  3. Why do "passive nodes" need to set their Node ID manually?
25 Posts 5 Posters 7.1k Views 4 Watching
    @NeverDie I have no idea. The passive node is a bit of a hack, since MySensors nodes were initially designed to always have a path to the gateway. Hacks usually have unintended side-effects and it appears you have found one of those side-effects.
    @mfalkvidd OK, but setting the passive node sketch aside, which of the other "normal" example sketches do you recommend?
    mfalkviddM S 2 Replies Last reply
      @NeverDie I'm not sure what you mean. any example should work. That's what they are for :)
        smilvert
        I have started to test node-red (Which dont work yet...) so I have created a dummy sketch for parse the data to domoticz.
        // Enable debug prints
        #define MY_GATEWAY_SERIAL
        // Enable passive mode
        #define MY_PASSIVE_NODE
        #define MY_REPEATER_FEATURE
        // Passive mode requires static node ID
        #define MY_NODE_ID 0
        // #define MY_RADIO_NRF24
        //#define MY_RADIO_NRF5_ESB
        //#define MY_RADIO_RFM95
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        #define CHILD_ID_BINARY 2
        // Initialize general message
        MyMessage msgBinary(CHILD_ID_BINARY, V_STATUS);
        int counter = 0;
        float temperature = 0;
        float humidity = 0;
        int binary = 0;
          sendSketchInfo("Passive node", "1.0");
          present(CHILD_ID_HUM, S_HUM);
          present(CHILD_ID_BINARY, S_BINARY);
          // generate some random data
          counter ++;
          if (counter == 20 ){
            temperature = 0;
            humidity = 0;
            counter = 0;
            temperature = 25.0 + random(0,30)/10.0;
            humidity = 55.0 + random(-20,20);
          if (binary == 0){
            send(msgBinary.set(binary,2));
            binary = 1;
          }else {
            binary = 0;
          send(msgTemp.set(temperature,2));
          send(msgHum.set(humidity,2));
          wait(1000);
        • S smilvert
          int counter = 0;
          float humidity = 0;
          int binary = 0;
            counter ++;
              temperature = 0;
              humidity = 0;
              counter = 0;
            if (binary == 0){
              binary = 1;
            }else {
              binary = 0;
            wait(1000);
          @smilvert I guess it's destiny then: Node Red + MQTT
          S 1 Reply Last reply
            smilvert
            Well I wanted to filter noise values and I also want to use influx/grafana as a complement to domoticz
            • S smilvert
              @smilvert So, do you have the gateway connected directly to Node Red, which then feeds Domoticz and also feeds influx/grafana? I think I want to do the same, if that's how to do it.
                smilvert
                that's the idea but it is not 100 % yet but I working on it.
                • S smilvert
                  @smilvert I think @Toyman said he has it figured out. Maybe he can tell us how he did it?
                  rmtuckerR 1 Reply Last reply
                    rmtuckerR
                    rmtuckerR
                    rmtucker
                    Just cut domoticz out of the picture as node-red/influx/grafana works perfect with any gateway serial/ethernet/mqtt.
                    I prefer the serial gateway in my own experience is the most stable and no reliance on wifi routers and things.
                    Domoticz has nowhere near the same flexibility when graphing etc.
                    • rmtuckerR rmtucker
                      @rmtucker Ahhhhhh, that's right, it was rmtucker, not toyman, who had done it: https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/1078
                      • tekkaT
                        tekkaT
                        tekka
                        @NeverDie @mfalkvidd Passive nodes communicate without message ACKs - ID requests may never make their way to the controller, hence the requirement of a static node ID.
                        • tekkaT tekka
                          @tekka In that case couldn't it just keep retrying until it received its ID?
                          tekkaT 1 Reply Last reply
                            tekkaT
                            tekkaT
                            tekka
                            @NeverDie No, that's not the idea of a passive node. However, with
                            void transportTogglePassiveMode(const bool OnOff)
                            you can enable the passive transport mode, see here for additional information (>=2.2.0)
                            • S smilvert
                              int counter = 0;
                              float humidity = 0;
                              int binary = 0;
                                counter ++;
                                  temperature = 0;
                                  humidity = 0;
                                  counter = 0;
                                if (binary == 0){
                                  binary = 1;
                                }else {
                                  binary = 0;
                                wait(1000);
                              @smilvert Got it working: https://www.openhardware.io/view/510/Multi-Sensor-TempHumidityPIR-LeakMagnetLightAccel#tabs-source
                              I cited you in the credits at the beginning of the sketch.
