  3. Why do "passive nodes" need to set their Node ID manually?
25 Posts 5 Posters 7.2k Views 4 Watching
  • rmtuckerR rmtucker
    @NeverDie
    Just cut domoticz out of the picture as node-red/influx/grafana works perfect with any gateway serial/ethernet/mqtt.
    I prefer the serial gateway in my own experience is the most stable and no reliance on wifi routers and things.
    Domoticz has nowhere near the same flexibility when graphing etc.
    NeverDieN
    NeverDieN
    @rmtucker Ahhhhhh, that's right, it was rmtucker, not toyman, who had done it: https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/1078
    • tekkaT
      tekkaT
      tekka
      @NeverDie @mfalkvidd Passive nodes communicate without message ACKs - ID requests may never make their way to the controller, hence the requirement of a static node ID.
      NeverDieN 1 Reply Last reply
      • tekkaT tekka
        NeverDieN
        NeverDieN
        @tekka In that case couldn't it just keep retrying until it received its ID?
        tekkaT 1 Reply Last reply
        • NeverDieN NeverDie
          tekkaT
          tekkaT
          tekka
          @NeverDie No, that's not the idea of a passive node. However, with
          void transportTogglePassiveMode(const bool OnOff)
          you can enable the passive transport mode, see here for additional information (>=2.2.0)
          • S smilvert
            @NeverDie
            I have started to test node-red (Which dont work yet...) so I have created a dummy sketch for parse the data to domoticz.
            // Enable debug prints
            #define MY_GATEWAY_SERIAL
            // Enable passive mode
            #define MY_PASSIVE_NODE
            #define MY_REPEATER_FEATURE
            // Passive mode requires static node ID
            #define MY_NODE_ID 0
            // #define MY_RADIO_NRF24
            //#define MY_RF24_PA_LEVEL RF24_PA_HIGH
            //#define MY_RADIO_NRF5_ESB
            //#define MY_RADIO_RFM95
            #define CHILD_ID_HUM 0
            #define CHILD_ID_TEMP 1
            #define CHILD_ID_BINARY 2
            // Initialize general message
            MyMessage msgBinary(CHILD_ID_BINARY, V_STATUS);
            int counter = 0;
            float temperature = 0;
            float humidity = 0;
            int binary = 0;
              // Send the sketch version information to the gateway and controller
              sendSketchInfo("Passive node", "1.0");
              present(CHILD_ID_HUM, S_HUM);
              present(CHILD_ID_BINARY, S_BINARY);
              // generate some random data
              counter ++;
              if (counter == 20 ){
                temperature = 0;
                humidity = 0;
                counter = 0;
              else
                temperature = 25.0 + random(0,30)/10.0;
                humidity = 55.0 + random(-20,20);
              if (binary == 0){
                send(msgBinary.set(binary,2));
                binary = 1;
              }else {
                binary = 0;
              send(msgTemp.set(temperature,2));
              send(msgHum.set(humidity,2));
              wait(1000);
            NeverDieN
            NeverDieN
            @smilvert Got it working: https://www.openhardware.io/view/510/Multi-Sensor-TempHumidityPIR-LeakMagnetLightAccel#tabs-source
            I cited you in the credits at the beginning of the sketch.
