  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 817.0k Views 27 Watching
  • YveauxY Yveaux
    @andrew you wrote you sourced your cnc from the EU. Could you share where you bought it?
    andrewA
    andrewA
    andrew
    @yveaux I bought mine from "rattmotor" seller on ebay (https://www.ebay.com/usr/rattmmotor), but I basically just limited the item location filter to Europe when I searched for cnc2418 on ebay, then I made my choice based on the price and seller ratings.
    • YveauxY Yveaux
      NeverDieN
      NeverDieN
      @yveaux Even Amazon.com sells them. Some even have 1-day Prime shipping, so you could have one tomorrow if you wanted.
      YveauxY 1 Reply Last reply
      • NeverDieN NeverDie
        YveauxY
        YveauxY
        @neverdie Amazon still doesn't ship to the Netherlands and all eBay sellers seem to ship from China...
        andrewA 1 Reply Last reply
        • YveauxY Yveaux
          andrewA
          andrewA
          andrew
          wrote on last edited by andrew
          #44
          @yveaux search for "cnc 2418" with space separated, then you can find some one from Germany.
          • andrewA andrew
            YveauxY
            YveauxY
            @andrew ok, I'll give it another try, but suggested rattmotor also seems to ship from China (despite all the American flags in the pictures...)
            • YveauxY Yveaux
              andrewA
              andrewA
              andrew
              #46
              @yveaux they had items from China and from EU warehouse as well. with the search I mentioned you can find product like this or this
              • andrewA andrew
                YveauxY
                YveauxY
                @andrew ok, thanks! It was probably the mobile searching then that hid them.
                Probably better not having the link though... Must resist to click....
                NeverDieN 1 Reply Last reply
                • YveauxY Yveaux
                  NeverDieN
                  NeverDieN
                  #48
                  @yveaux If you do a fair amount of PCB prototyping, then it pays for itself pretty rapidly (as compared to using a Fab that is).
                  YveauxY zboblamontZ 2 Replies Last reply
                    YveauxY
                    YveauxY
                    @neverdie sure, but I'm afraid of the time I'll have to invest too tweak it and keep it running...
                    Let's see how it turns out for you!
                    • YveauxY Yveaux
                      NeverDieN
                      NeverDieN
                      #50
                      @yveaux Oh, come on, jump in and share the risk! It will be more fun that way.
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @neverdie The attraction for making ready designed boards as one-offs is clear enough, the costs and time don't stack up for bulk manufacture, but that is not what these machines are intended for anyway. For those making occasional boards who have no time constraints such machines are an increasingly affordable solution without chemicals to mess with.
                        However much the focus here may be on PCBs, wood engraving, making your own panel labels, plaques, or fancy engraving on plastics are all uses beyond the PCB...
                        • zboblamontZ zboblamont
                          NeverDieN
                          NeverDieN
                          #52
                          @zboblamont I was just joking. Actually, I don't think there is much risk at all, because @andrew has proven it out already. If it weren't for him, and the results he's reporting, I wouldn't have had the confidence to buy a CNC 2418, or even embark upon this.
                          I also think it's just one of those things where you either value the benefits, or you don't. That's going to vary a lot from person to person.
                          That being said, the more the merrier!
                          Also, though it's totally off topic, if there were a way to custom mill little project enclosures out of solid plastic, that would be a real bonus. That would obviate pretty much my only reason for also wanting a 3D printer. For instance, I can buy 1" thick vinyl planks at Home Depot for not much money, so it wouldn't matter if all of the plastic that's removed from a cavity is entirely wasted. It might even be cheaper than doing addative 3D printing from a spool. But, like I say, that would be gravy. I'm not banking on that. I suppose I could also make little wooden boxes from thinner sheets of wood that get cut on this CNC, and maybe that would be just as good. I'm pretty confident that could be done, though I'm not really sure as yet how.
                            zboblamontZ
                            zboblamontZ
                            zboblamont
                            @neverdie I was referring to earlier comment from the more commercial viewpoint. It is a hobby machine, but with a variety of uses beyond the current subject, and at this cost level risk is minimal.
                            I have woodwork and mechanical tools aplenty which have made short work of completely obtuse and dissociated tasks, this is simply another tool with a specific task in mind, but a variety of possible other uses.
                            • dbemowskD
                              dbemowskD
                              #54
                              So I picked this thing up at our local university surplus store. It is a Lachat instruments XYZ auto sampler After some research, it appears to be a piece of lab equipment for sample testing. Not exactly sure how it works, but for the $20 US that I paid for it, I though it might be worth trying to build a CNC machine from it. The video clip shows the machine homing the X, Y and Z axis' when powered on.
                              https://www.youtube.com/watch?v=OYuLQs5Cm7E
                              Here is the label from the back panel:
                              The motors for the X, Y and Z axis' do not appear to be stepper motors though:
                              Found this one on ebay that appears to be a match. https://www.ebay.com/itm/Used-Good-MAXON-motor-2028-945-13-131-025-30-1-E-N2-/171548411580
                              It appears to use rotary encoders to deal with position. Here is a pic of the encoders:
                              If you look at the image above you will see that the X axis rails and linear bearings are pretty beefy at 16mm diameter.
                              It would be nice if I could figure out the serial interface to see if I could make it do anything. Just wondering what the thoughts are from the group.
                              andrewA NeverDieN 2 Replies Last reply
                              • dbemowskD dbemowsk
                                andrewA
                                andrewA
                                andrew
                                @dbemowsk the serial interface to those controllers which are used by most of these DIY CNCs are simple serial over USB, which speak grbl.
                                if your motors are not steppers then I guess it would not be precise enough.
                                dbemowskD 1 Reply Last reply
                                • andrewA andrew
                                  dbemowskD
                                  dbemowskD
                                  @andrew I had made the assumption that it had to be somewhat precise being a lab instrument, but maybe i'm wrong.
                                  • dbemowskD
                                    dbemowskD
                                    Wonder if I could convert to steppers. I'll have to check the motors and mounting.
                                      andrewA
                                      andrewA
                                      andrew
                                      @dbemowsk said in CNC PCB milling:
                                      well, that is just my assumption. with steppers you definitely could turn exactly as much as you have to, with normal motors it is much harder as there should be some feedback based control (e.g. the rotary encoders which you mentioned). moreover steppers "keep" their status in one fixed position until they receive another polarity change (so a step), while in case of standard motors it is not true and if the mechanical part does not prevent it, then their axis could turn unexpectedly based on the external force it receive.
                                      • andrewA andrew
                                        dbemowskD
                                        dbemowskD
                                        @andrew When it homes itself to the left and stops, it appears to lock itself in position. Do you know of any software that I could use to test the serial connection if it in fact it does speak grbl?
                                        andrewA NeverDieN 3 Replies Last reply
                                          andrewA
                                          andrewA
                                          andrew
                                          @dbemowsk any serial console could do the job. I usually use command line tools on OS X or linux, such as minicom or screen, but you can find graphical tools pretty easy. if you are working on windows then e.g. PuTTY could be a good solution.
