  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 499.7k Views 73 Watching
  • C
    C
    cdr
    It is possible to burn the bootloader to an Arduino Uno right? (if not please skip below and I will rtfm some more)
    Could anyone please explain me what I am doing wrong here? I use avrdudess (http://blog.zakkemble.co.uk/avrdudess-a-gui-for-avrdude/) to program the bootloader.hex (also tried the supplied method) but no dice;
    Writing the bootloader seems to work;
    Detected 1e950f = ATmega328P
    MYSBootloader.hex: 2.002 / 32.768 Bytes (6,11%)
    avrdude.exe: set SCK frequency to 1500000 Hz
    avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update.
    avrdude.exe: AVR device initialized and ready to accept instructions
    Reading | ################################################## | 100% 0.00s
    avrdude.exe: Device signature = 0x1e950f
    avrdude.exe: erasing chip
    avrdude.exe: reading input file "C:\Users\codar\Desktop\MYSController_0_1_2_280\Bootloader\MYSBootloader.hex"
    avrdude.exe: input file C:\Users\codar\Desktop\MYSController_0_1_2_280\Bootloader\MYSBootloader.hex auto detected as Intel Hex
    avrdude.exe: writing flash (32722 bytes):
    Writing | ################################################## | 100% 0.00s
    avrdude.exe: 32722 bytes of flash written
    avrdude.exe: verifying flash memory against C:\Users\codar\Desktop\MYSController_0_1_2_280\Bootloader\MYSBootloader.hex:
    avrdude.exe: load data flash data from input file C:\Users\codar\Desktop\MYSController_0_1_2_280\Bootloader\MYSBootloader.hex:
    avrdude.exe: input file C:\Users\codar\Desktop\MYSController_0_1_2_280\Bootloader\MYSBootloader.hex contains 32722 bytes
    avrdude.exe: reading on-chip flash data:
    avrdude.exe: verifying ...
    avrdude.exe: 32722 bytes of flash verified
    However tech life wouldn't be techlife without days of endless debugging
    Setting the extended fuse fails verification
    avrdude.exe: reading input file "0xF7"
    avrdude.exe: writing lfuse (1 bytes):
    avrdude.exe: 1 bytes of lfuse written
    avrdude.exe: verifying lfuse memory against 0xF7:
    avrdude.exe: load data lfuse data from input file 0xF7:
    avrdude.exe: input file 0xF7 contains 1 bytes
    avrdude.exe: reading on-chip lfuse data:
    avrdude.exe: 1 bytes of lfuse verified
    avrdude.exe: reading input file "0xDA"
    avrdude.exe: writing hfuse (1 bytes):
    avrdude.exe: 1 bytes of hfuse written
    avrdude.exe: verifying hfuse memory against 0xDA:
    avrdude.exe: load data hfuse data from input file 0xDA:
    avrdude.exe: input file 0xDA contains 1 bytes
    avrdude.exe: reading on-chip hfuse data:
    avrdude.exe: 1 bytes of hfuse verified
    avrdude.exe: reading input file "0xFE"
    avrdude.exe: writing efuse (1 bytes):
    Writing |  ***failed;
    ################################################## | 100% 0.03s
    avrdude.exe: 1 bytes of efuse written
    avrdude.exe: verifying efuse memory against 0xFE:
    avrdude.exe: load data efuse data from input file 0xFE:
    avrdude.exe: input file 0xFE contains 1 bytes
    avrdude.exe: reading on-chip efuse data:
    avrdude.exe: verification error, first mismatch at byte 0x0000
                 0x06 != 0xfe
    avrdude.exe: verification error; content mismatch
    avrdude.exe done.  Thank you.
    This last error is giving me headaches, why the "first mismatch at byte 0x0000 0x06 != 0xfe" error?
    Really hope someone can enlighten me...
    tekkaT 1 Reply Last reply
    • C cdr
                   0x06 != 0xfe
      tekkaT
      tekkaT
      tekka
      @cdr the efuse only uses the lower 3 bits: with AVRDude set 0x06, with AVRStudio set 0xFE. You can verify this with the fuse calculator.
      • F
        F
        Fabien
        I try to uplaod sketch via OTA but it doesn''t work.
        I have sensebender with stock bootloader. Gateway is connect to an ODROID C1 with ser2net and i connect to ser2net. I can see all incoming traffic for my sensors.
        I upload sensebender default sketch from dev branch using MySensors dev branch too.
        I tell MYSController sensors is battery powered.
        I try with the two provided example but nothing happen in log or anything else
        M 1 Reply Last reply
        • F Fabien
          mvader
          wrote on last edited by mvader
          #144
          check in the sensebender announcement thread. I had the same question. Hek responded with what needed to be done to make it work.
          I didn't get a chance to try his solutions yet to see if it works. if you do, post and let us know.
          edit: here
          http://forum.mysensors.org/topic/1345/sensebender-micro/139
          • D
            D
            Dirk_H
            @Fabien
            I dont understand what you mean by "I told MysController" that the node is battery powered. It should find that out automatically I think. Anyway I'm pretty sure that I read somewhere that battery powered sensors cant be updated OTA. (If it relly is battery powered). I think I read a define somewhere that disables the firmware low level commands in the MySensors Library if the Node is battery powered.
              No there isn't. But battery powered sensors most likely sleep most of the time so they won't receive any update command. And a fw updates over-the-air would probably drain batteries pretty quick.
              • C
                C
                cdr
                @tekka I feel really, really, REALLY stupid;
                I changed the channel in the mysensors config.h to 77, this was the reason no node would ever show up since the default mysbootloader uses the default channel 76.
                D'OH
                Thanks for your patience and help, everything is working now and I'm really happy!
                :+1:
                N petewillP 2 Replies Last reply
                • O
                  O
                  Omemanti
                  wrote on last edited by Omemanti
                  #148
                  Hi. I was wondering if someone could get the irrigation controller working with this program?
                  I'm new to this all, and so far this the easiest controller that I came across. ( got the gateway etc working with almost no effort)
                  • F
                    F
                    fitzpatrick
                    Hi, nice work. Is there any chances that you add the possibility to log the nodes information to a mysql database ?
                    • 5546dug5
                      5546dug5
                      5546dug
                      Hi @tekka
                      I am having trouble understanding the error codes on this gui.
                      It is the solar mini weather stn on proto board and it is not working properly.
                      At this minute I see that the g/w code is telling me 4-4-5-0 ,there was a node 5 in my My Sensors package and it was configured as a repeater but it is not here as it connected laptop> usb port/cord> ftdi 3.3v> 3.3 v promini.
                      As the code cannot get to and from node 5 it is a down as a st=fail
                      Is there a why to change this in your program to allow continuing debugging my sketch?
                      Am I again missing something?
                      • 5546dug5
                        5546dug5
                        5546dug
                        • 5546dug5 5546dug
                          tekkaT
                          tekkaT
                          tekka
                          @5546dug the log looks like a sensor log, try connecting MYSController to the gateway...
                          • rvendrameR
                            rvendrameR
                            rvendrame
                            Hello guys, I'm trying to burn the MYSBootloader.hex into some Pro minis (clones) here, however after burning it, they get somehow 'bricked' :
                            • I'm using my Uno "as ISP" on IDE 1.6.4
                            • I've followed the step-by-step tutorial posted above by @tekka
                            • My pro-minis are 5V, 16Mhz, external clock , 328p, supposedly a perfect match with 'boards.txt' info...
                            • "Burn bootloader" ends successful, with "Done burning boot loader" message.
                            • After that, the pro-mini pin 13 led flashes in a kind of random pattern, and it is not possible to upload any sketch, nor any kind of serial monitor on any speed.
                            • I can revert it, by selecting the standard 'Arduino Pro or Pro Mini' board , and burn boot loader again. It makes the pro-mini gets back to live, I can upload my sketches and serial monitor it.
                            So my questions:
                            • I don't have extra eprom connected --- Is it mandatory? I've read somewhere that it can be disabled, but can't find the instructions anymore...
                            • Fuse adjustments?
                            • What else can I do in order to troubleshooting it?
                            Thanks!
                            ESP8266 GW + mySensors 2.3.2
                            Alexa / Google Home
                            • scalzS
                              scalzS
                              wrote on last edited by scalz
                              #154
                              @rvendrame: it seems to be wrong fuses. MYSBootloader does not use extra eeprom. It's DualOptiboot which uses one. You need to set fuses. Then burn bootloader. For fuses you need to look in boards.txt . It should work. For setting fuses, I use usbasp. I never tried with uno.
                              • rvendrameR
                                rvendrameR
                                rvendrame
                                @scalz, thanks for the reply. BTW, did you see this?
                                Well, with standard bootloader (working), my pro-minis have fuses as FF DA 05 (Low/High/Ext).
                                The MYSBootloader.hex boot loader (not working) is set in boards.txt with F7 DA 06.
                                I have played with all possible combinations (including changing values in boards.txt), no luck.
                                Maybe I have to compile my own version of MYSBootloader? Sorry, this is all new to me...
                                Thx again
                                Alexa / Google Home
                                • scalzS
                                  scalzS
                                  @rvendrame: Hi I don't have a mac. But I use a similar tool for win (avrdudess). but your link seems ok.
                                  You don't have to recompile MYSBootloader. MYSBootloader needs to match fuses. If not, it will blink like you have seen. Do you have an usbasp? very useful. So you need to burn fuses F7 DA 06. Did you try that? And then burn bootloader.
                                  Be careful when burning fuses, don't try combination or you will semi-brick atmel chip (meaning you could not be able to reprogram it normal spi way). Never enable RSTDISBL and DWEN bits in fuse. You can see all of this here http://www.engbedded.com/fusecalc/ very useful too!
                                  If in future you want to test new ota, I have made a small breadboard to test it. You can find it here : https://oshpark.com/profiles/scalz You will need to solder eeprom and atsha.
                                  • rvendrameR
                                    rvendrameR
                                    rvendrame
                                    @scalz, yes I have tried to burn fuses F7 DA 06, and then MYSBootloader, no joy.
                                    Maybe the main diference is the low fuse F7 ( = Ext.Clock full-swing Crystal ) , as my pro-minis run fine with FF ( = Ext. Crystal Osc 8.MHz ) ?
                                    Alexa / Google Home
                                    • rvendrameR
                                      rvendrameR
                                      rvendrame
                                      @scalz , one more thing: What speed did you set? The AVRFuses seems to work on at 19200 bps --- Could this be a problem?
                                      And moreover --- You mentioned that extra eprom is not required --- But what about atsha? I don't have that either... (just pro-mini + radio ). Is it required for OTA?
                                      Alexa / Google Home
                                      • scalzS
                                        scalzS
                                        @rvendrame: I am not at home at this moment. but I will check. baudrate is already set up in .hex and in boards.txt . So I think it should work..strange thing. I don't know MYSBootloader so. maybe grandmaster @Tekka have an idea:grinning: maybe something has changed. I don't know.
                                        extra eeprom is for new ota in mysensors 1.5
                                        ATSHA is optional, it is just on the board too. It is for authentication in 1.5 too.
                                        • rvendrameR
                                          rvendrameR
                                          rvendrame
                                          I'm using 1.5 --- So do I need the extra eprom ?
                                          Alexa / Google Home
