  3. LogOTANode & LogOTAGateway
1 Posts 1 Posters 683 Views 1 Watching
  • R Offline
    R Offline
    romeo01
    Hi All,
    Someone could confirm me that LogOTANode & LogOTAGateway sketch example work correctly.
    I'm unable to test the OTA degug feature because all characters sent by the node are unreadeable.
    In fact, I do not try with the logOTAGateway sketch, because I aready have a gateway running. But I use a new node with unique ID to receive all debug messages from the fist node (LogOTANode).
    TX_LogOTANode.ino (TX OTA)
     * Example for sending debug messages over the air (OTA).
    // Enable debug
    // Enable OTA debugging to Node 100
    #define MY_DEBUG_OTA (100)
    // Allow sending logs without MY_DEBUG_OTA enabled
    #define MY_OTA_LOG_SENDER_FEATURE
    #define MY_NODE_ID 50
    // Disable ACK for debug messages
    //#define MY_DEBUG_OTA_DISABLE_ACK
      sendSketchInfo("TX DebugSensor", "1.0");
    // Arduino loop
    int c=0;
      // Wait some time
      if (sleep(3000)==MY_SLEEP_NOT_POSSIBLE) {
        delay(3000);
      // Count loops
      c++;
      // A debug message
      DEBUG_OUTPUT(PSTR("DEBUG\nc=%" PRId16 "\nmillis=%" PRId32 "\n"), c, hwMillis());
      // Send a log message with ACK to a node
      OTALog(100, true, PSTR("LOG\nc=%" PRId16 "\nmillis=%" PRId32 "\n"), c, hwMillis() );
    RX_LogOTANode.ino (RX OTA)
    // Enable OTA log display
    #define MY_OTA_LOG_RECEIVER_FEATURE
    #define MY_NODE_ID 100
    #define MY_BAUD_RATE 115200
        sendSketchInfo("RX DEBUG Display", "1.0");
    // Traite les messages provenant de la Gateway
    void receive(const MyMessage &message){
      OTALogPrint(message);
    Pse confirm if the sketchs above are OK and run on your side.
    Thanks in advance.
