  3. Domoticz
  4. Problem with Domoticz
12 Posts 3 Posters 4.2k Views 3 Watching
  • A Offline
    A Offline
    arduino_89_89
    Hi everyone, I wanted to know how ever whenever the PC reboots, I also change the com port. And why when I break the gateway, are the sensors no longer connected? It's okay to restart them all to let them read.
    P 1 Reply Last reply
      The sensors should reconnect automatically when the gateway is back online. If not you need to look at the serial logs of node and gateway to check what is going on.
      • A Offline
        A Offline
        arduino_89_89
        I understand, but the only sensors that connect are: The temperature sensor and the gas sensor, which send periodic signals. My system is structured on 3 floors. The first floor has the Gateway, and off the first floor has a Node Repeater. Then the second floor has another Node Repeater and has 2 Relay Nodes. And finally the Third Floor with another repeater and 2 sensors, Gas and Temp / Hum.
          Without the serial logs of when you are experiencing the problem, it is kind of impossible to help.
          • A Offline
            A Offline
            arduino_89_89
            But should I use watchdog? To reset nodes automatically every day?
              That is a workaround, it is not a solution. You need to debug the issue and find the root cause. Also posting the logs can be helpful for us to help
              • A Offline
                A Offline
                arduino_89_89
                How do I send it to you? It's too long.
                  Just paste it here using a different "insert code block" tag for each log, also try to cleanup the logs so they are not hundreds of lines each.
                  • A Offline
                    A Offline
                    arduino_89_89
                    It's too long.
                    • A Offline
                      A Offline
                      arduino_89_89
                      0_1502269526374_Log.txt
                      • A Offline
                        A Offline
                        arduino_89_89
                        0_1502270247458_Log.txt
                        • A arduino_89_89
                          P Offline
                          P Offline
                          pjr
                          @arduino_89_89 said in Problem with Domoticz:
                          What environment? Could this help? https://www.domoticz.com/wiki/Assign_fixed_device_name_to_USB_port
