  3. Water pressure sensor
8 Posts 4 Posters 4.7k Views 6 Watching
  • L
    L
    lekeb
    I need your help to write my first "My sensor" sketch.
    I use this 5V sensor (link below) and pro-mini arduino to mesure water pressure inside my home water pipe.
    https://fr.aliexpress.com/item/0-0-5-Mpa-Water-Gas-Pressure-Sensor-G1-4-DC-5V-Air-Compressor-Pressure-Transmitter/32660132491.html?spm=a2g0s.9042311.0.0.KxZ6lv
    I used this simple sketch to read water pressure in Bar. I can read a pressure around 2.20 Bar
      Serial.begin(9600);
    int lecture_adc;
    float pression;
    lecture_adc = analogRead(A0);
    Serial.print("Sensor Value: ");
    Serial.println(lecture_adc);
    pression = (((lecture_adc*5/1024.0)-0.52)/1.7); //read pressure in Bar, remove 1.7 to read Voltage, divide 0.17 to read in  MPa
    Serial.print("Pression: ");
    Serial.println(pression);
    delay(1000);
    Now, I tried to monitore my water pressure with my sensor and domoticz, that's why I wrote this sketch
    #define MY_NODE_ID 7
    #define BARO_CHILD 0
    #define BAR_SENSOR_ANALOG_PIN 0
    unsigned long SLEEP_TIME = 60000;
    MyMessage pressureMsg(BARO_CHILD, V_PRESSURE);
    void setup(){
    void presentation() {
      sendSketchInfo("pressure Sensor", "1.0");
      present(BARO_CHILD, S_BARO);
      int lecture_adc;
      float pression;
      lecture_adc = BAR_SENSOR_ANALOG_PIN;
      pression = ((lecture_adc*5/1024.0)-0.52)/1.7;
      send(pressureMsg.set(pression, 2));
      sleep(SLEEP_TIME);
    But with this code, my node send as value -0.21 (check in DEBUG). I don't understand why.
    Could you help me to understand what is wrong?
    • L lekeb
        Serial.begin(9600);
      int lecture_adc;
      float pression;
      delay(1000);
      void setup(){
        int lecture_adc;
        float pression;
        sleep(SLEEP_TIME);
      Welcome to the MySensors community @lekeb Congratulations on your first node :)
      Do you mean that
      prints the correct value, but
      results in .0.21?
      Could you post the full debug output?
      • L
        L
        lekeb
        Thanks for your answer.
        Exactly, I don't get the same value
        Here my full debug
        3 TSM:INIT
        4 TSF:WUR:MS=0
        11 TSM:INIT:TSP OK
        12 TSM:INIT:STATID=7
        14 TSF:SID:OK,ID=7
        16 TSM:FPAR
        35 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        2042 !TSM:FPAR:NO REPLY
        2044 TSM:FPAR
        2063 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        2071 TSF:MSG:READ,0-0-7,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        2076 TSF:MSG:FPAR OK,ID=0,D=1
        4071 TSM:FPAR:OK
        4072 TSM:ID
        4073 TSM:ID:OK
        4075 TSM:UPL
        4077 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        4083 TSF:MSG:READ,0-0-7,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        4088 TSF:MSG:PONG RECV,HP=1
        4091 TSM:UPL:OK
        4092 TSM:READY:ID=7,PAR=0,DIS=1
        4097 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        4104 TSF:MSG:READ,0-0-7,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        4110 TSF:MSG:SEND,7-7-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
        4118 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
        4128 TSF:MSG:READ,0-0-7,s=255,c=3,t=6,pt=0,l=1,sg=0:M
        4134 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=OK:pressure Sensor
        4144 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
        4151 TSF:MSG:SEND,7-7-0-0,s=0,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=OK:
        4157 MCO:REG:REQ
        4160 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        4166 TSF:MSG:READ,0-0-7,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        4171 MCO:PIM:NODE REG=1
        4173 MCO:BGN:STP
        4175 MCO:BGN:INIT OK,TSP=1
        -0.29
        4178 TSF:MSG:SEND,7-7-0-0,s=0,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:-0.29
        4186 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
        4191 MCO:SLP:TPD
        4192 MCO:SLP:WUP=-1
        -0.29
        4196 TSF:MSG:SEND,7-7-0-0,s=0,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:-0.29
        4202 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
        4207 MCO:SLP:TPD```
        • L lekeb
          Here my full debug
          3 TSM:INIT
          4 TSF:WUR:MS=0
          11 TSM:INIT:TSP OK
          14 TSF:SID:OK,ID=7
          16 TSM:FPAR
          2044 TSM:FPAR
          4071 TSM:FPAR:OK
          4072 TSM:ID
          4073 TSM:ID:OK
          4075 TSM:UPL
          4091 TSM:UPL:OK
          4157 MCO:REG:REQ
          4173 MCO:BGN:STP
          -0.29
          4191 MCO:SLP:TPD
          4192 MCO:SLP:WUP=-1
          -0.29
          4207 MCO:SLP:TPD```
          @lekeb looks like you've forgotten analogRead :ghost:
          • L
            L
            lekeb
            Makes sense! My value didn't change over time
            But what means this ligne
            I guessed it was to declare AnalogRead on pin 0?
            M 1 Reply Last reply
            • L lekeb
              mickecarlsson
              Change
              To
              lecture_adc = analogRead(BAR_SENSOR_ANALOG_PIN);
              • L
                L
                lekeb
                Thanks a lot, It works!!!
                Here my code updated
                //#define MY_DEBUG
                //#define MY_NODE_ID 7
                void setup(){
                  int lecture_adc = analogRead(BAR_SENSOR_ANALOG_PIN);
                  float pression = ((lecture_adc*5/1024.0)-0.50)/1.7;
                  sleep(SLEEP_TIME);
                D 1 Reply Last reply
                • L lekeb
                  //#define MY_DEBUG
                  void setup(){
                    sleep(SLEEP_TIME);
                  D
                  D
                  dpancer
                  @lekeb
                  How is your pressure sensor working out? are you getting accurate reading? I'm looking to hook up something similar to vera
