  3. MQTT Gateway to Sensor communication problem
3 Posts 3 Posters 1.6k Views 1 Watching
  • B Offline
    B Offline
    Brian787
    I have an Arduino UNO with W5100 Ethernet Shield and NRF24L01+ configured as a MQTT Gateway and I can communicate with the MQTT Broker. However, I cannot communicate (via the radio) with a humidity sensor.
    Debugging is turned on in MyConfig.h
    I have tried multiple NRF24L01+
    I have tried powering the gateway NRF24L01+ from another arduino uno (just using it as a power supply and connecting the grounds of the 2 boards).
    I suspect I have a mismatch between the wiring and the software, but I am new to this and nothing I have found by searching the forums as led me to a solution.
    Please help.
    For the MQTT Gateway,
    The NRF24L01+ is wired through the Ethernet shield to the UNO as follows:
    GND to GND
    VCC to 3V3
    CE to 5
    CSN to 6
    MOSI to A1
    MISO to A2
    SCK to A0
    IRQ not connected
    The defines in MQTTGateway.ino are as follows:
    #define RADIO_CE_PIN 5 // radio chip enable
    #define RADIO_SPI_SS_PIN 6 // radio SPI serial select
    #define RADIO_ERROR_LED_PIN A2 // Error led pin
    #define RADIO_RX_LED_PIN A1 // Receive led pin
    #define RADIO_TX_LED_PIN A0 // the PCB, on board LED */
    The relevant parts in RF24_config.h as follows:
    #define SOFTSPI // Requires library from https://github.com/greiman/DigitalIO
    const uint8_t SOFT_SPI_MISO_PIN = 16;
    const uint8_t SOFT_SPI_MOSI_PIN = 15;
    const uint8_t SOFT_SPI_SCK_PIN = 14;
    When I start the gateway, I get the following output:
    Started!
    0;0;3;0;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0:
    0;0;3;0;9;version mismatch
    When I start a humidity sensor which is wired (triple checked) and programmed per the instructions, I get the following serial output:
    send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
    sensor started, id 255
    req node id
    req node id
    req node id
    req node id
    req node id
    req node id
    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
    req node id
    T: 20.00
    req node id
    H: 34.00
    B 1 Reply Last reply
    • B Brian787
      Please help.
      GND to GND
      VCC to 3V3
      CE to 5
      CSN to 6
      MOSI to A1
      MISO to A2
      SCK to A0
      IRQ not connected
      Started!
      req node id
      req node id
      req node id
      req node id
      req node id
      req node id
      req node id
      T: 20.00
      req node id
      H: 34.00
      B Offline
      B Offline
      boozz
      @Brian787
      If I were you I would check if you have the nrf24l01+version. I got some nrf24l01 radio's via Alice (although Alice sells them as nrf24l01+) and experience the same problem. Look at the square chip on the radio module. It should have the +sign on it!
      My problem with the gateway is solved once I exchanged the non-plus version with a plus version.
      • M Offline
        M Offline
        mbj
        wrote on last edited by mbj
        What version are you using. The current MQTT gateway code states:
        #define RADIO_ERROR_LED_PIN 7 // Error led pin
        #define RADIO_RX_LED_PIN 8 // Receive led pin
        #define RADIO_TX_LED_PIN 9 // the PCB, on board LED*/
        This works for me (sorry for the large font size, came from cut-and-paste from the Arduino code and I have found no way of changing it.)
        12.2k
