  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 768.6k Views 27 Watching
  • NeverDieN
    NeverDieN
    Here is the Sorbothane installed:
    dbemowskD 1 Reply Last reply
    • NeverDieN NeverDie
      dbemowskD
      dbemowskD
      @neverdie Out of curiosity, I thought most CNC machines used ball screws. That to me looks like a lead screw.
      NeverDieN 1 Reply Last reply
      • dbemowskD dbemowsk
        NeverDieN
        NeverDieN
        @dbemowsk Yes, it's not a ball screw.
          dbemowskD
          dbemowskD
          @neverdie Good, then I don't feel so bad using plain 5/16 threaded rods in my build. I would assume that there is some sort of anti backlash where it connects to the carriage though, correct? There is not a lot of play in mine to begin with, but I am using two threaded rod coupler nuts with a spring in between on mine to take up any little bit of backlash it might have.
            NeverDieN
            NeverDieN
            @dbemowsk said in CNC PCB milling:
            Yes, mine has a similar spring, and I assume for the same reason.
            • NeverDieN
              NeverDieN
              #546
              For now, I've settled on this hardware for monitoring the CNC when I'm not in the garage:
              The bottom unit monitors the current that the CNC consumes to determine whether or not the CNC is active. When the CNC transitions from active to inactive, it sends a wireless signal to the battery powered node (above it in the photo), which rings a buzzer to let me know that the CNC has finished.
              Since my 3D printer that's on order is also 24 volts, I think there's a good chance this hardware may work with it as well. :)
              • NeverDieN
                NeverDieN
                #547
                The sorbathane helped a little, maybe, but there's still a lot of vibration. Found this video on how to dampen a 3D printer. It has some Interesting ideas on how to dampen vibrations:
                https://www.youtube.com/watch?v=OnfYA5QLA84
                The video is aimed at Mk3 i2 owners, but I imagine similar tricks might work for a small CNC such as that discussed on this thread.
                • NeverDieN
                  NeverDieN
                  #548
                  Based on a file test, it appears that the smooth rod is not hardened. Not sure how much improvement I might see if I upgraded to hardened.
                  Unfortunately, this thread seems to have fizzled out....
                  • NeverDieN
                    NeverDieN
                    #549
                    Looks as though upgrading to hardened and chromed rods is fairly inexpensive:
                    https://www.aliexpress.com/item/Optical-Axis-300-380-400-500-mm-Smooth-Rods-8mm-Linear-Shaft-Rail-3D-Printers/32838846750.html?spm=2114.search0204.3.2.7fc04405d43d4M&ws_ab_test=searchweb0_0%2Csearchweb201602_5_10152_10151_10065_10344_10068_10130_10324_10342_10547_10325_10343_10546_10340_10548_10341_10545_10084_10083_10618_10630_10307_5711220_5722320_10313_10059_10534_100031_10629_10103_10626_10625_10624_10623_10622_10621_10620_10142%2Csearchweb201603_2%2CppcSwitch_5_ppcChannel&algo_expid=04efdb04-9516-4d2e-a8d0-ec277a9f66b3-0&algo_pvid=04efdb04-9516-4d2e-a8d0-ec277a9f66b3&priceBeautifyAB=0
                    So, less sagging in the middle, and maybe less vibration also.
                      dbemowskD
                      dbemowskD
                      @neverdie As part of my CNC build, I have gotten 8mm rods that I pulled out of old scanners and old ink jet printers, I guess I never checked to see if they were hardened or not. How much of a difference would it make?
                        NeverDieN
                        NeverDieN
                        @dbemowsk Well, let's put it this way: the set screws on my rods had come lose, so I noticed considerable sagging when the spindle got to the middle of the rods. When I tightened up the set screws, a lot of that sagging went away. So, I think that means the spindle is now, in part, being supported by tension.
                        Hardened rods should flex less. I'm sure there are formulas that could tell you by how much. Also, there are different degrees of hardness.
                        • NeverDieN
                          NeverDieN
                          On the other hand, according to this thread:
                          http://forums.reprap.org/read.php?1,113177
                          deflection isn't affected by hardness. I had thought hardened would be stiffer.
                            dbemowskD
                            dbemowskD
                            @neverdie So I have a few questions regarding your spindle assembly. First, do you know how many RPMs your motor is? Next, how many collets do you have and use for your setup. Third, is your collet and chuck assembly like this one?
                            https://www.amazon.com/Adealink-Spring-Collets-Extension-Holder/dp/B078JQQ5X7/ref=sr_1_2?s=hi&ie=UTF8&qid=1519193790&sr=1-2&keywords=5mm+shaft+collet
                              NeverDieN
                              NeverDieN
                              I don't know. You could try asking the seller: https://www.aliexpress.com/store/product/Freeshipping-spindle-775-with-ER11-High-speed-Large-torque-DC-motor-Electric-tool-Electric-machinery-12/424291_32809235881.html?spm=2114.12010612.0.0.47291db35wj5jd
                              One.
                              Your link says its an ER11A, whereas I think mine may be just an ER11.
                              Though my spindle eventually gets the job done, I think a more powerful spindle could maybe cut faster
                                One.
                                dbemowskD
                                dbemowskD
                                #555
                                @neverdie said in CNC PCB milling:
                                Thanks, I wasn't sure if you bought yours as a package deal where they had the specs on all the parts.
                                I did find this link (http://www.cnczone.com/forums/cnc-tooling/319670-er11-type-vs-b-type.html) which states that the A should designate the style of the clamping nut. Looking at the different styles they have, it just looks like they just use different tools to tighten the nut. A looks like a standard wrench type.
                                This is the only information I have on the motor that I plan on using. I googled all the numbers and couldn't find anything.
                                It is a German made motor, so I am assuming it is a pretty good motor. It feels like it has pretty good torque. It is one that I had in my junk parts bin. it has a 5mm D type shaft. In the pic I just have one of my 5mm to 8mm couplers on it. I think I may order that collet assembly as it sounds like it should work. It says that it uses ER11 collets anyway.
                                  NeverDieN
                                  NeverDieN
                                  @dbemowsk Maybe you'll want to try using TMC2130 drivers for your stepper motors?
                                    dbemowskD
                                    dbemowskD
                                    @neverdie I do already have the DRV8825's that came with the controller. I guess I'll try them and see how they work and if they don't seem to do well, I'll consider changing.
                                    • NeverDieN
                                      NeverDieN
                                      #558
                                      As it turns out, the smooth rods on my CNC are 10mm in diameter, not the more common 8mm found on 3D printers. Definitely not hardened: I can see grooves where the ball bearings have scratched into it.
                                      Sanladerer strongly recommends using precision tolerance hardened chromed rods for 3D printers, so I can only assume the same would apply to CNC.
                                      Since it's a relatively cheap upgrade, I may do it.
                                      What tolerance should I get? h6? Also, what spec for surface roughness?
                                      scalzS 1 Reply Last reply
                                        scalzS
                                        scalzS
                                        wrote on last edited by scalz
                                        #559
                                        not surprised it is not hardened for the price, cheap price->cheap quality
                                        pity is sometimes even more expensive kits cheat on this too..
                                        I would say as long as you use h6/h7 with roughness around 60 or more, so, precision hardened, chromed nice too, you should be very fine. day&night vs cheap rods which, in first place are not made for this job+precision..
                                        • NeverDieN
                                          NeverDieN
                                          I made some enhancements to the remote used with the CNC Monitor. Among other things, it's now more compact, and the top now has a ground plane (which may help the RF):
                                          The bottom makes most of the connections and will hold the two AA batteries:
