  3. Code for beta-testing?
33 Posts 10 Posters 19.8k Views 2 Watching
  • B Bmlsx
    Hi there again
    A quick question @jka I used the 1.4 branch on both arduino and rpi and all I get o rpi are messed up messages with crc errors, can u point me a direction on what I do wrong?
    Thanx
    G
    B
    B
    Bmlsx
    Can anyone pls help on this ...I'm about to eat the raspberry
      Sorry, I don't know why you are experiencing problem. We will soon have a look at the RPI stuff again and make a usable version.
      The last week all our mysensors-time has been spend on server infrastructure (prod/stage environment etc) to prepare for the new services.
      Getting this right took more time that we initially anticipated.
      In the meantime. Anyone having a good low footprint node-database-candidate for storing sensor data in the RPI?
      The purpose is having a local backup of all historic data and to keep a record of which data has been sent to cloud-service.
      There won't be much local querying, mostly storing.
      Right now I'm considering:
      NeDB/NEDBLogger (https://github.com/louischatriot/nedb)
      Levelup/Leveldb (https://github.com/rvagg/node-levelup)
      • T
        ToSa
        Code Contributor
        wrote on last edited by ToSa
        #23
        The "Message crc error." is a bit misleading. The code in the validate() routine actually checks the crc as well as the protocol version. Looking at the Arduino and the RPi 1.4 branch the versions don't match. I've adjusted the library and protocol version in the Sensor.h file on the Rpi to:
        LIBRARY_VERSION "1.4"
        PROTOCOL_VERSION 2
        and the crc error disappeared.
        While changing the data rate from 2M to 1M in line 30 of the Arduino Sensor.cpp, I had to fix a syntax error to recompile successfully in line 361: a missing "}" to close the do/while. The full line should be "} while (--retry);"
        With these two fixed the RPi and the Arduino now communicate - but I get a lot of "Send failed" messages on the Arduino and a lot of "Error looking up radioIds" on the RPi now:
        RPi output:
        Received: from=255, to=0, childId=255, mtype=4, type=5, crc=139, ''
        139, 2, 0, 255, 0, 255, 255, 4, 5
        Message crc ok.
        header.type=5, header.to=0, radioId=0
        Got message
        Message type: 4
        msgTypeId=4 int=4
        ...and so on...
        Android in DEBUG mode:
        Started sensor.
        Relay=0, distance=1
        No radio id found in EEPROM fetching one from sensor net gateway
        Relaying message back to gateway.
        Tx: fr=255,to=0,la=255,ne=0,ci=255,mt=4,ty=5,cr=139:
        Send failed.
        Send failed.
        ...and so on...
        B 1 Reply Last reply
        • T
          ToSa
          Code Contributor
          Changing the mongo database URL in the dbDetails,js file
          mongodb://mysensors:27017/pi
          to:
          mongodb://localhost:27017/mysensors
          fixed the "Error looking up radioIdo" issue on the RPi. Now the Rpi generates a new radioId but the attempt to send this to the Arduino fails:
          RPi output:
          Message crc ok.
          Got message
          Message type: 4
          msgTypeId=4 int=4
          Sending data 255;255;4;5;1
          Writing back messageWe have input
          Nread=14
          INP:255;255;4;5;1
          INGOT radioId=255, childId=255, messageType=4, type=5, value=1
          Sending data to GATEWAYRelaying message back to gateway.
          Sending: from=0, to=255, childId=255, mtype=4, type=5, crc=193, '1
          ', sent via 0
          193, 2, 0, 0, 255, 0, 255, 4, 5
          radioId: Inserted id=1
          Send failed. No ack received.
          Sent to JS
          Dynamic payload size=9
          • T ToSa
            PROTOCOL_VERSION 2
            RPi output:
            Message crc ok.
            Got message
            Message type: 4
            msgTypeId=4 int=4
            ...and so on...
            Started sensor.
            Relay=0, distance=1
            Send failed.
            Send failed.
            ...and so on...
            B
            B
            Bmlsx
            @ToSa thank you ...u saved my rpi;)
            • T
              ToSa
              Code Contributor
              #26
              @BMLSX - probably rather saved your stomach - eating the raspberry sounds noxious :)
              I got one step further (maybe) - the Arduino now receives the radioId... looking at the log from the RPi above I stumbled over the RPi sending the data to the gateway ??? the RPi is the gateway !!! Comparing the code to the SerialGateway which seems to work for a lot of folks I found that the sendData() function is missing in the Relay.cpp code used for the RPi. Once that procedure is in place the RPi actually submits the new radioId to the sensor:
              RPi : now "sent via 255" instead of "sent via 0"
              Received: from=255, to=0, childId=255, mtype=4, type=5, crc=65, ''
              Message crc ok.
              Got message
              Message type: 4
              msgTypeId=4 int=4
              We have input
              Nread=14
              INP:255;255;4;5;1
              No route... try sending direct.
              Sending: from=0, to=255, childId=255, mtype=4, type=5, crc=11, '1
              ', sent via 255
              Sent to JS
              Arduino
              Started sensor.
              Open ping reading pipe: 255
              Tx: fr=255,to=255,la=255,ne=255,ci=255,mt=4,ty=9,cr=235:
              Message available on pipe 1
              Rx: fr=0,to=255,la=0,ci=255,mt=4,t=10,cr=106(ok): 0
              Message addressed for this node.
              Using relay 0. Distance is 0
              Relay=0, distance=1
              TH: get: n=0,c=255,st=4,rt=4,vt=5
              Tx: fr=255,to=0,la=255,ne=0,ci=255,mt=4,ty=5,cr=65:
              Ack: receive timeout
              Sent ack msg to 0
              Rx: fr=0,to=255,la=0,ci=255,mt=4,t=5,cr=11(ok): 1
              Radio id received: 1
              Radio id stored in EEPROM was: 1
              Tx: fr=1,to=0,la=1,ne=0,ci=255,mt=0,ty=17,cr=17: 1.3b3 (7afb55c)
              Tx: fr=1,to=0,la=1,ne=0,ci=255,mt=4,ty=7,cr=176: 0
              Tx: fr=1,to=0,la=1,ne=0,ci=255,mt=4,ty=14,cr=21: Temperature Sensor
              Tx: fr=1,to=0,la=1,ne=0,ci=255,mt=4,ty=15,cr=13: 1.0
              Tx: fr=1,to=0,la=1,ne=0,ci=0,mt=0,ty=6,cr=99: 1.3b3 (7afb55c)
              TH: get: n=0,c=255,st=4,rt=4,vt=13
              Tx: fr=1,to=0,la=1,ne=0,ci=255,mt=4,ty=13,cr=200:
              I'm still not sure if the missing ACK for the majority of the messages is by purpose or by accident... would be relatively easy to fix by either not waiting for an ACK for all messages or by always sending an ACK - but I don't want to mess with this code without knowing why it was implemented this way.
              • T
                ToSa
                Code Contributor
                RPi and Arduino now talk to each other, the Arduino receives the radioId from the Rpi and stores it in the EEPROM and the Arduino presents itself to the network. I still see some timing issues (ACKs too late / replies too early while the other end is still waiting for an ACK / ...) but in general it works.
                To get there I forked both the Arduino and the RPi project and tried to get to the latest and greatest code by merging some of the branches (mainly master and 1.4dev)... When I ran into additional issues due to the RPi code not getting the latest updates and bug fixes available in the Arduino project, I decided to merge across the two and ended up with a common set of RF files: a common codebase for RF24 as well as Sensor/Relay/Gateway. If any of this is of interest for themain development then please let me know and I'll create a pull request.
                What I did in detail:
                Arduino:
                • started new branch tosa-dev based on latest master branch
                • adjusted the message header to use full bytes as mentioned earlier in this thread
                • no need to merge the 1.4dev branch as the message header was essentially the only remaining relevant change in there
                • no need to merge other branches as the majority of these were already merged back into master
                Raspberry:
                • merged the 1.4dev branch into tosa-dev
                • a couple of minor tweaks (mongoDb URL / start and stop scripts / data rate / ... majority listed earlier in this thread)
                When I found the missing Relay::sendData() routine I decided to stop tweaking bit by bit and instead looked at what it would take to use the more advanced Arduino code for RF24 and Sensor/Relay/Gateway for the RPi as well. Based on comments in the forum this seems to work for several people using a SerialGateway or EthernetGateway so my expectation was to find well maintained code there avoiding some of the low level communication issues I ran into so far with the RPi code. This code is available in a separate branch "tosa-dev-commonrf" for both Arduino and Raspberry.
                The code is not perfect yet but it works. I'm not a GIT expert but as far as I can tell the fork is public and everybody should be able to see it:
                https://github.com/ToSa27/Raspberry/tree/tosa-dev-commonrf
                https://github.com/ToSa27/Arduino/tree/tosa-dev-commonrf
                Again: happy to create pull requests if you want to use this setup as part of the master branch at some point. The main reason for me to do this is to get a solid foundation to start working on the OTA update code...
                  Great.
                  I'm working on breaking out the message part from Sensor.cpp into a new class and make it more platform independent (c++ bit fields is not good) . This will help when we port code from Arduino to RPI.
                  • jendrushJ
                    jendrushJ
                    jendrush
                    How the work is going?
                    • D
                      D
                      donnib
                      @ToSa How is your system working ? Are you still using the code you cahnged on your sensors and rPI ? Is it working acceptable ?
                      • D
                        D
                        donnib
                        @ToSa i tried compiling your code but it fails on the RPi with allot of errors :
                        pi@raspberrypi ~/Raspberry $ make
                        make -C librf24
                        make[1]: Entering directory /home/pi/Raspberry/librf24' g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -c RF24.cpp RF24.h: In constructor ‘RF24::RF24(std::string, uint32_t, uint8_t)’: RF24.h:65:12: warning: ‘RF24::spispeed’ will be initialized after [-Wreorder] RF24.h:53:11: warning: ‘uint8_t RF24::ce_pin’ [-Wreorder] RF24.cpp:258:1: warning: when initialized here [-Wreorder] g++ -shared -Wl,-soname,librf24.so.1 -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -o librf24.so.1 compatibility.o gpio.o spi.o RF24.o make[1]: Leaving directory /home/pi/Raspberry/librf24'
                        g++ -c -g -o Gateway.o Gateway.cpp -Wall -Ofast -mfpu=vfp -DDEBUG -DRPI -mfloat-abi=hard -march=armv6zk -mtune=arm1176jzf-s -I/home/pi/RF24/RPi/RF24/
                        In file included from Sensor.h:15:0,
                        from Relay.h:15,
                        from Gateway.h:15,
                        from Gateway.cpp:12:
                        Config.h:15:0: warning: "DEBUG" redefined [enabled by default]
                        <command-line>:0:0: note: this is the location of the previous definition
                        In file included from Relay.h:15:0,
                        from Gateway.h:15,
                        Sensor.h:154:16: error: expected ‘)’ before ‘_spidevice’
                        In file included from Gateway.h:15:0,
                        Relay.h:43:16: error: expected ‘)’ before ‘_spidevice’
                        In file included from Gateway.cpp:12:0:
                        Gateway.h:47:18: error: expected ‘)’ before ‘_spidevice’
                        Gateway.cpp:34:1: error: prototype for ‘Gateway::Gateway(std::string, uint32_t, uint8_t, uint8_t)’ does not match any in class ‘Gateway’
                        Gateway.h:24:7: error: candidates are: Gateway::Gateway(const Gateway&)
                        Gateway.h:24:7: error: Gateway::Gateway()
                        Gateway.cpp: In member function ‘void Gateway::begin(rf24_pa_dbm_e, uint8_t, rf24_datarate_e, void ()(char))’:
                        Gateway.cpp:62:18: error: ‘OUTPUT’ was not declared in this scope
                        Gateway.cpp:62:24: error: ‘pinMode’ was not declared in this scope
                        Gateway.cpp:65:26: error: ‘digitalWrite’ was not declared in this scope
                        Gateway.cpp:70:25: error: ‘INPUT’ was not declared in this scope
                        Gateway.cpp:86:53: error: ‘PSTR’ was not declared in this scope
                        Gateway.cpp: In member function ‘void Gateway::checkButtonTriggeredInclusion()’:
                        Gateway.cpp:104:59: error: ‘PSTR’ was not declared in this scope
                        Gateway.cpp: In member function ‘void Gateway::parseAndSend(char*)’:
                        Gateway.cpp:161:35: error: ‘PSTR’ was not declared in this scope
                        Gateway.cpp: In member function ‘void Gateway::setInclusionMode(boolean)’:
                        Gateway.cpp:181:33: error: ‘PSTR’ was not declared in this scope
                        Gateway.cpp: In member function ‘void Gateway::serial(message_s)’:
                        Gateway.cpp:236:33: error: ‘PSTR’ was not declared in this scope
                        Gateway.cpp: In member function ‘void Gateway::ledTimersInterrupt()’:
                        Gateway.cpp:243:28: error: ‘digitalWrite’ was not declared in this scope
                        Gateway.cpp:246:30: error: ‘digitalWrite’ was not declared in this scope
                        Gateway.cpp:252:28: error: ‘digitalWrite’ was not declared in this scope
                        Gateway.cpp:255:30: error: ‘digitalWrite’ was not declared in this scope
                        Gateway.cpp:262:28: error: ‘digitalWrite’ was not declared in this scope
                        Gateway.cpp:265:30: error: ‘digitalWrite’ was not declared in this scope
                        make: *** [Gateway.o] Error 1
                        S 1 Reply Last reply
                        • D donnib
                          make -C librf24
                          from Relay.h:15,
                          from Gateway.h:15,
                          from Gateway.h:15,
                          sjostrom
                          @donnib I got the same error. Checked out the 1.4dev branch instead and got it working.
                          • T
                            ToSa
                            Code Contributor
                            @donnib - I didn't continue this way but instead started using node-js based controller code that connects to a standard Ethernet gateway. @hek merged the code about two weeks ago. I will provide a tutorial on how to set it up from scratch shortly...
