  3. MQTT and batterylevel
17 Posts 6 Posters 8.4k Views 2 Watching
  • gaduG
    gaduG
    gadu
    I can't get the ProMini to publish the batterylevel.
    In the serial interface I can see that it is reporting the levels correct, but nothing reaches Mosquitto nor OpenHAB.
    My sketch looks likes this, what am I doing wrong?!
    #include <OneWire.h>
     unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
     OneWire oneWire(ONE_WIRE_BUS);
     int oldBatteryPcnt = 0;
     int numSensors=0;
     boolean metric = true;
     MyMessage msg(0,V_TEMP);
       // Startup OneWire
       sensors.begin();
       analogReference(INTERNAL);
       gw.begin();
       //gw.sendSketchInfo("Temperature Sensor", "1.0");
     gw.present(i, S_TEMP);
       gw.process();
    if (lastTemperature[i] != temperature && temperature != -127.00) {
        // get the battery Voltage
        //Serial.println(sensorValue);
        float batteryV  = sensorValue * 0.003363075;
        Serial.print(batteryV);
        Serial.println(" V");
        Serial.print(batteryPcnt);
        Serial.println(" %");
          // Power up radio after sleep
          oldBatteryPcnt = batteryPcnt;
       gw.sleep(SLEEP_TIME);
    • gaduG
      gaduG
      gadu
      Sorry for bumping, but i'm lost... :(
      Help?
      • MagiskeM
        MagiskeM
        Magiske
        wrote on last edited by Magiske
        This post is deleted!
          mbj
          Maybe I did not read your code good enough but I could not see any definition of the message type sendBatteryLevel (see an example for the definition of the temperature message in your code "MyMessage msg(0,V_TEMP);" )
          gaduG 1 Reply Last reply
          • M mbj
            gaduG
            gaduG
            gadu
            @mbj
            Like this?
             MyMessage msgvolt(1,V_VOLTAGE);
            • gaduG
              gaduG
              gadu
              Nope, I cant get this to work...
              I really would appreciate if someone could help me with an working example where batterylevel can be presented as a MQTT topic.
              Help!
                mbj
                Unfortunately I am a beginner with all this but I have been successful getting messages over to Openhab via the MQTT binding.
                I can guess that the "sendBatteryLevel" example from the API pages is tailored for a Vera controller or similar but is not at all understood by Openhab. I have come across something similar when other sensors send commands directed to the controller itself.
                So my assumption was that if you should send something across that Openhab understands you could test creating a message like your example msgvolt and then send the info with something like gw.send(msgvolt.set(batteryV)) or gw.send(msgvolt.set(batteryV,1)) and pick this up with an item in Openhab.
                The messages type V_VAR1 and onwards can be used for custom values so I think you can use one of these to send the battery level percentage. Only way to find out is to experiment :-)
                • M mbj
                  gaduG
                  gaduG
                  gadu
                  Big thanks @mbj
                  I'm more of a beginner than you. Trust me. :-)
                  I'll do some experiments using you pointers.
                  gaduG K 2 Replies Last reply
                  • gaduG gadu
                    Big thanks @mbj
                    gaduG
                    gaduG
                    gadu
                    @mbj saved my day!!
                    publish: MyMQTT/21/0/V_TEMP 23.5
                    0;0;3;0;9;send: 0-0-21-21 s=0,c=1,t=0,pt=0,l=5,st=ok:23.5r
                    0;0;3;0;9;read: 21-21-0 s=1,c=1,t=24,pt=2,l=2:87
                    publish: MyMQTT/21/1/V_VAR1 87
                    And you called yourself a beginner? ;-)
                    M 1 Reply Last reply
                    • gaduG gadu
                      @mbj saved my day!!
                      mbj
                      @gadu Glad to be of any help, your turn next :-)
                      • gaduG
                        gaduG
                        gadu
                        If anything, let me know! Dunno if I can be of any help, but i could try :-)
                        Odd thing happend though, When the Mini is connected to the FTDI the serial monitor says "Check Wires", but on battery it sends everything correct?
                        Well, that's another issue to look at later...
                        • gaduG gadu
                          Big thanks @mbj
                          K
                          K
                          kunall
                          @gadu Can you post your working battery level send sketch for openhab? I would really appreciate it. I'm facing the same issue. Thanks!
                          • HeinzH
                            HeinzH
                            Heinz
                            ... probably gw.sendBatteryLevel(percent); helps.
                            • K kunall
                              gaduG
                              gaduG
                              gadu
                              @kunall
                              First these two rows before setup..
                              and in the loop i have these rows...
                              in OpenHab items i have this row...
                              Number node2_batt  "Battery [%.1f %%]" <energy> (node2,All)  {mqtt="<[MySensor:MyMQTT/21/1/V_VAR1:state:default]"}
                              hope this helps....
                              • gaduG gadu
                                @kunall
                                hope this helps....
                                K
                                K
                                kunall
                                Thanks alot @gadu . I will give this a try and get back to you! :+1:
                                • gaduG gadu
                                  @kunall
                                  hope this helps....
                                  K
                                  K
                                  kunall
                                  wrote on last edited by kunall
                                  @gadu How did you implement V_Var1 ? and assign it to child ID 1 ?
                                  Like this? if so, what did you use for gw.present(CHILD_ID, S_XXX) ?
                                  #define CHILD_ID 1
                                  myMessage msg(CHILD_ID, V_VAR1);
                                  • siodS
                                    siodS
                                    siod
                                    @gadu
                                    where is the imprtoant MQTT code of your sketch? Would be so kind and share it with us?
                                    Thanks in advance!!
                                    still learning...
