  3. Why do "passive nodes" need to set their Node ID manually?
25 Posts 5 Posters 7.1k Views 4 Watching
    Which MySensor example should I use, then, for a TH sensor? I want it to report temperature, humidity, and battery voltage. And I want Domoticz to be able to graph all three (including negative temperature values). I was surprised that none of the given examples was exactly this. What do you recommend?
    @NeverDie I have no idea. The passive node is a bit of a hack, since MySensors nodes were initially designed to always have a path to the gateway. Hacks usually have unintended side-effects and it appears you have found one of those side-effects.
      @mfalkvidd OK, but setting the passive node sketch aside, which of the other "normal" example sketches do you recommend?
      mfalkviddM S 2 Replies Last reply
        @NeverDie I'm not sure what you mean. any example should work. That's what they are for :)
          smilvert
          I have started to test node-red (Which dont work yet...) so I have created a dummy sketch for parse the data to domoticz.
          // Enable debug prints
          #define MY_GATEWAY_SERIAL
          // Enable passive mode
          #define MY_PASSIVE_NODE
          #define MY_REPEATER_FEATURE
          // Passive mode requires static node ID
          #define MY_NODE_ID 0
          // #define MY_RADIO_NRF24
          //#define MY_RADIO_NRF5_ESB
          //#define MY_RADIO_RFM95
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 1
          #define CHILD_ID_BINARY 2
          // Initialize general message
          MyMessage msgBinary(CHILD_ID_BINARY, V_STATUS);
          int counter = 0;
          float temperature = 0;
          float humidity = 0;
          int binary = 0;
            sendSketchInfo("Passive node", "1.0");
            present(CHILD_ID_HUM, S_HUM);
            present(CHILD_ID_BINARY, S_BINARY);
            // generate some random data
            counter ++;
            if (counter == 20 ){
              temperature = 0;
              humidity = 0;
              counter = 0;
              temperature = 25.0 + random(0,30)/10.0;
              humidity = 55.0 + random(-20,20);
            if (binary == 0){
              send(msgBinary.set(binary,2));
              binary = 1;
            }else {
              binary = 0;
            send(msgTemp.set(temperature,2));
            send(msgHum.set(humidity,2));
            wait(1000);
          • S smilvert
            int counter = 0;
            float humidity = 0;
            int binary = 0;
              counter ++;
                temperature = 0;
                humidity = 0;
                counter = 0;
              if (binary == 0){
                binary = 1;
              }else {
                binary = 0;
              wait(1000);
            @smilvert I guess it's destiny then: Node Red + MQTT
            S 1 Reply Last reply
              smilvert
              Well I wanted to filter noise values and I also want to use influx/grafana as a complement to domoticz
              • S smilvert
                @smilvert So, do you have the gateway connected directly to Node Red, which then feeds Domoticz and also feeds influx/grafana? I think I want to do the same, if that's how to do it.
                  smilvert
                  that's the idea but it is not 100 % yet but I working on it.
                  • S smilvert
                    @smilvert I think @Toyman said he has it figured out. Maybe he can tell us how he did it?
                    rmtuckerR 1 Reply Last reply
                      rmtuckerR
                      rmtuckerR
                      rmtucker
                      Just cut domoticz out of the picture as node-red/influx/grafana works perfect with any gateway serial/ethernet/mqtt.
                      I prefer the serial gateway in my own experience is the most stable and no reliance on wifi routers and things.
                      Domoticz has nowhere near the same flexibility when graphing etc.
                      • rmtuckerR rmtucker
                        @rmtucker Ahhhhhh, that's right, it was rmtucker, not toyman, who had done it: https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/1078
                        • tekkaT
                          tekkaT
                          tekka
                          @NeverDie @mfalkvidd Passive nodes communicate without message ACKs - ID requests may never make their way to the controller, hence the requirement of a static node ID.
                          • tekkaT tekka
                            @tekka In that case couldn't it just keep retrying until it received its ID?
                            tekkaT 1 Reply Last reply
                              tekkaT
                              tekkaT
                              tekka
                              @NeverDie No, that's not the idea of a passive node. However, with
                              void transportTogglePassiveMode(const bool OnOff)
                              you can enable the passive transport mode, see here for additional information (>=2.2.0)
                              • S smilvert
                                int counter = 0;
                                float humidity = 0;
                                int binary = 0;
                                  counter ++;
                                    temperature = 0;
                                    humidity = 0;
                                    counter = 0;
                                  if (binary == 0){
                                    binary = 1;
                                  }else {
                                    binary = 0;
                                  wait(1000);
                                @smilvert Got it working: https://www.openhardware.io/view/510/Multi-Sensor-TempHumidityPIR-LeakMagnetLightAccel#tabs-source
                                I cited you in the credits at the beginning of the sketch.
