  3. Ardunio n00b needs some help!
29 Posts 9 Posters 11.0k Views 3 Watching
    mvader
    I am a network engineer and a pretty good scripter. so i'm fairly technically inclined.
    however I am new with Ardunio.
    I can solder, so i figured i would have a go at this project. but i can't seem to get off the ground
    I need a little push if someone wouldn't mind.
    I purchased.
    This Arduino uno r3 board
    http://www.ebay.com/itm/281548912985
    This Ardunio 5100 shield
    http://www.ebay.com/itm/121458024279
    And this Radio
    http://www.ebay.com/itm/121540572074
    I'm trying to just get the ethernet part of it working first.
    I have tried both codebender and the ardunio IDE
    The sketch verifies and it says it's uploads successfully.
    When i go to the device I hit reset on the enet shield and all the lights light up
    but i can not ping the device. the ardunio module vera also can not see it, but i'm obviously not surprised by that.
    The sketch i'm using is the example sketch at mysensors.org from the the enet gateway link.
    is there something I'm missing? have to change because of my board or shield?
    Thanks!
    Modify message
    E 1 Reply Last reply
    • M mvader
      I purchased.
      And this Radio
      Thanks!
      Modify message
      E
      E
      ericvdb
      @mvader
      try moving the line
      gw.begin(RF24_PA_LEVEL_GW, RF24_CHANNEL, RF24_DATARATE, writeEthernet);
      between
      delay(1000);
      and
      server.begin();
        mvader
        I will give that a try tonight when i get home.
        Thanks for the reply!!
        B 1 Reply Last reply
        • M mvader
          B
          B
          boozz
          @mvader Could it be that the sketch freezes as you probably may not have used softspi?
          In the Ethernet sketch you'll find the info were to enable softspi.
          Both the radio and the ethernet shield are not able to share the hardware spi. Your ethernet shield keeps blinking. Try to monitor the gateway via serial. You should at least see the message that the gateway started.
          Succes!
          Boozz
          M 1 Reply Last reply
          • B boozz
            Succes!
            Boozz
            mvader
            Succes!
            Boozz
            is that something (monitoring) I can do with the aurdunio ide software?
            or do i need something else? My board has a micro usb port and i do have the correct drivers installed in windows.
            • M mvader
              Succes!
              Boozz
              B
              B
              boozz
              @mvader yes it's in the Arduino IDE. See right above for the button to open the serial monitor. Make sure you select the right baudrate once the monitor has opened. Should be 115.200 by default I believe.
              BR
              Boozz
              • B boozz
                BR
                Boozz
                mvader
                wrote on last edited by mvader
                BR
                Boozz
                the port speed seemed to do the trick, thanks for that.
                sadly, i keep getting the
                0;0;3;0;9;check wires message
                I've removed the radio and the ethernet shield, recompiled and re-uploaded many times.
                still get the same message. even with the just the uno.
                the power is coming from my laptop usb port, I verified i'm seeing 3.3 and 5v on the uno
                using both code bender and arduino ide software, i get no errors during compile or upload.
                I also did try to edit and enable the softspi include file.
                again recompile/re-up
                still the same 0;0;3;0;9;check wires
                any suggestions?
                thanks!
                edit: just to make sure my process and equipment worked.
                i uploaded the "simple web server" sketch and it did indeed work
                so the board and shield seem to be good. I'm just having a problem getting the gateway code to work with it.
                E S 2 Replies Last reply
                • M mvader
                  BR
                  Boozz
                  any suggestions?
                  thanks!
                  E
                  E
                  ericvdb
                  @mvader
                  Did you enabled SOFTSPI in RF24_config.h?
                  S M 2 Replies Last reply
                  • E ericvdb
                    @mvader
                    Squint
                    wrote on last edited by Squint
                    @ericvdb If you enable SOFTSPI in the MySensors Library, does that also effect the Sensors or only the Gateway code? Is there anything different you would need to do for the Sensors?
                    hekH 1 Reply Last reply
                    • M mvader
                      BR
                      Boozz
                      any suggestions?
                      thanks!
                      Squint
                      FYI: 0;0;3;0;9;check wires means that the wireless module cannot be initialized. When it starts up, it does a validation check, if that check fails, you will receive the "check wires" message.
                      This means you either have the module wired incorrectly or you need to enable SOFTSPI as @ericvdb mentions.
                      I just went through the exact same scenario and after about 2 days of tweaking, I finally got a "Started!" message.
                      Hang in there, you'll get it. :)
                      • S Squint
                        SOFTSPI is a way to emulate SPI interface on some of the other digital inputs. This is a last resort thing used when one module can't behave correctly on the inteface (normally several devices can co-exists).
                        It only affects the code you compile and upload (gateway in you case). You should change code back when gateway has been created unless you want to run SOFTSPI on your sensors as well.
                        • S Squint
                          mvader
                          Very helpful. thank you for the info!!
                          • E ericvdb
                            @mvader
                            mvader
                            @ericvdb said:
                            @mvader
                            I did.
                            I'm assuming that the wireless card is just wired in wrong.
                            Do you happen to know what file the pins are defined in?
                            Appreciate all the responses and help.
                            Getting the simple web server up and running was a good feeling. at least i'm on the right path (& have working hardware). I can move forward with the gateway...
                            • M mvader
                              @ericvdb said:
                              @mvader
                              I did.
                              B
                              B
                              boozz
                              @mvader :
                              By wireless card you mean the radio (nrf24l01+) i guess...
                              see here for the wiring.
                              BR,
                              Boozz
                                mvader
                                Just wanted to report back.
                                I finally got the gateway working.
                                I had my wires backwards.
                                the screen shots show boards with white squares around each pin
                                but my board had no white on it what so ever.
                                so my guess at what was pin 1 (ground)
                                turned out to be wrong.
                                I had to view pics of the boards close up and then i realized my mistake.
                                so step 1 - make the gateway work - completed!
                                • M mvader
                                  E
                                  E
                                  ewgor
                                  @mvader can you please tell us how did u solved with this message 0;0;3;0;9;check wires? i get it when i try the SerialGateway on both Arduinos i have, Mega and Uno! What wires are wrong when only Arduino is connected to my laptop with the USB cable?
                                  Can you please explain more?
                                  Thanks!
                                  • rvendrameR
                                    rvendrameR
                                    rvendrame
                                    The "check wires" means that arduino can't communicate with nRF24L01+ radio.
                                    ESP8266 GW + mySensors 2.3.2
                                    Alexa / Google Home
                                    • E ewgor
                                      Thanks!
                                      mvader
                                      Thanks!
                                      I had my wires backwards. (they were not hooked up correctly)
                                      I would suggest verify your soldering work is good and that that wires are in the correct spot. could be a bad / burned up board as well. try switching radios and or ardunios.
                                      • rvendrameR rvendrame
                                        E
                                        E
                                        ewgor
                                        @rvendrame i dont have any nRF24L01+ radio in my house, i just want to try this SerialGateway between my laptop and my Arduino! What wires to check, the USB cable? this is the only cable i have!
                                        Do i have to buy this device RF24L01 in order to see the SerialGateway working between my PC and Arduino?
                                        • rvendrameR
                                          rvendrameR
                                          rvendrame
                                          The mySensors runs on a radio mesh network:
                                          http://www.mysensors.org/about/components
                                          You need at least one gateway and one sensor/actuator node. Both with radios. You also need one controller (or computer) to process the messages.
                                          Alexa / Google Home
