  3. Where/how to start?
Where/how to start?
6 Posts 3 Posters 1.8k Views 3 Watching
  • P Offline
    P Offline
    pumpkinpi
    Hello everyone
    This is my first post here so please be gentle with me.
    Am trying to get a basic setup going using Nodemcu as a gateway and DHT22 running on an Arduino Nano.
    Am no stranger to Arduino/Nodemcu programming etc, but what should I be seeing as an output from either the Sensor or the gateway? As far as I can tell, no debug statements are being sent but I do get some output.
    Is there a walkthrough at all?
    Thanks in advance.
    P 1 Reply Last reply
    • P pumpkinpi
      Hello everyone
      Thanks in advance.
      P Offline
      P Offline
      pumpkinpi
      Here is some output from the DHT22 board:
      3 TSM:INIT
      4 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      13 TSM:FPAR
      15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      2022 !TSM:FPAR:NO REPLY
      2024 TSM:FPAR
      2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      4034 !TSM:FPAR:NO REPLY
      4036 TSM:FPAR
      4038 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      6046 !TSM:FPAR:NO REPLY
      6048 TSM:FPAR
      6050 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      8058 !TSM:FPAR:FAIL
      8059 TSM:FAIL:CNT=1
      8061 TSM:FAIL:PDT
      18065 TSM:FAIL:RE-INIT
      18067 TSM:INIT
      18074 TSM:INIT:TSP OK
      18076 TSM:FPAR
      18078 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      20086 !TSM:FPAR:NO REPLY
      20088 TSM:FPAR
      20090 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      22099 !TSM:FPAR:NO REPLY
      22102 TSM:FPAR
      22104 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      24112 !TSM:FPAR:NO REPLY
      24114 TSM:FPAR
      24116 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      26124 !TSM:FPAR:FAIL
      26125 TSM:FAIL:CNT=2
      26127 TSM:FAIL:PDT
      Thanks in advance again.
      • P pumpkinpi
        3 TSM:INIT
        4 TSF:WUR:MS=0
        11 TSM:INIT:TSP OK
        13 TSM:FPAR
        2024 TSM:FPAR
        4036 TSM:FPAR
        6048 TSM:FPAR
        8058 !TSM:FPAR:FAIL
        8059 TSM:FAIL:CNT=1
        8061 TSM:FAIL:PDT
        18067 TSM:INIT
        18076 TSM:FPAR
        20088 TSM:FPAR
        22102 TSM:FPAR
        24114 TSM:FPAR
        26127 TSM:FAIL:PDT
        P Offline
        P Offline
        pumpkinpi
        And here is the output from the Nodemcu side:
        0;255;3;0;9;TSF:LRT:OK
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSF:WUR:MS=0
        0;255;3;0;9;TSM:INIT:TSP OK
        0;255;3;0;9;TSM:INIT:GW MODE
        scandone
        f 0, scandone
        state: 0 -> 2 (b0)
        state: 2 -> 3 (0)
        state: 3 -> 5 (10)
        add 0
        aid 4
        cnt
        chg_B1:-40
        connected with xxxxxxxxxxxxxxx, channel 6
        dhcp client start...
        .ip:192.168.0.14,mask:255.255.255.0,gw:192.168.0.1
        .IP: 192.168.0.14
        0;255;3;0;9;MCO:BGN:STP
        pm open,type:2 0
        • N Offline
          N Offline
          Hello and welcome !
          You have a tool to parse the log on the "Build" menu of the website.
          FPAR is "find parent", so here it means the node cannot communicate with the gateway.
          How did you connect the radio to the node MCU board ? Did you put the right defines in your sketch to declare the radio ?
          • P Offline
            P Offline
            pumpkinpi
            Thank you Nca78.
            The radio module has been connected up exactly as per the "Connecting the radio" page:
            GND GND
            3V3 VCC
            D2 CE
            D8 CSN/CS
            D5 SCK
            D7 MOSI
            D6 MISO
            I found the log parsing page after I posted and it was useful. Since then I have changed the cables for shorter duponts and used another nrf24l01 radio with the same result. What I haven't tried yet is the "add a capacitor to the power supply".
            Would I be correct in thinking that according to the log file, the radio is being initialised and therefore appears to be wired correctly?
            The capacitor thing is well documented, has anyone had to do this? If so, did it solve the issue?
            The Arduino nano side of things is using one of those adapter boards with the built-in regulator so am thinking it may be a power issue?
            • P pumpkinpi
              Thank you Nca78.
              GND GND
              3V3 VCC
              D2 CE
              D8 CSN/CS
              D5 SCK
              D7 MOSI
              D6 MISO
              @pumpkinpi welcome to the forum!
              The flowcharts at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ can probably be useful.
              You are correct that the radio wiring is ok since initialization works.
              You are incorrect that a few people has had to use a capacitor. Everyone has to. If not, problems will arise. Maybe not right away, sometimes people are just lucky and get the nodes partially working initially. But the nrf24 radios will fail sooner or later without a capacitor. I understand that the instructions on the radio wiring page weren't clear on this so I have adjusted them.
