  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 514.7k Views 73 Watching
  • FrancoisF
    FrancoisF
    Francois
    wrote on last edited by Francois
    #110
    @tekka I doing this and still the node ID is not changing. I change this node to 4 and it still come up as Node 3. The reboot command also don't reboot the device. I have to do a manual reset on the device is this normal?
    upload-fcaad57f-daaa-4259-8905-9c148719e332
    tekkaT 1 Reply Last reply
    • FrancoisF Francois
      tekkaT
      tekkaT
      tekka
      @Francois ok, I see - can you post or send the log (with debug mode on) to myscontroller at gmail dot com.
      If the reboot command is not functioning properly you may have a corrupt routing table: Try clearing the routing table of the node & all routing nodes in between (right mouse click on the node in the routing panel|clear routing table) then try again to reboot.
      • FrancoisF
        FrancoisF
        Francois
        @tekka will it be a problem if I don't have all my node on the MYSbootloader? Currently I only have 2 of my nodes with MYSBootloader. I am still testing before I change all the nodes
          tekkaT
          tekkaT
          tekka
          @Francois should be fine
          • FrancoisF
            FrancoisF
            Francois
            @tekka log file send
            • FrancoisF
              FrancoisF
              Francois
              #115
              @tekka See below it reboot the first time when I try it the seconde time it did
              not it just say reboot
              upload-c74f717f-972d-42a4-8346-7dac5fd0bc3a
              Here is my routing Tabel:
              upload-eab02958-9c75-4343-b325-7578209d761f
                tekkaT
                tekkaT
                tekka
                @Francois the node has AUTO ID or fix assigned ID (i.e. 91?) - if so, this may be an issue in the dev branch
                • rvendrameR
                  rvendrameR
                  rvendrame
                  Anyone who owns a Vera controller, and perhaps was able to connect this nice MYSController to the mySensors serial-gateway hooked into Vera USB?
                  The serial port is exposed in TCP/IP by Vera via ser2net, however I wasn't successful by setting MYSController to <my-vera-ip>:3482 (3482 is the port displayed in Vera -> APPS -> Develop Apps -> Serial port config ) .
                  (maybe the Vera MYSensor plugin opens the serial connection to GW in 'exclusive' mode or something like that? )
                  If I remove the GW from Vera USB and plug in my computer, MYSController works fine.
                  Anyone? Am I wanting too much?
                  ESP8266 GW + mySensors 2.3.2
                  Alexa / Google Home
                  • J
                    J
                    JoergP
                    I'm new to MySensors and playing around with this implementation since some weeks. I implemented an interface from serial to MQTT per python and everything is running fine so far. The last days I spend some time with the bootloader (it is a great feature!!!). I created also a python mqtt client that will take care on that.
                    I got really crazy the last 2 days with the CRC calculation. I always got a different CRC as as the MYSController. Now I found out, that it seems that the last byte within the HEX file is interpreted as 0xFF instead of the real data. I flashed now one sensor with the MYSController and as I can see in the log-file -> the last byte is read from the HEX as wrong value (0xFF instead of 0x14) -> therefore the HEX file is not flashed correctly (last byte is wrong) -> it seems that this is a bug in MYSController. (I'm using version 0.1.2.278)
                    Can you check that please?
                    • J JoergP
                      tekkaT
                      tekkaT
                      tekka
                      wrote on last edited by tekka
                      #119
                      @JoergP Indeed, bug confirmed. There is an error in the block padding code. I will push the update soon. Thanks for reporting!
                      • C
                        C
                        cdr
                        First of all, thanks Tekka for the great MYScontroller!
                        I want to get started with the MYSbootloader but I can't get it to work. I've followed each step securely but I never "see" my arduino in MYScontroller after flashing the bootloader. Perhaps I misunderstand the theory behind the bootloader? Maybe the fuses are wrong, I don't know.
                        Perhaps someone can reply to the following;
                        • Can I just attach a radio module to an Arduino Nano as instructed on the site, clear the eeprom and then burn the bootloader using usbasp? (as instructed in this thread) Or do I need to upload the gateway sketch before burning the bootloader?
                        • I have a hard time understanding what the bootloader does, I think it enables low level nrf functionality for OTA and Myscontroller instructions like reboot and clear eeprom etc. But when I upload a sketch does that mean the bootloader inits the nrf first and then the uploaded sketch will just re-init the nrf again?
                        • Is there a way to debug the bootloader?
                        Have a good laugh if you will at these noob questions, but any help is appreciated :)
                        • C cdr
                          tekkaT
                          tekkaT
                          tekka
                          Yes, simply attach the radio and burn the bootloader with the correct fuse settings (see the fuses.txt file in the bootloader directory). If you intend to use MYSController, set AutoID to automatically assign IDs to the nodes.
                          Yes, that's correct. The bootloader is a small piece of code located at the end of the flash area that is (if the fuses are set accordingly) executed first upon rebooting and allows for low-level OTA updates.
                          Yes, there are several ways (e.g. visual with LED, serial output, or AVR DebugWire)...you may want to google these topics for further information..
                          no problem :)
                          • C
                            C
                            cdr
                            Hi tekka,
                            Thanks for the response and clarification. I think I need more knowledge about fuses and bootloaders, it could be that the arduino clones are giving me sh&t.
                            Looking forward to my success and MYSloader 2.0 ofcourse!
                            Thanks again for all your work.
                            • tekkaT
                              tekkaT
                              tekka
                              MYSController Version 0.1.2.280 released
                              Changelog:
                              • Bugfix FW padding (thanks @JoergP)
                              • Handler rework
                              • Logging format rework
                              • Support battery-powered/sleeping nodes
                              • Refactoring
                              Update via update button in MYSController or download here.
                                Mickey
                                This is the most helpful tool I used since I started messing around with mysensors.
                                I hate to nag but this tool source code would be a giant step to someone looking to create a new controller by himself.
                                • R
                                  R
                                  robosensor
                                  Hello, how to verify right bootloader is uploaded to arduino?
                                  I'm using two Arduino Pro Mini 328 5.0V 16Mhz, one as ArduinoISP programmer and one as sensor node to upload bootloader and firmware.
                                  I followed manual (http://forum.mysensors.org/topic/838/windows-gui-controller-for-mysensors/76) step by step.
                                  I have tried MYSBootloader.hex coming from latest MYSController 0.1.2.280 and MYSBootloader.hex (1.1) from github with same results.
                                  Upload log is here:
                                  C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM10 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x06:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xF7:m
                                           Using Port                    : COM10
                                           Programmer Type : STK500
                                           Hardware Version: 2
                                           Firmware Version: 1.18
                                           Topcard         : Unknown
                                           Vtarget         : 0.0 V
                                           Varef           : 0.0 V
                                           Oscillator      : Off
                                           SCK period      : 0.1 us
                                  Reading | ################################################## | 100% 0.05s
                                  avrdude: erasing chip
                                  Writing | ################################################## | 100% 0.03s
                                  avrdude: verifying ...
                                  Writing | ################################################## | 100% 0.02s
                                  avrdude: reading input file "0xF7"
                                  C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM10 -b19200 -Uflash:w:C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:i -Ulock:w:0x0F:m
                                           Copyright (c) 2007-2009 Joerg Writing | ################################################## | 100% 0.02s
                                  avrdude: verifying lfuse memory against 0xF7:
                                  avrdude: load data lfuse data from input file 0xF7:
                                  avrdude: input file 0xF7 contains 1 bytes
                                  avrdude done.  Thank you.
                                  Wunsch
                                           Using Port                    : COM10
                                           Hardware Version: 2
                                           Topcard         : Unknown
                                           Vtarget         : 0.0 V
                                           Varef           : 0.0 V
                                           Oscillator      : Off
                                           SCK period      : 0.1 us
                                  Reading | ################################################## | 100% 0.06s
                                  avrdude: reading input file "C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex"
                                  Writing | ################################################## | 100% -0.00s
                                  avrdude: verifying flash memory against C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:
                                  avrdude: load data flash data from input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:
                                  avrdude: input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex contains 32722 bytes
                                  avrdude: reading input file "0x0F"
                                  Writing | ################################################## | 100% 0.05s
                                  avrdude: verifying lock memory against 0x0F:
                                  avrdude: load data lock data from input file 0x0F:
                                  avrdude: input file 0x0F contains 1 bytes
                                  Fuses looks like right:
                                  avrdude: safemode: lfuse reads as F7
                                  avrdude: safemode: hfuse reads as DA
                                  avrdude: safemode: efuse reads as 6
                                  MYSController log after node with new bootloader start:
                                  14.06.2015 10:14:46	STARTUP	Initialize message logging
                                  14.06.2015 10:14:46	STARTUP	MYSController 0.1.2.280
                                  14.06.2015 10:14:46	STARTUP	FPC 2.6.4 / Lazarus 1.4
                                  14.06.2015 10:14:46	STARTUP	still under development :) tekka 2015
                                  14.06.2015 10:14:46	STARTUP	Load INI file...
                                  14.06.2015 10:14:46	STARTUP	INI version 0.1.2.280
                                  14.06.2015 10:14:46	INFO	*** Logging START ***
                                  14.06.2015 10:14:46	VERSION	MYSController 0.1.2.280
                                  14.06.2015 10:14:46	STARTUP	INI file loaded
                                  14.06.2015 10:14:46	STARTUP	Loading FW repository...
                                  14.06.2015 10:14:46	REPO	FW "Blink" loaded. t=10, v=1, blocks=72, crc=0xD098
                                  14.06.2015 10:14:46	REPO	FW "TimeReporter" loaded. t=20, v=1, blocks=840, crc=0x4AC5
                                  14.06.2015 10:14:46	REPO	FW repository loaded. Items=2
                                  14.06.2015 10:14:46	STARTUP	Initialize message types
                                  14.06.2015 10:14:46	NODE	New node discovered, node id=0
                                  14.06.2015 10:14:46	NODE	New node discovered, node id=255
                                  14.06.2015 10:14:49	INFO	Connected to 192.168.0.1:12345
                                  14.06.2015 10:14:59	UPDATE	4295098648
                                  14.06.2015 10:21:26	CHILD	New child discovered, node id=0, child id=0
                                  14.06.2015 10:21:26	RX	0;0;3;0;9;read: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  14.06.2015 10:21:26	RX	0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,st=bc:0
                                  14.06.2015 10:21:28	RX	0;0;3;0;9;read: 3-3-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  14.06.2015 10:21:28	RX	0;0;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=ok:0
                                  14.06.2015 10:21:30	RX	0;0;3;0;9;read: 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                  14.06.2015 10:21:30	NODE	New node discovered, node id=3
                                  14.06.2015 10:21:30	CHILD	New child discovered, node id=3, child id=internal
                                  14.06.2015 10:21:30	TX	3;255;3;0;6;M
                                  14.06.2015 10:21:30	RX	3;255;3;0;6;0
                                  14.06.2015 10:21:30	RX	0;0;3;0;9;send: 0-0-3-3 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                                  14.06.2015 10:21:32	RX	0;0;3;0;9;read: 3-3-0 s=255,c=3,t=11,pt=0,l=7,sg=0:Balcony
                                  14.06.2015 10:21:32	RX	3;255;3;0;11;Balcony
                                  14.06.2015 10:21:32	RX	0;0;3;0;9;read: 3-3-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                  14.06.2015 10:21:32	RX	3;255;3;0;12;1.0
                                  14.06.2015 10:21:32	RX	0;0;3;0;9;read: 3-3-0 s=1,c=0,t=16,pt=0,l=20,sg=0:Photoconductive Cel
                                  14.06.2015 10:21:32	CHILD	New child discovered, node id=3, child id=1
                                  14.06.2015 10:21:32	DEBUG	Update child id=1, type=LIGHT_LEVEL
                                  14.06.2015 10:21:32	RX	3;1;0;0;16;Photoconductive Cell
                                  14.06.2015 10:21:32	RX	0;0;3;0;9;read: 3-3-0 s=2,c=0,t=6,pt=0,l=3,sg=0:ds0
                                  14.06.2015 10:21:32	CHILD	New child discovered, node id=3, child id=2
                                  14.06.2015 10:21:32	DEBUG	Update child id=2, type=TEMP
                                  14.06.2015 10:21:32	RX	3;2;0;0;6;ds0
                                  14.06.2015 10:21:32	RX	0;0;3;0;9;read: 3-3-0 s=3,c=0,t=6,pt=0,l=3,sg=0:ds1
                                  14.06.2015 10:21:32	CHILD	New child discovered, node id=3, child id=3
                                  14.06.2015 10:21:32	DEBUG	Update child id=3, type=TEMP
                                  14.06.2015 10:21:32	RX	3;3;0;0;6;ds1
                                  14.06.2015 10:21:32	RX	0;0;3;0;9;read: 3-3-0 s=4,c=0,t=6,pt=0,l=3,sg=0:ds2
                                  14.06.2015 10:21:32	CHILD	New child discovered, node id=3, child id=4
                                  14.06.2015 10:21:32	DEBUG	Update child id=4, type=TEMP
                                  14.06.2015 10:21:32	RX	3;4;0;0;6;ds2
                                  14.06.2015 10:21:32	RX	0;0;3;0;9;read: 3-3-0 s=5,c=0,t=6,pt=0,l=3,sg=0:ds3
                                  14.06.2015 10:21:32	CHILD	New child discovered, node id=3, child id=5
                                  14.06.2015 10:21:32	DEBUG	Update child id=5, type=TEMP
                                  14.06.2015 10:21:32	RX	3;5;0;0;6;ds3
                                  14.06.2015 10:21:33	RX	0;0;3;0;9;read: 3-3-0 s=6,c=0,t=6,pt=0,l=3,sg=0:ds4
                                  14.06.2015 10:21:33	CHILD	New child discovered, node id=3, child id=6
                                  14.06.2015 10:21:33	DEBUG	Update child id=6, type=TEMP
                                  14.06.2015 10:21:33	RX	3;6;0;0;6;ds4
                                  14.06.2015 10:21:33	RX	0;0;3;0;9;read: 3-3-0 s=7,c=0,t=6,pt=0,l=3,sg=0:ds5
                                  14.06.2015 10:21:33	CHILD	New child discovered, node id=3, child id=7
                                  14.06.2015 10:21:33	DEBUG	Update child id=7, type=TEMP
                                  14.06.2015 10:21:33	RX	3;7;0;0;6;ds5
                                  14.06.2015 10:21:33	RX	0;0;3;0;9;read: 3-3-0 s=8,c=0,t=6,pt=0,l=3,sg=0:ds6
                                  14.06.2015 10:21:33	CHILD	New child discovered, node id=3, child id=8
                                  14.06.2015 10:21:33	DEBUG	Update child id=8, type=TEMP
                                  14.06.2015 10:21:33	RX	3;8;0;0;6;ds6
                                  14.06.2015 10:21:33	RX	0;0;3;0;9;read: 3-3-0 s=9,c=0,t=6,pt=0,l=3,sg=0:ds7
                                  14.06.2015 10:21:33	CHILD	New child discovered, node id=3, child id=9
                                  14.06.2015 10:21:33	DEBUG	Update child id=9, type=TEMP
                                  14.06.2015 10:21:33	RX	3;9;0;0;6;ds7
                                  14.06.2015 10:21:33	RX	0;0;3;0;9;read: 3-3-0 s=10,c=0,t=6,pt=0,l=3,sg=0:ds8
                                  14.06.2015 10:21:33	CHILD	New child discovered, node id=3, child id=10
                                  14.06.2015 10:21:33	DEBUG	Update child id=10, type=TEMP
                                  14.06.2015 10:21:33	RX	3;10;0;0;6;ds8
                                  14.06.2015 10:21:33	RX	0;0;3;0;9;read: 3-3-0 s=11,c=0,t=6,pt=0,l=3,sg=0:ds9
                                  14.06.2015 10:21:33	CHILD	New child discovered, node id=3, child id=11
                                  14.06.2015 10:21:33	DEBUG	Update child id=11, type=TEMP
                                  14.06.2015 10:21:33	RX	3;11;0;0;6;ds9
                                  14.06.2015 10:21:33	RX	0;0;3;0;9;read: 3-3-0 s=1,c=1,t=23,pt=2,l=2,sg=0:49
                                  14.06.2015 10:21:33	RX	3;1;1;0;23;49
                                  14.06.2015 10:21:36	RX	0;0;3;0;9;read: 3-3-0 s=3,c=1,t=0,pt=7,l=5,sg=0:26.5625
                                  14.06.2015 10:21:36	RX	3;3;1;0;0;26.5625
                                  14.06.2015 10:21:37	RX	0;0;3;0;9;read: 3-3-0 s=1,c=1,t=23,pt=2,l=2,sg=0:49
                                  14.06.2015 10:21:37	RX	3;1;1;0;23;49
                                  Node successfully start and connecting to gateway with new bootloader, but then I issue reboot command in MYSController, node hangs up completely, even reset button isn't working. Only power off, then power on helps. Assign firmware isn't working also (nothing happens).
                                  • R robosensor
                                    Upload log is here:
                                             Using Port                    : COM10
                                             Hardware Version: 2
                                             Topcard         : Unknown
                                             Vtarget         : 0.0 V
                                             Varef           : 0.0 V
                                             Oscillator      : Off
                                             SCK period      : 0.1 us
                                    Wunsch
                                             Using Port                    : COM10
                                             Hardware Version: 2
                                             Topcard         : Unknown
                                             Vtarget         : 0.0 V
                                             Varef           : 0.0 V
                                             Oscillator      : Off
                                             SCK period      : 0.1 us
                                    tekkaT
                                    tekkaT
                                    tekka
                                    #126
                                    @robosensor said:
                                    The MYSBootloader.hex file you are flashing has a wrong file size (=32722 bytes) in your post:
                                    MYSBootloader 1.1 should have ~2kb
                                    From your log I assume, that you flashed the sketch instead of the bootloader.
                                    Please pay attention to steps 3 and 13 from the step-by-step manual.
                                    R N 3 Replies Last reply
                                    • tekkaT tekka
                                      R
                                      R
                                      robosensor
                                      @tekka I have noticed this, but I thought that this is due to the peculiarities of bootloader upload process (upper end of memory).
                                       Directory of C:\Program Files (x86)\Arduino\hardware\arduino\avr\bootloaders\MySensors
                                      14.06.2015  00:08    <DIR>          .
                                      14.06.2015  00:08    <DIR>          ..
                                      14.06.2015  09:59             5 548 MYSBootloader.hex
                                                     1 File(s)          5 548 bytes
                                      For sketch size is too big (32722 bytes), real sketch size is 19928 bytes.
                                      In any case, thanks for the help, I'll try to figure it out or try to download it manually using avrdude.
                                      • tekkaT tekka
                                        N
                                        N
                                        NewFolk
                                        @tekka
                                        Hello, could you help me with uploading bootloader. I stuck on Step 5 step-by-step manual and get error
                                        Arduino: 1.6.4 (Mac OS X), Плата"ATmega328 16Mhz MYSBootloader"
                                        avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
                                        I`m using 16Mhz pro mini clone and FTDI232
                                        • tekkaT tekka
                                          R
                                          R
                                          robosensor
                                          wrote on last edited by robosensor
                                          #129
                                          @tekka I have googled for [avrdude bootloader "bytes of flash written"] and found many answers about big upload size for bootloader (> 32000 bytes). It seems that big size is the way it should be.
                                          I have solved problem. I must power up node with newly burned bootloader but without sensor node firmware and upload firmware using MYSController
                                          Incorrect way is: burn bootloader, burn sensor node firmware, powerup sensor.
                                          Thank you for great software! :)
