  3. OpenHAB
  4. Installation instruction OpenHAB2 + MQTT gateway
11 Posts 3 Posters 7.1k Views 2 Watching
  • vladimirV
    vladimirV
    vladimir
    Hello! Tell me please, what should I do to OpenHAB 2 started working with the MQTT gateway? There is somewhere understandable step-by-step instructions for configuring the OpenHAB 2 + MySensors (MQTT gateway)?
    • vladimirV vladimir
      @vladimir I don't use OpenHab myself, but https://forum.mysensors.org/topic/4415/my-final-setup-to-get-mysensors-and-openhab-communicating-via-mqtt looks quite comprehensive. If you have already looked at that, and it was not complete enough, could you describe what you are missing?
      vladimirV 1 Reply Last reply
      • vladimirV
        vladimirV
        vladimir
        This post is deleted!
          vladimirV
          vladimirV
          vladimir
          @mfalkvidd I can not understand where to find the file openhab.cfg
            @vladimir did you look at https://community.openhab.org/t/where-is-openhab-cfg/20348 ? If so, could you clarify why that didn't help you?
            vladimirV 2 Replies Last reply
              vladimirV
              vladimirV
              vladimir
              @mfalkvidd It looks like the whole problem is that I'm trying to do this in the Mac OS. Very strange, but even the debugging mode does not display real-time information.
                vladimirV
                vladimirV
                vladimir
                @mfalkvidd It is very strange that in the presence of such a large community, there are no detailed step-by-step instructions, everything is scattered in different places.
                Thank you very much for your help!
                  @vladimir it would be great if you could write step-by-step instructions that are detailed enough. We could publish them on https://www.mysensors.org/controller/openhab
                  Now that you've just gone through the process it should be fresh in your mind so writing it should be super easy.
                    vladimirV
                    vladimirV
                    vladimir
                    @mfalkvidd The fact of the matter is that I could not figure it out. Here are the problems that I now faced:
                    1. In OpenHAB2, on the Mac OS, debugging information is not displayed when starting start_debug.sh
                    2. I still could not understand why in OpenHAB2, there is no MQTT gateway in the list:
                    H 1 Reply Last reply
                      H
                      H
                      haggis
                      @vladimir mysensors mqtt gateway connect to the mosquitto broker, openhab also connect to mosquitto so you should install the mqtt binding in openhab. in the tutorial i think that in my config "openhab.cfg" is this file /etc/openhab2/services/mqtt.cfg
                      • H haggis
                        H
                        H
                        haggis
                        @haggis https://forum.mysensors.org/topic/3605/can-t-get-openhab2-to-see-my-mqtt-messages/3
