  3. Relay for PCB relay node
13 Posts 7 Posters 6.6k Views 1 Watching
  • J Offline
    J Offline
    johnr
    I am working on a PCB for a wall switch. Since I would like to use quality components for the 230V parts, I am lookin for best quality / price relay.
    What do you think about Omron ALQ305 ?
    https://www.elfa.se/elfa3~se_sv/elfa/init.do?item=37-071-30&toc=18836
    Do you suggest to use an optocoupler for safety?
    R 1 Reply Last reply
    • J johnr
      R Offline
      R Offline
      RJ_Make
      @johnr Relay specs look good, and fairly small foot print. Not sure on the quality though..
      How are you going to handle the step down?
      RJ_Make
      • D Offline
        daulagari
        I do not see why you would want to use and optocoupler unless some part of the circuit can be touched but like @ServiceXp asks, more crucial is how you are going to convert from 230V to 5V.
        • J Offline
          J Offline
          johnr
          Hi thanks for the feedback.
          For 230v -> 5v I am going to test the Mean Well irm-05-5.
          It is definitely not the cheapest you can find, but I was able to get an ok price for them. It is capsuled which I think is nice, and like I stated above I would like to use quality components for the high voltage parts.
          • J johnr
            R Offline
            R Offline
            RJ_Make
            @johnr It's an "OK" transformer, but it doesn't appear to have any thermal protection and it's fairly big.
            RJ_Make
            • D Offline
              daulagari
              Looking at the datasheet of the IRM-05-5 the Derating Curve shows that for 70 degrees the load drops to 0% so it looks like it has thermal protection.
              • D daulagari
                R Offline
                R Offline
                RJ_Make
                @daulagari Does that classify it as having over temp protection? Seems like every transformer datasheet I've seen has that drop off curve?
                In this case I just did a quick look through for OTP, OVP, SCP features. and didn't see any OTP, plus the thing is fairly big.. :-)
                RJ_Make
                • V Offline
                  V Offline
                  viking
                  @johnr great idea! i have spent a few days considering this myself. Have you put any thought in to how it will be integrated to the socket? My concern is that I'd like to re-use the existing mechanical buttons in the house, connecting the arduino as a multi-way connection (swedish: trapp-koppling) to be able to use both mechanical buttons and non-mechanical. For existing multi-way connections I was thinking of adding the arduino as a "cross" (Swedish: korskoppling) in between to facilitate that but that would require two relays
                  B J 2 Replies Last reply
                  • V viking
                    B Offline
                    B Offline
                    bluman
                    I'm working on a Distributed Arduino Node (DAN) that is designed as a "per-room" style controller using the MySensors network talking back to my Vera via serial gateway.
                    Lighting and temp/humidity is currently working.
                    I also plan to add Lux and infrared send/receive.
                    Local control of the lighting is possible using a normal wall switch which is also wired to a relay in a "two-way" switch configuration. Like this:
                    http://www.electronics-project-design.com/images/TwoWayLightSwitch.GIF
                    This circuit switches power to a 12V power supply feeding into an LED dimmer/driver like this:
                    http://www.aliexpress.com/item/Free-Shipping-Constant-Voltage-DMX512-0-10V-Dimming-driver-1-Channel-Single-output-DC12-24V-10A/1329369736.html
                    This dimmer has a 0-10V DC input which controls the brightness of the LED lighting.
                    http://en.wikipedia.org/wiki/0-10_V_lighting_control
                    A rotary encoder is then mounted with the normal wall switch as a dimmer control.
                    The encoder controls the Arduino's digital-to-analog converter outputting 0-5V. This output is then fed through an operational amplifier with a gain of 2, scaling the output from 0-10V. This feeds the LED dimmer/driver above and is working well with no flicker!
                    Feedback is required from the 12v power supply so Vera knows if the load is either on or off as there is no way of knowing this with the two-way switching.
                    This is designed for bidirectional control, from the local wall switch / rotary encoder or from the Vera for example, scene control.
                    Both on/off and brightness are fed back to the Vera so the DAN and Vera status is kept in sync.
                    If people are interested I am happy to post more details, sketch, Eagle schematic etc. This is still a "work in progress" though for our new home which we hope to start building this year.
                    Regards
                    Bluman
                    • greglG Offline
                      greglG Offline
                      gregl
                      Hi @bluman - Yes please post more details/sketch eagle files...sounds really well implemented!!!
                      • hekH Offline
                        hekH Offline
                        @bluman
                        Candidate for the project contest perhaps?
                        B 1 Reply Last reply
                        • V viking
                          J Offline
                          J Offline
                          johnr
                          @viking
                          Would it not be easier to connect the wall switch to a digital in on the arduino? It is the way the fibaro/qubino/ etc wall switches work. Double relays seems like overshooting when you can Control each relay by remote signal.
                          Actually I was thinking to create a plugin adapter and use something similar to this http://www.ebay.com/itm/MAD-140-ABS-Plastic-Box-Adapter-Enclosure-Case-Hobby-Electronic-Project-/161113131266?pt=LH_DefaultDomain_0&hash=item2583174902
                          It could accomodate both socket outlet, tempsensor, and proximity sensor, hopefully.
                          If you would like to but your sensor behind a wall socket, I Think you will need a much smaller Power supply. CHeck this thread:
                          http://forum.mysensors.org/topic/687/230v-power-supply-to-arduino/2
                          Especially this Power supply is mentioned which looks nice:
                          http://fr.rs-online.com/web/p/alimentations-a-decoupage-integrables/7719379/
                          But I do fell that It have enough Electronics skill to integrate it safely right now.
                            @bluman
                            B Offline
                            B Offline
                            bluman
                            @hek said:
                            @bluman
                            If all my parts turn up from China in time then it should be ready to submit for judging!
