  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 513.6k Views 73 Watching
    mvader
    @tekka - i do :) i use it every day
    • C cdr
      @tekka I feel really, really, REALLY stupid;
      I changed the channel in the mysensors config.h to 77, this was the reason no node would ever show up since the default mysbootloader uses the default channel 76.
      D'OH
      Thanks for your patience and help, everything is working now and I'm really happy!
      :+1:
      petewillP
      petewillP
      petewill
      I think I am running into the same thing. How did you fix this? I have many nodes so switching back to 76 is not a good option for me.
      C 1 Reply Last reply
      • petewillP petewill
        C
        C
        cdr
        You can edit myconfig.h and have te recompile after change.
        • petewillP
          petewillP
          petewill
          @cdr I've never recompiled a bootloader before but when I did some searching it seems that I need the .c file to do this. Maybe I'm missing something and I can recompile the .hex? How did you end up doing it? Thanks!
          • petewillP
            petewillP
            petewill
            I did some more testing and my issue definitely appears to be a result of changing the channel in MyConfig.h. I just built a serial gateway with channel 76 selected and everything worked perfectly. The only problem is I have over 20 nodes located throughout my house so re-uploading the code so they use that channel is not something I'd like to do if I can avoid it. Does anyone know how I can recompile the bootloader so I can change the channel?
            I tried the files @siklosi posted here http://forum.mysensors.org/topic/2319/how-to-make-complie-mysbootloader/7 but it did not work.
            N 1 Reply Last reply
            • N
              N
              niccodemi
              in firmware_config.csv file what is the first column "type" for? And where do I get "type" codes?
              tekkaT 1 Reply Last reply
              • N niccodemi
                tekkaT
                tekkaT
                tekka
                @niccodemi type can be any numeric value used to identify a specific firmware type - this value (together with FW version and the FW CRC) is used to automatically update the nodes.
                  N
                  N
                  niccodemi
                  @petewill did you have any success finding out how to change default channel?
                  petewillP 1 Reply Last reply
                  • F
                    F
                    Fabien
                    I recently switch to RFM69 and I know it's not yet compatible with MYSBootloader. But I can't find information about RFM69 and dualoptiboot support for OTA in MYSController (without a sensebender). Is it possible ? I have to make special config ? Thank !
                    AnticimexA 1 Reply Last reply
                    • F Fabien
                      AnticimexA
                      AnticimexA
                      Anticimex
                      #310
                      @Fabien DualOptiboot is completely radio agnostic. You should not need any custom config to use OTA with DualOptiboot and rfm69. You do need an external flash on your board though.
                      • F
                        F
                        Fabien
                        @Anticimex ok but in MYSController is there a way in the GUI for setting the bootloader (DualOptiboot or MYSBootloader) or is ti automatic. I ask this because you have to tell MYSBootloader your are running SenseBender (DualOptiboot).
                        • F Fabien
                          tekkaT
                          tekkaT
                          tekka
                          @Fabien yes, select "sensebender"...this will do the trick
                          • F
                            F
                            Fabien
                            Thank you @tekka I don't test your new bootloader beacuse I think you don't have RFM69 version (perhaps in th future ?)
                            • F Fabien
                              tekkaT
                              tekkaT
                              tekka
                              @Fabien perhaps, will have to get some RFM69 hardware first...
                              • N niccodemi
                                petewillP
                                petewillP
                                petewill
                                Sorry, don't know how I missed this. No, I haven't. I got sidetracked (kids) and I haven't had a chance to work on it further.
                                • petewillP
                                  petewillP
                                  petewill
                                  @niccodemi I just was able to upload the bootloader using the files provided by @siklosi posted here http://forum.mysensors.org/topic/2319/how-to-make-complie-mysbootloader/7. The difference is I used a USBASP (V2.0) instead of an UNO. It worked the first time uploading the blink sketch!! It was a pain getting the USBASP to work on Windows 8.1 but after I got the driver installed (and the wiring connections correct) it worked great. I haven't uploaded any sensor sketches yet but hopefully I'll have time to play with it soon.
                                    N
                                    N
                                    niccodemi
                                    @petewill thanks, I tried ch77 and it works great.
                                    • balloonguyB
                                      balloonguyB
                                      balloonguy
                                      Hi, download link for MYSController is broken. Error on attempt to download. thank you
                                      • balloonguyB balloonguy
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @balloonguy Not on my side. Please try again.
                                        balloonguyB 1 Reply Last reply
                                        • tekkaT tekka
                                          balloonguyB
                                          balloonguyB
                                          balloonguy
                                          @tekka thanks for the quick response - i have tried the {http://goo.gl/9DCWNo} with no luck, all i get is a "this page is not available" message. I have tried with different browsers and different pc's - still the same response.
                                          BTW- Merry Christmas.
                                          R 1 Reply Last reply
