  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 513.6k Views 73 Watching
  • dirkcD
    dirkcD
    dirkc
    I have problems using the OTA feature with MYSController.
    1. "undefined firmware/type" reported.
      My setup:
    • ESP8266 Gateway 2.1.1
    • MYSController Version 1.0.0beta (build 3314)
    • atmega328p chip with own pcb, internal osc 8MHz, and MYSBootloaderV13pre.hex (taken from the same zip file as MYSController.exe)
    The log file in MYSController shows "undefined firmware/type" :
    Where can I find the latest software (exe and boot loader)?
    1. the "Reload repo" toolbar button is always greyed, but the "firmware_config" is available, has all entries and the hex files are in the same directory.
    2. is there a more detailed description available for the columns of the "firmware_config" file?
    thanks in advance
    Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
    tekkaT 1 Reply Last reply
    • dirkcD dirkc
        My setup:
      thanks in advance
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      #442
      @dirkc If you are using MYSBootloader there is no need to define MY_OTA_FIRMWARE_FEATURE since the FW update happens offline, see here for additional infos.
      See here for a firmware_config.csv example:
      Type,Name,Version,File,Comments
      1,DoorSensor_V1,1,DoorSensorV1.hex,Door sensor version 1
      1,DoorSensor_V2,2,DoorSensorV2.hex,Door sensor version 2
      1,DoorSensor_V3,3,DoorSensorV3.hex,Door sensor version 3
      10,TestSensor,1,TestSensor.hex,Test FW
      11,LightSensor,1,LightSensor.hex,Light sensor
      20,TempSensor Indoor V1,1,TempSensorIndoorV1.hex,Temp. Sensor indoor V1
      20,TempSensor Indoor V2,2,TempSensorIndoorV2.hex,Temp. Sensor indoor V2
      30,TempSensor Outdoor V1,1,TempSensorOutdoorV1.hex,Temp. Sensor outdoor V2
      Impotant: All defined files need to be present in the directory, only comma delimiters are allowed.
      • R
        R
        romeo01
        wrote on last edited by romeo01
        #443
        With MSController 1.0.0 & SerialGateway with 2.2.0 MySensor lib, 1 problem occurs.
        MSController crash at the presentation step by the node
        Below what the node send when reeboot. (Debug log via Serial)
        0 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0-beta
        26 TSM:INIT
        27 TSF:WUR:MS=0
        34 TSM:INIT:TSP OK
        35 TSM:INIT:STATID=1
        37 TSF:SID:OK,ID=1
        39 TSM:FPAR
        75 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        1051 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        1056 TSF:MSG:FPAR OK,ID=0,D=1
        2083 TSM:FPAR:OK
        2084 TSM:ID
        2085 TSM:ID:OK
        2087 TSM:UPL
        2091 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        2101 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        2106 TSF:MSG:PONG RECV,HP=1
        2109 TSM:UPL:OK
        2110 TSM:READY:ID=1,PAR=0,DIS=1
        2115 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        2122 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        2129 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
        2139 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
        2155 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
        2162 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=OK:OTA Test 2
        2171 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
        2180 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Sensor 1
        2187 MCO:REG:REQ
        2190 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        2197 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        2202 MCO:PIM:NODE REG=1
        2204 MCO:BGN:STP
        2205 MCO:BGN:INIT OK,TSP=1
        Below is the log in MSController
        08/05/2017 18:12:26	RX	0;255;3;0;9;33925 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
        08/05/2017 18:12:26	RX	0;255;3;0;9;33931 TSF:MSG:BC
        08/05/2017 18:12:26	RX	0;255;3;0;9;33933 TSF:MSG:FPAR REQ,ID=1
        08/05/2017 18:12:26	RX	0;255;3;0;9;33937 TSF:PNG:SEND,TO=0
        08/05/2017 18:12:26	RX	0;255;3;0;9;33940 TSF:CKU:OK
        08/05/2017 18:12:26	RX	0;255;3;0;9;33943 TSF:MSG:GWL OK
        08/05/2017 18:12:26	RX	0;255;3;0;9;34102 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        08/05/2017 18:12:29	RX	0;255;3;0;9;37248 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
        08/05/2017 18:12:29	RX	0;255;3;0;9;37254 TSF:MSG:BC
        08/05/2017 18:12:29	RX	0;255;3;0;9;37257 TSF:MSG:FPAR REQ,ID=1
        08/05/2017 18:12:29	RX	0;255;3;0;9;37260 TSF:CKU:OK,FCTRL
        08/05/2017 18:12:29	RX	0;255;3;0;9;37263 TSF:MSG:GWL OK
        08/05/2017 18:12:30	RX	0;255;3;0;9;37669 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        08/05/2017 18:12:32	RX	0;255;3;0;9;40570 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        08/05/2017 18:12:32	RX	0;255;3;0;9;40579 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        08/05/2017 18:12:33	RX	0;255;3;0;9;40729 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:28000100E803E5750103
        08/05/2017 18:12:33	RX	1;255;4;0;0;28000100E803E5750103
        08/05/2017 18:12:33	INFO	BL version=259
        08/05/2017 18:12:33	INFO	No FW assigned
        08/05/2017 18:12:36	RX	0;255;3;0;9;44053 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:28000100E803E5750103
        08/05/2017 18:12:36	RX	1;255;4;0;0;28000100E803E5750103
        08/05/2017 18:12:36	INFO	BL version=259
        08/05/2017 18:12:36	INFO	No FW assigned
        08/05/2017 18:12:39	RX	0;255;3;0;9;47376 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:28000100E803E5750103
        08/05/2017 18:12:39	RX	1;255;4;0;0;28000100E803E5750103
        08/05/2017 18:12:39	INFO	BL version=259
        08/05/2017 18:12:39	INFO	No FW assigned
        08/05/2017 18:12:43	RX	0;255;3;0;9;50700 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:28000100E803E5750103
        08/05/2017 18:12:43	RX	1;255;4;0;0;28000100E803E5750103
        08/05/2017 18:12:43	INFO	BL version=259
        08/05/2017 18:12:43	INFO	No FW assigned
        08/05/2017 18:12:46	RX	0;255;3;0;9;54213 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        08/05/2017 18:12:46	RX	0;255;3;0;9;54219 TSF:MSG:BC
        08/05/2017 18:12:46	RX	0;255;3;0;9;54222 TSF:MSG:FPAR REQ,ID=1
        08/05/2017 18:12:46	RX	0;255;3;0;9;54226 TSF:PNG:SEND,TO=0
        08/05/2017 18:12:46	RX	0;255;3;0;9;54230 TSF:CKU:OK
        08/05/2017 18:12:46	RX	0;255;3;0;9;54232 TSF:MSG:GWL OK
        08/05/2017 18:12:47	RX	0;255;3;0;9;55224 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        08/05/2017 18:12:48	RX	0;255;3;0;9;56261 TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        08/05/2017 18:12:48	RX	0;255;3;0;9;56267 TSF:MSG:PINGED,ID=1,HP=1
        08/05/2017 18:12:48	RX	0;255;3;0;9;56273 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
        08/05/2017 18:12:48	RX	0;255;3;0;9;56286 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        08/05/2017 18:12:48	RX	0;255;3;0;9;56294 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        08/05/2017 18:12:48	RX	0;255;3;0;9;56302 TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
        08/05/2017 18:12:48	RX	1;255;0;0;17;2.2.0-beta
        08/05/2017 18:12:48	DEBUG	Update child id=255, type=S_ARDUINO_NODE
        08/05/2017 18:12:48	RX	0;255;3;0;9;56309 TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
        08/05/2017 18:12:48	RX	1;255;3;0;6;0
        08/05/2017 18:12:48	TX	1;255;3;0;6;M
        08/05/2017 18:12:48	RX	0;255;3;0;9;56328 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
        08/05/2017 18:12:48	RX	0;255;3;0;9;56335 TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=10,sg=0:OTA Test 2
        08/05/2017 18:12:48	RX	1;255;3;0;11;OTA Test 2
        08/05/2017 18:12:48	RX	0;255;3;0;9;56343 TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=0:2.0
        08/05/2017 18:12:48	RX	1;255;3;0;12;2.0
        08/05/2017 18:12:48	RX	0;255;3;0;9;56351 TSF:MSG:READ,1-1-0,s=1,c=0,t=3,pt=0,l=8,sg=0:Sensor 1
        Here a screenshot when MSController crash.
        When I click on "request presentation", same error.
        This error is only with SerialGateway & Library 2.2.0 beta
        With library 2.1.1that's ok
        • R romeo01
          26 TSM:INIT
          27 TSF:WUR:MS=0
          34 TSM:INIT:TSP OK
          37 TSF:SID:OK,ID=1
          39 TSM:FPAR
          2083 TSM:FPAR:OK
          2084 TSM:ID
          2085 TSM:ID:OK
          2087 TSM:UPL
          2109 TSM:UPL:OK
          2187 MCO:REG:REQ
          2204 MCO:BGN:STP
          tekkaT
          tekkaT
          tekka
          @romeo01 Thanks for reporting, this is a known issue with build 3314 and lib 2.2.0: The msg parser requires some changes - build 3316 is in preparation (also supporting new 2.2.0 features).
          V 1 Reply Last reply
          • siodS
            siodS
            siod
            Hi, I am trying your software but I only get "connection refused" though in the status bar it says Connected... what can I do?
            still learning...
            • tekkaT tekka
              V
              V
              vikasjee
              @tekka hi, can we access the previous build if that is working for MySensors2.1.1?
              • siodS siod
                tekkaT
                tekkaT
                tekka
                @siod Seems like something is wrong with your GW - either GW is not working or too many connections.
                • V vikasjee
                  tekkaT
                  tekkaT
                  tekka
                  @vikasjee What build are you looking for?
                  • tekkaT tekka
                    V
                    V
                    vikasjee
                    @tekka , I upgraded Arduino IDE from 1.6.0 to 1.8.2 recently. Burnt the gateway with the MySensors2.1.1 gateway sketch and the nodes bootloader with MysBootloader1.3.0beta3 from the master branch on github.
                    As per my understanding the Node with MysBootloader should connect to the Gateway (checked with MysController 1.0beta b3314) where i can specify the Firmware for this new node. But i am not able to get the Node entry in the left hand side tree in MysController. Upon checking the MysController Debug, there are a stream of messages from the node but are being endlessly repeated:
                    6/12/2017 19:24:59	RX	0;255;3;0;9;TSF:CKU:OK,FCTRL
                    6/12/2017 19:24:59	RX	0;255;3;0;9;TSF:MSG:GWL OK
                    6/12/2017 19:25:01	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                    6/12/2017 19:25:06	RX	0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=1,l=1,sg=0:235
                    6/12/2017 19:25:06	RX	0;255;3;0;9;TSF:MSG:BC
                    6/12/2017 19:25:06	RX	0;255;3;0;9;TSF:MSG:FPAR REQ,ID=255
                    6/12/2017 19:25:06	RX	0;255;3;0;9;TSF:CKU:OK,FCTRL
                    6/12/2017 19:25:06	RX	0;255;3;0;9;TSF:MSG:GWL OK
                    6/12/2017 19:25:08	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                    6/12/2017 19:25:09	RX	0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=1,l=1,sg=0:235
                    6/12/2017 19:25:09	RX	0;255;3;0;9;TSF:MSG:BC
                    6/12/2017 19:25:09	RX	0;255;3;0;9;TSF:MSG:FPAR REQ,ID=255
                    6/12/2017 19:25:09	RX	0;255;3;0;9;TSF:CKU:OK,FCTRL
                    6/12/2017 19:25:09	RX	0;255;3;0;9;TSF:MSG:GWL OK
                    I am unable to get to the root of the problem... and could not find any mention of a similar problem on this forum (searched far and wide :) )
                    Any pointers to a solution or hint of what may be wrong will definitely help me save time...
                    • V
                      V
                      vikasjee
                      @tekka , there seems to be an issue with the build 3314 and MYSBootloader for MySensors 2.1.1,as noted above. Any good, working previous version should do...
                      • V
                        V
                        vikasjee
                        wrote on last edited by vikasjee
                        #451
                        @tekka please help with the MysController build 3312 if that one works with MYSBootloader for MySensors 2.1.1 master.
                        • V vikasjee
                          tekkaT
                          tekkaT
                          tekka
                          @vikasjee Apologies for the late reply. This issue is not related to MYSController:
                          The debug log hints to some issues with the radio (range, connection) and/or power supply (node does not receive the find_parent_response message), please double-check the wiring, power supply (appropriate caps on both, GW and node), change the distance between GW and node, or try with different radio modules.
                          • tekkaT tekka
                            V
                            V
                            vikasjee
                            @tekka No Issues. Thanks for the response.
                            I have tried all of these with all my 35 radios (were all working before the upgrade) and equal number of nodes! :(
                            I will go through all this sequence once again though... Thanks for clearing the doubts on MYSController build. Indebted!
                            • S
                              swiss
                              Newbie can't make it happen...
                              I've been struggling for the last couple of days, trying to make the mysensors world to fly. But unfortunately i have no success so i will try to post one of my many trials, would be very glad if you could let me know what i'm missing...
                              Hardware:
                              • Aurduino Mini Pro
                              • W5100 ETH interface
                              • long-distance NRF24L01 (Gateway)
                              • NRF24L01+ 2.4GHz Antenna Wireless Transceiver Module (Sensor)
                              Software:
                              • https://github.com/mysensors/MySensors/blob/master/examples/GatewayW5100/GatewayW5100.ino (Gateway)
                              • https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/BinarySwitchSensor/BinarySwitchSensor.ino (Sensor)
                              All i did was to load both sketch to the according mini.
                              Of course changing the IP of the gateway.
                              I can ping the gateway using Windows terminal, but i can't access the gateway using the MYSController. As soon i try to dicover any node the connection is terminated by the remot side (entry in the debug window of MYSCtrl)
                              If i did understand it correct i do not have to load the Bootloader as of now (as long i do not need OTA)
                              Any help would be highly appriciated,
                              matt
                              • S swiss
                                Hardware:
                                • Aurduino Mini Pro
                                Software:
                                matt
                                Welcome to the MySensors community @swiss :-)
                                What does the debug output from the gateway say?
                                How is the gateway powered?
                                If you haven't already, take a look at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to fix them.
                                S 1 Reply Last reply
                                  swiss
                                  @mfalkvidd
                                  wow that was quick :-)
                                  The gateway is powered thru a breadboard 3.3V psu.
                                  Here is teh log dump of the gateway:
                                  0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  Thank you so much!
                                  • S swiss
                                    @mfalkvidd
                                    Thank you so much!
                                    #457
                                    @swiss could you post the entire log?
                                    EDIT: How much current can the breadboard psu provide? Which capacitor(s) are you using?
                                      and yes, you are correct that bootloader is only needed for FOTA.
                                        swiss
                                        @mfalkvidd
                                        0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
                                        0;255;3;0;9;TSM:INIT
                                        0;255;3;0;9;TSF:WUR:MS=0
                                        0;255;3;0;9;TSM:INIT:TSP OK
                                        0;255;3;0;9;TSM:INIT:GW MODE
                                        IP: 192.168.8.155
                                        0;255;3;0;9;MCO:BGN:STP
                                        0;255;3;0;9;TSF:PNG:SEND,TO=0
                                        • S swiss
                                          @mfalkvidd
                                          IP: 192.168.8.155
                                          @swiss nothing at all happens after TSF:MSG:BC ?
