  3. How to tell if mysensors library starts up successfully?
7 Posts 4 Posters 2.3k Views 4 Watching
  • A
    A
    arraWX
    I would like to turn on a LED if a node cannot find the gateway (e.g. if the distance is too large) when the node is powered up. How can that be done?
    I understand that the send command returns a Boolean that tells whether a message reached the gateway. However, if the node cannot find the gateway on power up the sketch never proceeds beyond #include <MySensors.h>. Is it possible to derive some status from this command?
    Boots33B 1 Reply Last reply
      you already have 3 status LED, when red led flashes there has been a transmission error.
      • A
        A
        arraWX
        @gohan Thank you!
        The node is a sensebender micro. I would like to use the built-in LED.
        I never made a node with the 3 status LEDs. It might be worthwhile for me to look more into that.
          Unless you want to go the rfm69 way as they are a bit more advanced and you can read signal strength, power output and also the new driver has adaptive TX power.
          • A arraWX
            Boots33B
            Boots33B
            Boots33
            @arraWX The line of code to force the node to move on if no gateway is found is
            //set how long to wait for transport ready in milliseconds
            #define MY_TRANSPORT_WAIT_READY_MS 3000
            some posts that may be of interest
            Synchronising Light switch
            Booting sensors without Gateway connection?
            use of ACK
            • A
              A
              arraWX
              @Boots33 Thank you!
              Those posts provide lots of useful information.
              • Lars DeutschL
                Lars DeutschL
                Lars Deutsch
                @boots33 said in How to tell if mysensors library starts up successfully?:
                thank you very much ! I am using the latest 2.2.rc2 version. Will give the preprocessor statement above a try ...
                thank you very much,
                Lars
