  3. NRF24L01+ with external antenna - don't work
6 Posts 4 Posters 2.8k Views 1 Watching
    Meister_Petz
    I have 2 of these NRF24L01+ with external antenna
    http://www.ebay.de/itm/310651702557
    if I connect them like the ones with onboard antenna I just get this message:
    "req node id"
    then nothing.
    if I connect the normal ones it works.
    any idea?
    Many Thanks
    Petz
    daulagariD 1 Reply Last reply
    • M Meister_Petz
      "req node id"
      then nothing.
      any idea?
      Many Thanks
      Petz
      daulagariD
      daulagariD
      daulagari
      Some questions:
      • What is the distance between the node and the gateway?
      • Did you point the antenna towards the gateway?
      • J
        J
        johnr
        I vad the same issue when upgrading to 1.4
        In my case solved by adding 47uf capacitor instead of 4.7uF.
        And I also had to change transmit power from max to high.
        • T
          therik
          Any idea why changing from max to high made it work? Do you think that the max setting was drawing more current than what you were supplying?
          • J
            J
            johnr
            I think it is an power issue, the le33cz I use can supply max 100ma, the bigger radio can use up to 115ma according to the data sheet. I have ordered some ld1117v33 to use with the reapeter nodes which I use with the antenna version of the radio, hopefully they solve the problem
              Meister_Petz
              The power was the right hint! I solved it with a capacitator and a separate 3.3 V regulator. Now everything works perfectly. Many thanks!
