  3. UV Sensor and Vera - System Error: "Fail to load implementation file D_UvSensor1.xml"
5 Posts 3 Posters 2.6k Views 3 Watching
  • pndgt0P
    pndgt0P
    pndgt0
    Hi, I have problem in making Vera and Gateway add the UV Sensor (I used the example sketch provided in Build section). I have the following error after Gateway detect 1 Device: "System error: Device:496: Fail to load implementation file D_UvSensor1.xml ". I have reviewed the Luup files in Develop Apps and verified that the mentioned file does not exists only the same file name with JSON extension (don't know why it is not available neither in the Vera UI7 zip file for MySensors nor any other place). I googled to find the XML file with no luck. Please, could anyone share the XML file with me or any help will be much appreciated. Thanks
    dbemowskD 1 Reply Last reply
      http://code.mios.com/trac/mios_rfxcom/browser
      • pndgt0P pndgt0
        dbemowskD
        dbemowskD
        @pndgt0 Take a look at this forum post:
        http://forum.micasaverde.com/index.php/topic,1435.msg89456/topicseen.html#msg89456
        pndgt0P 1 Reply Last reply
        • dbemowskD dbemowsk
          pndgt0P
          pndgt0P
          pndgt0
          @dbemowsk Thank you!!!
          • pndgt0P pndgt0
            dbemowskD
            dbemowskD
            @pndgt0 Always glad to help.
