  3. Please can you tell me where I have gone wrong here?
6 Posts 4 Posters 1.7k Views 4 Watching
  • skywatchS Offline
    skywatchS Offline
    skywatch
    Hi all,
    I have a sketch to monitor a door/window and that tesed OK - Then I decided to add an anti-tamper switch to the box and whatever I try I cannot get it to work....
    Here is the code....
    // Enable debug prints
    // #define MY_DEBUG
    #define MY_RF24_PA_LEVEL RF24_PA_LOW  //Options are: RF24_PA_MIN, RF24_PA_LOW, RF24_PA_HIGH or RF24_PA_MAX
    uint32_t SLEEP_TIME = 900000; // Sleep time between reports (in milliseconds) approx eveery 15 mins.
    #define DIGITAL_INPUT_SENSOR_2 2   // Anti-Tamper switch connection.
    #define DIGITAL_INPUT_SENSOR_3 3   // The digital input you attached your Door/Window sensor.
    #define CHILD_ID_1 2   // Id of the Anti-Tamper sensor child.
    #define CHILD_ID_2 3   // Id of the door/window sensor child.
    int batteryPcnt = 0;
    // Initialize door/window message
    MyMessage msg( CHILD_ID_1, V_TRIPPED);  //Tamper.
    MyMessage msg1( CHILD_ID_2, V_TRIPPED); //Door/Window.
      pinMode(DIGITAL_INPUT_SENSOR_3, INPUT);      // sets the door/window sensor digital pin as input
      digitalWrite(DIGITAL_INPUT_SENSOR_3, HIGH);
      pinMode(DIGITAL_INPUT_SENSOR_2, INPUT);      // sets the Anti-Tamper sensor digital pin as input
      digitalWrite(DIGITAL_INPUT_SENSOR_2, HIGH);
      sendSketchInfo("Patio Door", "3.0");
      present(CHILD_ID_1, S_DOOR, "Patio Tamper");
      present(CHILD_ID_2, S_DOOR, "Patio Door");
      ////to be tested ........../////
      // Read digital anti-tamper.
      bool tripped = digitalRead(DIGITAL_INPUT_SENSOR_2) == HIGH;
        send(msg.set(tripped ? "1" : "0")); // Send anti-tamper tripped value to gw
      //Read digital door/window value.
      bool tripped = digitalRead(DIGITAL_INPUT_SENSOR_3) == HIGH;
         send(msg1.set(tripped ? "1" : "0")); // Send door/window tripped value to gw
        batteryPcnt = sensorValue / 10;
      // Sleep until interrupt comes in on motion sensor. Send battery update every 15 minutes.
      sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_2) || digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_3), CHANGE, SLEEP_TIME);
    The door/window pin works and the data gets sent to the controller, but it never sees any data from the anti-tamper switch....I have tried a few things but I cannot get both switches to work - what have I got wrong here please?
    • skywatchS skywatch
      Hi all,
      // #define MY_DEBUG
      @skywatch the sleep call in the code is very strange. I think you want to use this function:
      int8_t sleep(uint8_t interrupt1, uint8_t mode1, uint8_t interrupt2, uint8_t mode2, unsigned long ms=0);
      Reference for sleep: https://www.mysensors.org/download/sensor_api_20#sleeping
      • skywatchS Offline
        skywatchS Offline
        skywatch
        Hi @Mfalkvidd -
        Yes I just tracked it down to that line with w few serial.prints..... Thanks for the fast reply - I will try again! :)
        and
        sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_2), CHANGE, digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_3), CHANGE, SLEEP_TIME);
        This way it works! :) - Thank you! :)
        • wallyllamaW Offline
          wallyllamaW Offline
          wallyllama
          The alternative answer is that you chose a hobby that will take up all your spare time and burn all your extra money.
          • wallyllamaW wallyllama
            zboblamontZ Offline
            zboblamontZ Offline
            zboblamont
            @wallyllama Ah, you mean marriage? Sorry, couldn't resist.... :)
            • skywatchS Offline
              skywatchS Offline
              skywatch
              @wallylama
              I already did that! :o - That's why I now need to make it all work!!! :)
