  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 499.7k Views 73 Watching
  • tekkaT
    tekkaT
    tekka
    wrote on last edited by tekka
    #101
    MYSController Version 0.1.2.278 released
    New features:
    • Support MYSBootloader 2.0 / SHA (signing bootloader) ==> will be released in the nearest future
    • Support 1.5 framework (dev branch)
    • Parse MySensors log/debug messages
    • Div. options
    Changelog:
    • Moved send message dialog to main window
    • Handler adjustments
    • Bugfix FW upload in GW debug mode
    • Bugfix message logging
    Update via update button in MYSController or download here.
    • D
      D
      derry
      Brilliant work! Ran perfectly under Wine on Fedora linux by using /dev/ttyUSB0 for serial port [after first checking my gateway was connected to that port]. Solved a problem I was having with a sensor getting assigned a weird node ID. Saved me loads of time tracking down the problem, many thanks for sharing this tool, much appreciated!
      • R
        R
        rickmontana83
        This is awesome!
        Any plans to provide source or a back-end API that could be used to connect this up to an HA controller? That way you could control everything downstream in the MySensors cloud from this app, and everything upstream (the HA controller and the cloud) could interface with a much richer (and presumably more robust) infrastructure rather than yet again figuring out how to parse the bits coming off of the serial port...
        ch3b7C tekkaT 2 Replies Last reply
        • R rickmontana83
          This is awesome!
          ch3b7C
          ch3b7C
          ch3b7
          @rickmontana83 parse the data from the serial port is easy, im put in other post in this forum with a part of my code in vb.net
          • R rickmontana83
            This is awesome!
            tekkaT
            tekkaT
            tekka
            @rickmontana83 Serial API is described here.
            • FrancoisF
              FrancoisF
              Francois
              wrote on last edited by Francois
              #106
              @tekka once you flash the Arduino with the MYSBootloader is the only why that now you can programme the Arduino is though the MYSController software?
              tekkaT 1 Reply Last reply
              • FrancoisF Francois
                tekkaT
                tekkaT
                tekka
                #107
                @Francois AFAIK, MYSController and NodeJsController (see framework, link here) are the only controllers that provide OTA updates via bootloader. Both controllers use the OTA protocol described here. However, MYSBootloader 2.0 will support updates OTA and via IDE.
                • FrancoisF
                  FrancoisF
                  Francois
                  @tekka the reason I asked I has a problem where I had 2 node with the same node ID and a could not do a OTA via MYSController. As i keep the same ID. I clear the EEPROM and still l it did not work. So the only why I could get the node working was to reflash the boot loader.
                    tekkaT
                    tekkaT
                    tekka
                    #109
                    @Francois in general, if two nodes have the same ID, you have to disconnect one node and reassign ID/clear eeprom of the other node:
                    • MYSBootloader 1.1: use the bootloader commands in MYSController (right mouse click on the node, then reassign ID or clear EEPROM)
                    • MYSBootloader 1.0: upload the clear eeprom sketch and have the controller reassigning the ID
                    • FrancoisF
                      FrancoisF
                      Francois
                      #110
                      @tekka I doing this and still the node ID is not changing. I change this node to 4 and it still come up as Node 3. The reboot command also don't reboot the device. I have to do a manual reset on the device is this normal?
                      upload-fcaad57f-daaa-4259-8905-9c148719e332
                        tekkaT
                        tekkaT
                        tekka
                        @Francois ok, I see - can you post or send the log (with debug mode on) to myscontroller at gmail dot com.
                        If the reboot command is not functioning properly you may have a corrupt routing table: Try clearing the routing table of the node & all routing nodes in between (right mouse click on the node in the routing panel|clear routing table) then try again to reboot.
                        • FrancoisF
                          FrancoisF
                          Francois
                          @tekka will it be a problem if I don't have all my node on the MYSbootloader? Currently I only have 2 of my nodes with MYSBootloader. I am still testing before I change all the nodes
                            tekkaT
                            tekkaT
                            tekka
                            @Francois should be fine
                            • FrancoisF
                              FrancoisF
                              Francois
                              @tekka log file send
                              • FrancoisF
                                FrancoisF
                                Francois
                                #115
                                @tekka See below it reboot the first time when I try it the seconde time it did
                                not it just say reboot
                                upload-c74f717f-972d-42a4-8346-7dac5fd0bc3a
                                Here is my routing Tabel:
                                upload-eab02958-9c75-4343-b325-7578209d761f
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @Francois the node has AUTO ID or fix assigned ID (i.e. 91?) - if so, this may be an issue in the dev branch
                                  • rvendrameR
                                    rvendrameR
                                    rvendrame
                                    Anyone who owns a Vera controller, and perhaps was able to connect this nice MYSController to the mySensors serial-gateway hooked into Vera USB?
                                    The serial port is exposed in TCP/IP by Vera via ser2net, however I wasn't successful by setting MYSController to <my-vera-ip>:3482 (3482 is the port displayed in Vera -> APPS -> Develop Apps -> Serial port config ) .
                                    (maybe the Vera MYSensor plugin opens the serial connection to GW in 'exclusive' mode or something like that? )
                                    If I remove the GW from Vera USB and plug in my computer, MYSController works fine.
                                    Anyone? Am I wanting too much?
                                    ESP8266 GW + mySensors 2.3.2
                                    Alexa / Google Home
                                    • J
                                      J
                                      JoergP
                                      I'm new to MySensors and playing around with this implementation since some weeks. I implemented an interface from serial to MQTT per python and everything is running fine so far. The last days I spend some time with the bootloader (it is a great feature!!!). I created also a python mqtt client that will take care on that.
                                      I got really crazy the last 2 days with the CRC calculation. I always got a different CRC as as the MYSController. Now I found out, that it seems that the last byte within the HEX file is interpreted as 0xFF instead of the real data. I flashed now one sensor with the MYSController and as I can see in the log-file -> the last byte is read from the HEX as wrong value (0xFF instead of 0x14) -> therefore the HEX file is not flashed correctly (last byte is wrong) -> it seems that this is a bug in MYSController. (I'm using version 0.1.2.278)
                                      Can you check that please?
                                      • J JoergP
                                        tekkaT
                                        tekkaT
                                        tekka
                                        #119
                                        @JoergP Indeed, bug confirmed. There is an error in the block padding code. I will push the update soon. Thanks for reporting!
                                        • C
                                          C
                                          cdr
                                          First of all, thanks Tekka for the great MYScontroller!
                                          I want to get started with the MYSbootloader but I can't get it to work. I've followed each step securely but I never "see" my arduino in MYScontroller after flashing the bootloader. Perhaps I misunderstand the theory behind the bootloader? Maybe the fuses are wrong, I don't know.
                                          Perhaps someone can reply to the following;
                                          • Can I just attach a radio module to an Arduino Nano as instructed on the site, clear the eeprom and then burn the bootloader using usbasp? (as instructed in this thread) Or do I need to upload the gateway sketch before burning the bootloader?
                                          • I have a hard time understanding what the bootloader does, I think it enables low level nrf functionality for OTA and Myscontroller instructions like reboot and clear eeprom etc. But when I upload a sketch does that mean the bootloader inits the nrf first and then the uploaded sketch will just re-init the nrf again?
                                          • Is there a way to debug the bootloader?
                                          Have a good laugh if you will at these noob questions, but any help is appreciated :)
