverDieN Offline
                Not sure why, but by upgrading to 2mbps datarate from the previous default of just 250kbps, I'm able to reduce LONG_WAIT to 0 without incurring packet losses. Go figure.
                • NeverDieN Offline
                  NeverDieN Offline
                  For the SHORT_WAIT, 10ms seems adequate on an nRF52832. Not sure where it hangs if the SHORT_WAIT is reduced too much lower than that though.
                  gohanG 1 Reply Last reply
                    @NeverDie my question was if thay handle higher speeds better than the lowest since you said "A lot of the nrf24 fake chips don't even run at 250kbps"
                      NeverDieN Offline
                      NeverDieN Offline
                      I'm not understanding your question.
                      • NeverDieN Offline
                        NeverDieN Offline
                        What does it mean when the Domoticz log looks like this?
                        2017-08-11 08:11:20.670 MySensors: Node: 1, Sketch Version: v0.5
                        2017-08-11 08:11:24.053 MySensors: Node: 1, Sketch Name: MockMySensors
                        2017-08-11 08:11:24.068 MySensors: Node: 1, Sketch Version: v0.5
                        2017-08-11 08:11:27.454 MySensors: Node: 1, Sketch Name: MockMySensors
                        2017-08-11 08:11:27.470 MySensors: Node: 1, Sketch Version: v0.5
                        2017-08-11 08:11:30.870 MySensors: Node: 1, Sketch Name: MockMySensors
                        2017-08-11 08:11:30.887 MySensors: Node: 1, Sketch Version: v0.5
                        2017-08-11 08:11:34.245 MySensors: Node: 1, Sketch Name: MockMySensors
                        2017-08-11 08:11:34.260 MySensors: Node: 1, Sketch Version: v0.5
                        2017-08-11 08:11:37.650 MySensors: Node: 1, Sketch Name: MockMySensors
                        2017-08-11 08:11:37.666 MySensors: Node: 1, Sketch Version: v0.5
                        2017-08-11 08:11:41.036 MySensors: Node: 1, Sketch Name: MockMySensors
                        2017-08-11 08:11:41.051 MySensors: Node: 1, Sketch Version: v0.5
                        2017-08-11 08:11:44.375 MySensors: Node: 1, Sketch Name: MockMySensors
                        2017-08-11 08:11:44.391 MySensors: Node: 1, Sketch Version: v0.5
                        2017-08-11 08:11:47.800 MySensors: Node: 1, Sketch Name: MockMySensors
                        2017-08-11 08:11:47.816 MySensors: Node: 1, Sketch Version: v0.5
                        2017-08-11 08:11:51.185 MySensors: Node: 1, Sketch Name: MockMySensors
                        2017-08-11 08:11:51.200 MySensors: Node: 1, Sketch Version: v0.5
                        2017-08-11 08:11:54.583 MySensors: Node: 1, Sketch Name: MockMySensors
                        2017-08-11 08:11:54.599 MySensors: Node: 1, Sketch Version: v0.5
                        2017-08-11 08:11:58.005 MySensors: Node: 1, Sketch Name: MockMySensors
                        2017-08-11 08:11:58.021 MySensors: Node: 1, Sketch Version: v0.5
                        2017-08-11 08:12:01.384 MySensors: Node: 1, Sketch Name: MockMySensors
                        2017-08-11 08:12:01.401 MySensors: Node: 1, Sketch Version: v0.5
                        Plainly, it's caught in a loop of some kind and never receives the sensor values.
                        • NeverDieN Offline
                          NeverDieN Offline
                          For some reason, downgrading from 2mbps back down to 250kbps solved the above problem.
                          • NeverDieN Offline
                            NeverDieN Offline
                            Fortunately, 1mbps seems to work, even if 2mbps doesn't.
                            11.9k
                            113.3k
