  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 768.6k Views 27 Watching
  • NeverDieN NeverDie
    I made some enhancements to the remote used with the CNC Monitor. Among other things, it's now more compact, and the top now has a ground plane (which may help the RF):
    The bottom makes most of the connections and will hold the two AA batteries:
    dbemowskD
    dbemowskD
    @neverdie So I have an odd CNC related couple of questions. Next, when you put a bit in the chuck, do you always bury it in to the base of the bit? When you have your bit in for working on PCBs, what is the distance from the end of the chuck to the tip of the bit that you use?
    • dbemowskD dbemowsk
      NeverDieN
      NeverDieN
      @dbemowsk Is this for calculating deflection?
      dbemowskD 1 Reply Last reply
        NeverDieN
        NeverDieN
        @dbemowsk I haven't been very consistent, but I'd say roughly 7/8 inch.
          dbemowskD
          dbemowskD
          @neverdie Actually, I am working on my Z axis and am trying to gauge how long I should have my rods. They are currently 8.25 in (209.55 mm). Wondering if there would be any benefit to leaving them that long or shortening them up some more.
          This is the spindle frame as I have it designed so far. The blue piece on the motor shaft is just one of the couplers that I bought for the steppers to connect the threaded rods. It is just for looks until I get the chuck.
            NeverDieN
            NeverDieN
            #565
            @dbemowsk said in CNC PCB milling:
            In that case, what matters is whether you can raise the spindle high enough on the z-axis to remove the used bit and insert the next one. I wish my z-axis had a bit more height on it. Sometimes I have to move the spindle away from the workpiece in order to get enough clearance for a tool change. I suppose it doesn't help that I'm using a 3/4" waste board. ;)
              dbemowskD
              dbemowskD
              @neverdie said in CNC PCB milling:
              Do you need 3/4"? Wouldn't 1/4" or 1/2" work? Do you drill in that far?
              NeverDieN 1 Reply Last reply
                NeverDieN
                NeverDieN
                @dbemowsk 1/2" is probably ideal for my particular setup. 3/4" is simply what I tried first. 1/4" might work, but with less margin for error.
                  NeverDieN
                  NeverDieN
                  @dbemowsk Shouldn't you have some linear ball bearings gripping those z-axis rods?
                  • NeverDieN
                    NeverDieN
                    #569
                    Here is the above PCB after assembly:
                    As you can see, it offers more potential functionality than the earlier version. It still has a buzzer, which is now mounted underneath the pro mini.
                      dbemowskD
                      dbemowskD
                      @neverdie FOr starters I am trying 3D printed rod bearings. I';ll see how that goes. The beauty of designing this myself is that I can alter the design whenever I want.
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @neverdie Di the relocation of the buzzer increase audibility as you were seeking?
                          NeverDieN
                          NeverDieN
                          #572
                          What are those? Is it like this?
                          or this?
                            or this?
                            dbemowskD
                            dbemowskD
                            #573
                            @neverdie these are similar linear bearings that you can buy mine are similar 3D printed ones
                              NeverDieN
                              NeverDieN
                              @dbemowsk what kind of material?
                                dbemowskD
                                dbemowskD
                                @neverdie I just printed them in PLA and they seem to slide pretty smoothly on the rods, but someone told me that printing them in nylon is better.
                                  NeverDieN
                                  NeverDieN
                                  #576
                                  It would seem so: http://www.craftechind.com/top-5-materials-for-plastic-bearings-used-on-metal-surfaces/
                                  If you had a multi-filament printer, I wonder if you could print the nylon bearing within another plastic piece (e.g. the part that holds the spindle to the z-axis)? That would would be pretty cool and would also save assembly time.
                                    dbemowskD
                                    dbemowskD
                                    @neverdie the way i have it designed, the printed bearings get sandwiched by a rear plate that holds the bearings and coupler nut that goes on the threaded rod to drive the assembly up and down.
                                    • dbemowskD
                                      dbemowskD
                                      I wasn't home before to get a pic, but here is the layout.
                                      • NeverDieN
                                        NeverDieN
                                        #579
                                        Anyone tried Trinamic drivers, such as the TMC2130? They seem to produce superior 3D prints, and so I would guess they would yield some improvement for CNC as well.
                                        So far I've only found two boards that appear to be made for them, a ramps and a rumba:
                                        https://www.aliexpress.com/item/MKS-Gen-V1-4-control-board-5PCS-TMC2130-V1-0-And-Heatsink-stepper-motor-compatible-with/32836389832.html?spm=2114.search0204.3.2.3e5a8105IWdaWH&ws_ab_test=searchweb0_0,searchweb201602_5_10152_5711320_10151_10065_10344_10068_10130_10324_10342_10547_10325_10343_10546_10340_10548_10341_10545_10084_10083_10618_10630_10307_5711220_5722320_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_10620_10142,searchweb201603_2,ppcSwitch_5_ppcChannel&algo_expid=875aa997-05fe-4eda-9d76-0aaefcaeff83-0&algo_pvid=875aa997-05fe-4eda-9d76-0aaefcaeff83&priceBeautifyAB=0
                                        https://www.aliexpress.com/item/3D-Printer-Rumba-Board-With-6pcs-TMC2130-Stepper-Driver-6pcs-Heatsink-High-Quality-3D-Printer-Parts/32839321651.html?spm=2114.search0204.3.49.3e5a8105IWdaWH&ws_ab_test=searchweb0_0,searchweb201602_5_10152_5711320_10151_10065_10344_10068_10130_10324_10342_10547_10325_10343_10546_10340_10548_10341_10545_10084_10083_10618_10630_10307_5711220_5722320_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_10620_10142,searchweb201603_2,ppcSwitch_5_ppcChannel&algo_expid=875aa997-05fe-4eda-9d76-0aaefcaeff83-7&algo_pvid=875aa997-05fe-4eda-9d76-0aaefcaeff83&priceBeautifyAB=0
                                        I have no experience with either board, so I don't know if either would be desirable.
                                        The pinout of the TMC2130 is different than the A4988 driver currently used in my Woodpecker. However, I could perhaps make an adapter board to re-route the pins so as to be compatible. In that case, maybe I could plug them into my Woodpecker board. A video by Sanladerer seems to imply that might actually work:
                                        https://www.youtube.com/watch?v=sPvTB3irCxQ
                                        Note: from what I've read, the v1.1 TMC2130 modules are much better for adapting than the v1.0 modules.
                                        • NeverDieN
                                          NeverDieN
                                          #580
                                          I'm unsure what kind of firmware runs on the Woodpecker board, so I have doubts whether it could exploit the Trinamic features. Anyone here know?
                                          So.... I'm looking at a Smoothieboard as perhaps one possibility, although I'm not sure yet as to whether Chillipepr will talkto it.
                                          https://www.panucatt.com/azteeg_X5_mini_reprap_3d_printer_controller_p/ax5mini.htm
